I am sure Mark will chime in on this, but the way I understand it the driveshaft itself needs rebuilding. I installed a new angle gear and a new viscous coupler on this car and they don't have a ton of miles on them.foggydogg wrote: 02 May 2021, 12:53 What a beauty.
If the driveshaft is just out of the car, sitting in the corner of the garage like mine, maybe you could clarify /
You car is what mine aspire to be. Good luck.
For Sale 1998 V70 XC AWD- Vermont Topic is solved
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- Has thanked: 1611 times
- Been thanked: 4071 times
FWIW. I think it is possible to drop the tank enough to service the pump and sender by just easing the torsion bar part of the suspension without dropping the entire back axle.
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
I've kind of lost track of this particular repair - because I haven't had the misfortune yet - is the other option the panel cutter technique behind the seat ?abscate wrote: 05 May 2021, 17:32 FWIW. I think it is possible to drop the tank enough to service the pump and sender by just easing the torsion bar part of the suspension without dropping the entire back axle.
The car looks like a shiny new penny compared to my fleet, all teetering on the brink of extinction.
markone
- Year and Model: 2007 V70
- Has thanked: 21 times
- Been thanked: 14 times
Both! It is out of the car and sitting in the corner of the garage. It needs to be rebuilt or replaced as the joint in the middle of the two-piece shaft had gotten a little worn.foggydogg wrote: 02 May 2021, 12:53 What a beauty.
2006 V70 NA/manual trans, 165k
2007 V70, NA/manual trans, 143k miles
2023 BMW X1, 29k miles
2018 Jeep Grand Cherokee LTD, 91k miles
2007 Malibu Response LXi, Ebony/white, 340 hp, 395 hours
1997 850 Sedan NA, manual trans, sold at 330k miles
1998 V70, NA/manual trans, sold at 365k miles
markone
I have contemplated the panel-cutter solution. However, I decided to let the new owner decide which route they would prefer to take. Same with the exhaust- there are options, and the new owner will choose how they would like it set up!foggydogg wrote: 06 May 2021, 14:19I've kind of lost track of this particular repair - because I haven't had the misfortune yet - is the other option the panel cutter technique behind the seat ?abscate wrote: 05 May 2021, 17:32 FWIW. I think it is possible to drop the tank enough to service the pump and sender by just easing the torsion bar part of the suspension without dropping the entire back axle.
- foggydogg
My 850 T5 was doing some goofy intermittent stuff, and I had visions of a fuel pump change in my future, but decided to try the relay swap first; been a week in local drives and so far- so good.markone wrote: 13 May 2021, 10:32I have contemplated the panel-cutter solution. However, I decided to let the new owner decide which route they would prefer to take. Same with the exhaust- there are options, and the new owner will choose how they would like it set up!foggydogg wrote: 06 May 2021, 14:19I've kind of lost track of this particular repair - because I haven't had the misfortune yet - is the other option the panel cutter technique behind the seat ?abscate wrote: 05 May 2021, 17:32 FWIW. I think it is possible to drop the tank enough to service the pump and sender by just easing the torsion bar part of the suspension without dropping the entire back axle.
Hope you're getting some real action instead of virtual tire-kickers.
- Has thanked: 2861 times
- Been thanked: 1332 times
https://www.matthewsvolvosite.com/for-s ... d-vermont/ on MVS Home page
markone
Car has been sold to a fine home shop owner, thick with Volvos of his own, as early as '94 and as late as '05. Thank you all for your help!
