Axle play - Normal ?
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
Along with other recent issues, I have noticed a vibration or shake in the steering wheel and front end at 65 - 70mph. It feels like a balance problem so I decided to rotate the tires to see if that made any difference. While doing that, I noticed that if I grab the wheel at top and bottom ( 12 - 6 ), I get some play. Taking the wheel off and looking at the movement, I see the axle shaft moving in and out a little bit ( 1/8"- ). This is on both front wheels. Struts, strut bearings, sway bar end links have been replaced. But nothing else that I can see.
So is that in and out movement of the axle normal ? If not, then what am I looking now ? :(
Just to add - no noises, except when I slowly roll over somewhat large rocks that I sometimes have to deal with on a dirt road. Then I might hear a clunk. But nothing on pavement.
1999 V70 GLT
Has thanked: 1850 times
Been thanked: 1712 times
Let us know if the issue does not resolve with wheel swap around. At that speed it is common for wheel balance issues or bent rims.
Has thanked: 1505 times
Been thanked: 3818 times
Axle play isn’t good. You want those splines bound tightly together or they are going to strip out when you drive.
Check the nut -1998 or the bolt 1999-
Has thanked: 292 times
Been thanked: 765 times
Sveedy wrote: 16 May 2021, 10:40 ... I see the axle shaft moving in and out a little bit ( 1/8"- ). This is on both front wheels. ...
Axle shaft is moving in and out of trans, or movement at the hub like abscate is referring to?
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 337 times
Post by Chuck W »
You will have a little "in/out" (axial) movement of the axle between the CV joints. That's normal. The axle should not move laterally (up/down or side-to-side).
The axle most definitely should NOT move in and out of the hub or transmission.
Sveedy
Post by Sveedy »
I guess I'm not describing it well. Yes, axial play. It looks like the shaft and boot move in and out a little as one, so I don't know if that's just play in the CV joints or something else. I have another long drive tomorrow so I'll see if there is any vibration etc.
Probably just being paranoid..
1999 V70 GLT
Chuck W
Post by Chuck W »
Yeah, the CV joints do have some play in them.
As long as they don't rattle when you try and move the axle up and down or side-to-side, you're probably fine.
Axial play in the CVS isn’t just normal, it’s essential for operation. It can be almost a cm to travel when tugged by hand.
Sveedy
Post by Sveedy »
Much smoother after rotation. Getting close to tire time. About at the wear indicators.
1999 V70 GLT
