2000 V70XC Exhaust Manifold Lower support Topic is solved
volvoAgX
Year and Model: 2000, 2006 XC
Has thanked: 15 times
Post by volvoAgX »
While working in the turbo area, I decided to install an R-style exhaust manifold on the car (less prone to cracks I have heard). After removing the old exhaust manifold, though, I noticed that the lower support hardware (shown in parts diagram #7) securing exhaust manifold to block does not line-up with a stud location in the R manifold. Other connection point(s) at the top also don't match. I'm wondering if I can easily make this work, or would a Japanifold be a better fit. The old manifold indeed has some cracks. Thanks.
Exhaust Manifold parts.jpg (83.06 KiB) Viewed 1440 times
manifold compare.jpg (38.78 KiB) Viewed 1440 times
06 XC70, 00 V70XC, 15 Accord V6, 24 4Runner
Been thanked: 4071 times
Would it fit if you moved (7) over to the right bolt hole?
volvoAgX
Post by volvoAgX »
I don't think so, but I'll recheck later.
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
If you have an extra minute, would you mind sending a picture of the manifold you took off, front and back please? I've had credible people tell me that the 2000 XC already comes with the Japanifold. Sorry for the slight-off topic, but I've been trying to figure this out for a while now.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
volvoAgX
Post by volvoAgX »
Exhaust manifold that I took off the car over the weekend, 2000 V70xc
volvoAgX
Post by volvoAgX »
Showing bracket location, original and R manifold.
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
Some folks will tell you swapping from a "Japanifold" to an R manifold isn't really worth it. Claims are the J-fold flows better up top.
volvoAgX
Post by volvoAgX »
A change is motivated by cracks in the manifold (and possible future leaks). Flow improvement is not the driving force.
Are those two compatible with the same head? They look like a completely different manifold, all together.
(WFI)
Chuck W
Post by Chuck W »
Yeah, they both fit the same head.
Replaced a standard manifold with an R version on my '96 recently.
