Vibration at idle and acceleration after hitting a deer
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
mrjay62 wrote: 04 May 2021, 22:59 Hi Matthew.
Are you talking about my video of the water bucket of water on the engine? It's exactly the same as vlt's video.
I'll have to figure out how i can set up Dropbox, iCloud,Utube etc.
Not the brightest blub in the box here..
Take video with your phone, hit the share option and it will bring youtube up as one of the options along with tweeter , facebuk, email etc.
mrjay62
Year and Model: V70XC 2002
Been thanked: 3 times
Post by mrjay62 »
Ok, but it's late I'll try it in the morning.
Thank you guys. .
GN
mrjay62
Post by mrjay62 »
Test testing
mrjay62
Post by mrjay62 »
Ok that was easy..
Thank you for your help.
Gn.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Normal 5 cyl noise/vibrations in the video.
mrjay62
Post by mrjay62 »
I think so too
Maybe I'll have to try it in the cabin.
jonesg
Post by jonesg »
mrjay62 wrote: 05 May 2021, 09:09 I think so too
Normal engine vibration but if engine mounts shifted it might be transmitting more vibration than previously into the frame.
If the rear view mirror is blurry I'd change the mounts, if not I'd try ignoring it.
mrjay62
Post by mrjay62 »
I just replaced all the motor mounts and subframe bushings the subframe was skewed about a quarter inch plus but got it centered once all thelse bolts were loosen .
Tomorrow I'm going to try vlt's idea of disconnect the the steering shaft. .
All I can tell you is Before knocking Bambi over the car never felt like this...
My 1st thought was some how the belt jumped a tooth and I was out of timing,or dropped a cylinder... checked sway bar and links nothing touching where it shouldn't bushings are intact. I do have replacement upper strut mounts that's the only other thing I can think that's coming from the subframe to the car body.
Once I figure it out I can get back to work on this POS...and the bike..
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
How is it to own a jaguar?
BMW 540i 2002
S70 Base 2000
mrjay62
Post by mrjay62 »
Hi kallekula.
Good question.
It's been sitting there since February of 2019 it was supposed to be a project for me and my son.
After he passed i couldn't bring myself just junk it. So from time to time I work on it, the engine was in poor shape, I don't think there was a fault code that wasn't thrown. It smoked, ran hot, uneven, almost everything electronic didn't work... Now the engine is running smoothly, Power everything is working, all that's left is a part of the transmission valve body that's cracked.
Looks sharp but not really practical for me. But i cant get rid of it.
Need the part number off the valvebody . To find a replacement or have it welded.
So I guess the answer to your question is -
I don't know. lol
Stock photo
Stock photo
2013-02-10_14-58-28_430_zpsfb0593a1 (1).jpg (309.05 KiB) Viewed 1085 times
