850 Suspension spring Front axle
manovlov
Has thanked: 672 times
Been thanked: 163 times
Post by manovlov »
Hy Buddies,
I have to plane to rebuild all my front suspension. But i don't know which spring i should get. On VWSParts, the reference is 354 66 41.
? N° 1 : Which trade do you advice me ? Does the LESJOFORS trade speak to someone ?
? N° 2 : Where does this part goes on, engine bay side, to the top of the "Suspension strut Support Bearing Front axle upper" ?
Capture d’écran 2021-05-02 à 12.02.38.jpg (10.63 KiB) Viewed 1287 times
As i 'm looking for advices, if someone wants to advice me with trade well known and efficients parts, just fill the excel bard following the link.
Many many thanks, Boys !
Manov
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
I have had good luck so far using Lesjofors spring on the rear of my '97 855... I wrote up a short description here:
viewtopic.php?f=1&t=95813&p=560572#p560572
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
This guide is for later models, but the main parts are the same for suspension. viewtopic.php?t=91985
The 1034503 washer goes on top of the foam cushion.
Good luck.
Azik09
Year and Model: S70 T5, 1997
Has thanked: 2 times
Been thanked: 31 times
Post by Azik09 »
I needed to raise front of my car and I installed springs from diesel (used). Here's result:
Picture for question 2, see pos.13
If my English is bad, please correct me :oops:
Been thanked: 4065 times
Azik09 wrote: 02 May 2021, 13:31 I nedded to raise front of my car and I installed springs from diesel (used). Here's result:IMG_20210502_221926.jpg
Those are the nice chiral Columba wheels! ( there are left and right hand versions)
manovlov
Post by manovlov »
Hy Azik09
I need to rebuild my front suspension. The issue with these diesel springs models is that they are too strong, to me, impression the wheels dance on the top of the suspension. To me, defintly not a good idea. Again : to me. And your english ik okay to me.
I have a question guys, i don't understand what these boarded references are for. Which springs shall i order ?
Here is the whole list, board © VOLVO - VPWS
https://www.volvopartswebstore.com/prod ... evel=24662
Manov
850 VPWS ref.png (85.16 KiB) Viewed 1216 times
850oldschool
Year and Model: 1996 850 NA
Been thanked: 45 times
Post by 850oldschool »
I was incredulous when I read this, but yes , it's true! Now that I know these weren't offered in bright silver they'll be easy to spot. I wonder if they are as ductile as the standard ones, or if they took the alloy up a notch.
abscate wrote: 04 May 2021, 04:55
Azik09
Post by Azik09 »
manovlov wrote: The issue with these diesel springs models is that they are too strong, to me, impression the wheels dance on the top of the suspension.
I was afraid these diesel springs will be too hard, but they are not! Much softer than stock lowered T5 springs.
Azik09
Post by Azik09 »
abscate wrote: Those are the nice chiral Columba wheels! ( there are left and right hand versions)
Thank you. And yes, I have 2 pairs:
Sorry for mess in my garage and mud on my car :oops:
