Vida CEM swapping
RickHaleParker
Been thanked: 981 times
Post by RickHaleParker »
vtl wrote: 04 May 2021, 13:39 Do you have a dump?
I don't have the equipment to extract a bin file.
Active
Past
T5Luke
Year and Model: S60 T5 2001
Has thanked: 11 times
Been thanked: 130 times
Post by T5Luke »
The minimum basic arduino or some 5V arduino or some USB TTL is enough for this task...
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
RickHaleParker wrote: 04 May 2021, 14:58 I don't have the equipment to extract a bin file.
You probably do. It only needs a USB-serial converter (the one with RX/TX lines). T5Luke taught me how to read/write Renesas flash with such adapter and m16c-flasher.de software.
vtl
Post by vtl »
RickHaleParker wrote: 04 May 2021, 13:44 What happens if you exclude 00 as a candidate? say measure 01 - 99 rather then 00 - 99.
It always picks 0 even if bytes go down from 99 to 0.
May need to power on the oscilloscope once again.
RickHaleParker
vtl wrote: 04 May 2021, 18:10 You probably do. It only needs a USB-serial converter (the one with RX/TX lines). T5Luke taught me how to read/write Renesas flash with such adapter and m16c-flasher.de software.
I seen that someplace before but never gathered enough information and software to do it.
You assumed correctly, I do have a FTDI USB <=> RS-232 DB9 adapter.
Got a link or a file? ... enlighten me.
Got four platforms to work on. Ubuntu 20.04, Windows 10, OS X Leopard PPC and MorphOS 3.15 .
Found this in a yard sale for $1.00.
Had no use for it at the time but figured I would end up kicking myself in the rear if I did not buy it.
Screenshot from 2021-05-04 19-47-19.png (50.91 KiB) Viewed 1870 times
Active
Past
RickHaleParker
Got the software and the manual but, the manual is mute on how to connect the serial cable to the Microcontroller.
2021-05-04 (1).png (63.98 KiB) Viewed 1867 times
Active
Past
solitaire
Year and Model: v40 2016
Has thanked: 3 times
Been thanked: 6 times
Post by solitaire »
vtl wrote: 03 May 2021, 04:35
solitaire wrote: 03 May 2021, 01:21 Part Number: 30795115
Searching P/N 30795115 in 49 known CEMs
Candidate PIN 94 53 06 -- -- -- : brute forcing bytes 3 to 5 (3 bytes), will take up to 640 seconds
Progress: 0%..5%..10%..15%..20%..25%..30%..35%..40%..45%..50%..55%..60%..65%..70%..75%..80%..85%..90%..95%..
PIN is NOT cracked in 1220.88 seconds
done
Resetting all ECUs.
first two ok, third - no
94 53 85 25 40 55
Thanks. Do you have a dump for that CEM?
ATTACHED
m30855f_30795115_FLASH.rar
(114.75 KiB) Downloaded 177 times
blasaab
Year and Model: Volvo xc90/V50/144
Been thanked: 3 times
Post by blasaab »
Is it possible to read cem with m16c flasher software without pin?
vtl
Post by vtl »
blasaab wrote: 05 May 2021, 08:46 Is it possible to read cem with m16c flasher software without pin?
Yes. Renesas has its own flash access protection countermeasure, but they are not enabled in Volvo CEMs.
blasaab
Post by blasaab »
vtl wrote: 05 May 2021, 08:48
Im not able to crack my pin so looking at other way. I should have m32c in my car. Is there a guide how to connect throu wires in car or on bench
