Vida CEM swapping
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
RickHaleParker wrote: 24 Apr 2021, 08:48 Updated CEM list 4/24/2021
P1 CEM Part numbers.
8690719 | 8690720 | 8690721 | 8690722 | 30765471 | 30728906 | 30765015 | 31254317 | 31327215 | 31254749 | 31254903 | 31296881
P2 CEM-B (Brick shaped 1999-2004 with K-line ) Part numbers.
8645716 | 8645719 | 8688434 | 8688436 | 8688513 | 30657629 | 9494336 | 9494594 | 8645171 | 9452553 | 8645205 | 9452596 | 8602436 | 9469809 | 8645200 |
P2 CEM-L ( L shaped and marked L 2005 - 2014 ) Part numbers.
30682981 | 30682982 | 30728542 | 30765149 | 30765646 | 30786475 | 30786889 | 31282457 | 31314468 |
P2 CEM-H ( L shaped and marked H 2005 - 2007 )
30786476 | 30728539 | 30682982 | 30728357 | 30765148 | 30765643 | 30786476 | 30786890 | 30795115 | 31282455 | 31394157 | 30786579
Notes
30759114 listed as a L shaped P2 CEM unable to determine if it is a CEM-L or CEM-H.
In this list when did the 250 -> 500 Kbps CAN-HS transition happen?
Also does CAN-LS always work at 125 Kbps, on all those listed CEMs? I'm thinking of querying CEM part.number via CAN-LS and configuring CAN-HS, shuffle order, etc based on that, so the cracker would be essentially a plug'n'play.
T5Luke
Year and Model: S60 T5 2001
Has thanked: 11 times
Been thanked: 130 times
Post by T5Luke »
The CEM got changed in MY 2005 (10th pos VIN 5 or higher), with this change the engine CAN was set to 500, before MY 2005 engine CAN is always 250, MS CAN stayed alwas at 125, i'm just writing about P2...
vtl
Post by vtl »
T5Luke wrote: 28 Apr 2021, 08:48 The CEM got changed in MY 2005 (10th pos VIN 5 or higher), with this change the engine CAN was set to 500, before MY 2005 engine CAN is always 250, MS CAN stayed alwas at 125, i'm just writing about P2...
I'm lazy, do you have a CAN request at hand for the VIN readout? =)
T5Luke
Post by T5Luke »
Ha, the prob is you need to read the VIN on MS CAN before 2005, and you need to read the VIN on HS CAN from 2005.
If i remember right it was CB 50 B9 FB for CEM on id 50. Yes it was 0xCB...
vtl
Post by vtl »
In P1 CEM, what's the ID on the CAN-LS bus? I've tried 0x40 and 0x50 to no avail. Reading from 0x50 on HS does work.
T5Luke
Post by T5Luke »
ID is same as P2, but P2 only responds to 1 can bus for diagnostic data, it should be the same here.
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Second that.
P2 CEM-B 250 Khz
P2 CEM-L 500 Khz
P2 CEM-H 500 Khz
vtl wrote: 28 Apr 2021, 08:51 I'm lazy, do you have a CAN request at hand for the VIN readout? =)
Can you extract the information from this?
https://github.com/carloop/app-vin-reader
Active
Past
vtl
Post by vtl »
T5Luke wrote: 28 Apr 2021, 11:25 ID is same as P2, but P2 only responds to 1 can bus for diagnostic data, it should be the same here.
Hmm, yes. Added next pins and it started to respond:
COCKPIT-1:16 -> +12v
COCKPIT-1:28 -> GND
COCKPIT-1:30 -> +12v
vtl
Post by vtl »
Interesting observation: P2 CEMs (both brick and L) in programming mode are willing to talk only on the CAN-bus where the first CAN message has been sent.
Example:
- init CAN-LS
- send to prog mode on CAN-LS
- get CEM part number on CAN-LS (and receive a reply)
- init CAN-HS
- no reaction to anything sent over CAN-HS
Another example:
- init CAN-LS
- init CAN-HS
- get CEM part number on CAN-HS (and receive a reply)
- CAN-HS works normally
That effectively kills the idea of plug'n'plug (query P/N on LS and configure HS based on the P/N).
T5Luke
Post by T5Luke »
CB 50 B9 F7 would give you the serial number in normal operation mode, maybe it is enough.
