Rear shocks top nut
toolpusher
Year and Model: 2007 XC90
Has thanked: 3 times
Been thanked: 3 times
Post by toolpusher »
Quick update: went through two locking pliers on the shaft that would not grip enough despite grinding.
An impact torx bit did a good job with the pass through wrench until it snapped leaving the bit head stuck in the shaft.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
toolpusher wrote: 08 Apr 2021, 21:58
I hate when that happens. Time for gas axe (AKA cutting torch)?
toolpusher
I am thinking of drilling into the nut. Start small, get bigger and then blow off the nut with a chisel.
I am afraid I am past drilling the shaft, because now there is a hardened steel bit stuck in it :(
Been thanked: 504 times
Post by cn90 »
- If you carefully apply heat (propane torch set at low) and point straight to the nut for 1 min, then spray with
PB Blaster and let is soak, then turn it.
- If you mess up the shock mount (the round piece), let me know, I have 2 gently used shock mounts in excellent condition, I can ship them to you.
- If you look at the link I posted above, you will see the vise-grips trick...
toolpusher
Yessss, it’s loose. Used a tie down strap to keep the self tightening Knipex in place. Seriously, get one, mine is 20 years old, bites as new.
toolpusher
Hi, Putting it all back together. I asked FCP for the torque specs. According to that sheet the top nut just needs 18 Ft Lb. Is that correct? Seems pretty low.
I hate to abuse good tools, but sometimes it is the only way. Glad you got it apart.
ggleavitt
Year and Model: 06,08 XC90 V8
Has thanked: 26 times
Been thanked: 134 times
Post by ggleavitt »
60 Nm or 44 ft lb for the nut per VIDA (see R&R section 76, shock absorber rear replacing).
toolpusher
Thank you!
So it is the strut center shaft. I assumed it is the upper shock mounting.
ggleavitt
Post by ggleavitt »
