Hi Guys.
A little while ago I had asked a question about why my sunroof would no longer open and someone here stated that usually it means that the alarm system has some corrosion of sorts near the plug for the alarm which is located near the passenger side wheel well on my 2002 V70 (P2).
My question is do I need to pick up at a dealer those small press-in type clips that hold the plastic sheet back up into the wheel well
after I disconnect the alarm plug? I have not jacked up the car yet to look at what I need to do. Thx in advance!
Re-attaching wheel well plastic sheet
Mr. Detail
- Year and Model: 2002 V70 N/A
- Has thanked: 158 times
- Been thanked: 6 times
- Has thanked: 1611 times
- Been thanked: 4075 times
Try this part numberMr. Detail wrote: 29 Apr 2021, 08:06 Hi Guys.
8687663
..with my friends Scott and Nick at FCP Euro
These are hard to find on the Volvo webstore - buried in the Mudflaps section.
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 44 times
they come apart in two pieces, the centre pin and the body then you can re use them, just tap/punch out the centre with a nail or punch. Volvo use them in a host of different places, ive got a bag of them i have removed from my junkyard car.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I did remove only the rivets needed - I think 3 -4 of them, and didn't put anything back, it stays well. Otherwise, if you have a junkyard, remove some plastic pins from the cross member above the radiator
Mr. Detail
Thanks much guys! I did not know they could be "re-used".
Mr. Detail
vtl, how do i do that? maybe I can do ti myself. Do I have to remove the actual bumper? I need to get that darn amlarm unplugged so my sunroof will work again. It's getting warmer now.
Mr. Detail
vtl, I can't view those photos or picture snapshots you sent. Just blank.
- 1057 Views
Last post by NotAWrenchTurner
- 1112 Views
- 1675 Views
- 10 Replies
- 2264 Views
Last post by BlackBart
- 583 Views
Last post by wizechatmgr
