Vida CEM swapping
- RickHaleParker
- Been thanked: 980 times
Why do you want DocosaHexaenoic Acid for your XC90? Are you saying your XC90 is weak in the mental department and needs some improvement or it has high cholesterol ?
* DHA is the active ingredient in omega-3, used for high cholesterol, boosting memory and thinking skills and other things.
Active
Past
Past
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Didn't do anything past that, but I looked at the standard deviations one again, and those same-page comparisons throw the highest deviation across the range. With a smarter control logic it would be possible to crack with one algo only, in one pass.vtl wrote: 29 Apr 2021, 20:23I need to generalize code, so slow path would be taken only on those 20% of hard to crack CEMs. But it is possible.
I looked at the routines placed at different offsets within a page, and the theory agrees with my real world observations. For example, byte 3 (2 from 0) cracks much harder in my original CEM, because its comparison code is trailing the page of byte 2 comparison. Now it is all clear.
GHvilks
- Year and Model: V70, 2007
- Has thanked: 2 times
Hello!
Tried to build T5Luke version of pin cracker with a modified chinese version of MCP2515 module, but can't get it to work properly in the car. If I don't terminate CAN with resistor I get results like this:
[ 00 -- -- -- -- -- ]: 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 : 197664
[ 01 -- -- -- -- -- ]: 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 : 196655
[ 02 -- -- -- -- -- ]: 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 : 193683
[ 03 -- -- -- -- -- ]: 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 : 193263
[ 04 -- -- -- -- -- ]: 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 : 192996
[ 05 -- -- -- -- -- ]: 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 : 192816
If i terminate can with resistor i get results like this:
[ 00 -- -- -- -- -- ]: 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 : 597000
[ 01 -- -- -- -- -- ]: 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 : 597000
[ 02 -- -- -- -- -- ]: 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 : 597000
[ 03 -- -- -- -- -- ]: 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 : 597000
[ 04 -- -- -- -- -- ]: 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 : 597000
[ 05 -- -- -- -- -- ]: 000 000 000 000 000 000 000 000 000 000 000 000 000 000 000 : 597000
I tried adding a second module for low speed CAN but results where the same. Are those chinese MCP2515 that bad or I am doing somthing wrong?
can_with_termination_log.pdf- (77.16 KiB) Downloaded 287 times
can_without_termination_log.pdf- (78.07 KiB) Downloaded 143 times
T5Luke
- Year and Model: S60 T5 2001
- Has thanked: 11 times
- Been thanked: 130 times
I use another lib for this mcp, cause especially on not so original mcps
https://github.com/coryjfowler/MCP_CAN_lib
This works more stable.
Code: Select all
#include <SPI.h>
#include <mcp_can.h>
#include <mcp_can_dfs.h>
#define printf Serial.printf
/* tunables */
#define SAMPLES 70 /* how many samples to do on a sequence, more is better (up to 100) */
#define CALC_BYTES 3 /* how many PIN bytes to calculate (1 to 4), the rest is brute-forced */
#define CEM_REPLY_DELAY_US 50 /* minimum time in us for CEM to reply for PIN unlock command (approx) */
#if defined(TEENSYDUINO) /* Teensy 4.0 */
#define CAN_CS_PIN 2 /* MCP2515 chip select pin */
#define CAN_INTR_PIN 4 /* MCP2515 interrupt pin */
#define CAN_L_PIN 10 /* CAN-L wire, directly connected */
#define TSC ARM_DWT_CYCCNT
#elif defined(ESP32) /* ESP32 Node32s */
#define CAN_CS_PIN 27 /* MCP2515 chip select pin */
#define CAN_INTR_PIN 34 /* MCP2515 interrupt pin */
#define CAN_L_PIN 26 /* CAN-L wire, directly connected */
#define TSC xthal_get_ccount()
#else
#error "TEENSY or ESP32"
#endif
#define PIN_LEN 6
MCP_CAN CAN0(CAN_CS_PIN);
bool cem_print = true;
void cem_send(unsigned long id, byte *d)
if (cem_print)
printf("send: ID=%08x data=%02x %02x %02x %02x %02x %02x %02x %02x\n", id, d[0], d[1], d[2], d[3], d[4], d[5], d[6], d[7]);
CAN0.sendMsgBuf(id, 1, 8, d);
bool cem_receive(bool wait, unsigned long *id, byte *data)
byte d[8] = { 0 };
byte len;
int ret;
unsigned long can_id = 0;
long unsigned int rxId;
do {
ret = (CAN0.checkReceive() == CAN_MSGAVAIL);
if (ret) {
CAN0.readMsgBuf(&rxId, &len, d);
//CAN0.readMsgBuf(&len, d);
can_id = rxId;
} while (!ret && wait);
if (id)
*id = can_id;
if (data)
memcpy(data, d, 8);
if (ret && cem_print)
printf("recv: ID=%08x data=%02x %02x %02x %02x %02x %02x %02x %02x\n", can_id, d[0], d[1], d[2], d[3], d[4], d[5], d[6], d[7]);
return ret;
byte to_bcd(byte b)
return ((b / 10) << 4) | (b % 10);
byte from_bcd(byte b)
return ((b >> 4) * 10) + (b & 0xf);
int crack_rate;
int cem_print_crack_rate()
byte pin[PIN_LEN];
long start, end;
int lat;
bool cp = cem_print;
int n = 1000;
int rate;
cem_print = false;
start = millis();
for (int i = 0; i < n; i++)
cem_unlock(pin, &lat, true);
end = millis();
rate = 1000 * n / (end - start);
printf("%d pins in %d ms, %d pins/s\n", n, (end - start), rate);
cem_print = cp;
return rate;
volatile bool can_intr;
void cem_intr()
can_intr = true;
bool cem_unlock(byte *pin, int *lat, bool shuffle)
byte b[8] = { 0x50, 0xbe };
byte *p = b + 2;
long start, end;
byte len;
unsigned long id;
long cur, max = 0;
bool prev_pin = true;
if (shuffle) {
p[3] = pin[0];
p[1] = pin[1];
p[5] = pin[2];
p[0] = pin[3];
p[2] = pin[4];
p[4] = pin[5];
} else {
memcpy(p, pin, 6);
cem_send(0xffffe, b);
can_intr = false;
long mt = 0;
for (cur = 0, start = TSC; !can_intr && mt < CEM_REPLY_DELAY_US * clockCyclesPerMicrosecond();) {
if (digitalRead(CAN_L_PIN)) {
cur++;
continue;
end = TSC;
if (cur > max) {
max = cur;
cur = 0;
mt = end - start;
while (!(digitalRead(CAN_L_PIN)))
start = TSC;
cem_receive(true, &id, b);
*lat = mt;
return b[2] == 0x00;
void cem_read_part_number()
unsigned long id;
byte d[8];
int ret;
byte data[8] = { 0x50, 0x88, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
printf("reading part number\n");
cem_send(0xFFFFE, data);
ret = cem_receive(true, &id, d);
void cem_programming_mode_on()
byte data[8] = { 0xFF, 0x86, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
int time = 5000;
int _delay = 5;
int cp = cem_print;
printf("sending CEM into programming mode\n");
cem_print = false;
while (time > 0) {
time -= _delay;
delay(_delay);
cem_print = cp;
void cem_reset()
byte data[8] = { 0xFF, 0xc8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
printf("reset CEM\n");
for (int i = 0; i < 50; i++) {
cem_send(0xFFFFE, data); delay(100);
struct seq {
byte b;
int lat;
} s[100] = { 0 };
int seq_max(const void *a, const void *b)
struct seq *_a = (struct seq *)a;
struct seq *_b = (struct seq *)b;
return _b->lat - _a->lat;
#define CEM_REPLY_US 200
void crack_pin_pos(byte *pin, int pos)
int h[CEM_REPLY_US];
int lat;
bool shuffle = true;
cem_print = false;
int from = 0, to = 10000;
memset(s, 0, sizeof(s));
for (int i = from; i < to; i++) {
unsigned int m = i;
pin[pos + 1] = to_bcd(m % 100); m /= 100;
pin[pos + 0] = to_bcd(m % 100); m /= 100;
if ((i % 100) == 0)
printf("%02x %02x %02x %02x %02x %02x: ", pin[0], pin[1], pin[2], pin[3], pin[4], pin[5]);
if ((i % 100) == 0) {
memset(h, 0, sizeof(h));
for (int j = 0; j < SAMPLES; j++) {
pin[pos + 2] = to_bcd(j);
cem_unlock(pin, &lat, shuffle);
int idx = lat / clockCyclesPerMicrosecond();
if (idx >= CEM_REPLY_US)
idx = CEM_REPLY_US - 1;
h[idx]++;
pin[pos + 2] = 0;
if ((i % 100) == 99) {
int prod = 0;
for (int k = 0; k < CEM_REPLY_US; k++) {
if (k > 61 && k < 95)
printf("%03d ", h[k]);
prod += h[k] * k;
printf(": %d\n", prod);
s[i / 100].b = pin[pos + 0];
s[i / 100].lat = prod;
qsort(s, 100, sizeof(struct seq), seq_max);
for (int i = 0; i < 25; i++) {
printf("%d: %02x = %d\n", i, s[i].b, s[i].lat);
printf("pin[%d] candidate: %02x lat %d\n", pos, s[0].b, s[0].lat);
pin[pos] = s[0].b;
pin[pos + 1] = 0;
void cem_crack_pin(int max_bytes)
byte pin[PIN_LEN] = { 0x00 , 0x00, 0x00, 0x00, 0x00, 0x00 }; //Preset pincode
long start = millis(), end;
bool cracked = false;
printf("calculating bytes 0-%d\n", max_bytes - 1);
crack_rate = cem_print_crack_rate();
for (int i = 0; i < max_bytes; i++)
crack_pin_pos(pin, i); //i= POS cracker should start
int n = max_bytes;
for (int i = 0; i < PIN_LEN; i++) {
printf("0x%02x ", pin[i]);
printf(" -- brute forcing bytes %d to %d (%d bytes), will take up to %d seconds\n", n, PIN_LEN - 1, PIN_LEN - n, (int)(pow(100, PIN_LEN - n) / crack_rate));
for (unsigned long m = 0; m < pow(100, (PIN_LEN - n)); m++) {
unsigned long f = m;
for (int k = n; k < PIN_LEN; k++) {
pin[k] = to_bcd(f % 100);
f /= 100;
int lat;
if (cem_unlock(pin, &lat, true)) {
printf("found PIN: 0x%02x 0x%02x 0x%02x 0x%02x 0x%02x 0x%02x\n", pin[3], pin[1], pin[4], pin[0], pin[5], pin[2]);
cracked = true;
break;
end = millis();
printf("PIN is %scracked in %3.2f seconds\n", cracked ? "" : "NOT ", (end - start) / 1000.0);
printf("done\n");
//extern "C" uint32_t set_arm_clock (uint32_t freq);
void setup() {
//set_arm_clock (180000000);
Serial.begin(115200);
delay(3000);
pinMode(CAN_L_PIN, INPUT_PULLUP);
pinMode(CAN_INTR_PIN, INPUT);
printf("F_CPU %d\n", F_CPU);
printf("can init\n");
if(CAN0.begin(MCP_ANY, CAN_500KBPS, MCP_8MHZ) == CAN_OK)
Serial.println("MCP2515 Initialized Successfully!");
else
Serial.println("Error Initializing MCP2515...");
CAN0.setMode(MCP_NORMAL); // Set operation mode to normal so the MCP2515 sends acks to received data.
attachInterrupt(digitalPinToInterrupt(CAN_INTR_PIN), cem_intr, FALLING);
printf("done\n");
while (cem_receive(false, NULL, NULL));
cem_programming_mode_on();
cem_read_part_number();
cem_crack_pin(CALC_BYTES);
cem_reset();
void loop() {
- RickHaleParker
Latency detection jumper missing?GHvilks wrote: 01 May 2021, 09:14 Hello!
Active
Past
Past
5ft24
- Year and Model: 2005 XC90 V8 AWD
- Has thanked: 20 times
- Been thanked: 12 times
LOL. the Volvo DHA software. Back a few pages. Let's you monitor all CAN traffic, logs it etcRickHaleParker wrote: 01 May 2021, 08:30Why do you want DocosaHexaenoic Acid for your XC90? Are you saying your XC90 is weak in the mental department and needs some improvement or it has high cholesterol ?![]()
- RickHaleParker
I think I may of found some of what you are looking for. Check your private messages. Let us know if it is true.5ft24 wrote: 01 May 2021, 11:04 LOL. the Volvo DHA software. Back a few pages. Let's you monitor all CAN traffic, logs it etc
Active
Past
Past
- 9409 Views
Last post by RickHaleParker
- 9455 Views
- 27 Replies
- 29223 Views
Last post by cn90
- 10 Replies
- 10988 Views
Last post by jonesg
- 6098 Views
