Turbo flange and down pipe?
- Gmstewart22
- Year and Model: 2000 v70 GLT, 850-T5
- Has thanked: 11 times
Very enlightening, that answers my question I guess. Sounds like the lpt and hpt have the same flange setup so a T5 downpipe should fit in place of my glt downpipe!
2000 v70 GLT
1997 v70 AWD lpt
1997 v70 AWD lpt "rally rig"
1995 850 T5
1997 v70 AWD lpt
1995 850 T5
- Has thanked: 311 times
- Been thanked: 817 times
Yep, looks like you are talking about a 2000 T5 downpipe (angled flange and downpipe) fits your 2000 GLT's existing flange, yes.
But a 98 T5 downpipe has a straight flange, you would have to grab the flange from the 98 T5 in addition to the 98 downpipe. The straight flange would then bolt right up to your turbo.
Flange to downpipe must match: straight to straight, angled to angled.
Flange to turbo just a V-band, completely interchangeable
Flange to exhaust manifold 4 nuts/studs, completely interchangeable
Redundant I know but hope to be clear.
- Gmstewart22
Thank you all for your help. It's much appreciated!
2000 v70 GLT
1997 v70 AWD lpt
1995 850 T5
1997 v70 AWD lpt
1995 850 T5
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
The exhaust housing is machined with nothing to remove or change about the downpipe fit. It is either cast and then machined with the spherical ground area where the spherical flange on pipe with the floating three fastener retainer ring or it is the cast and machined version with a flat angled larger opening that accepts the fixed downpipe flange.
- Year and Model: Many Volvos
- Been thanked: 76 times
Mine is as Jimmy57 describes. A flat machined surface that is fixed.
- Gmstewart22
Wow, so much info from one one question. I had no idea volvo had so many variations in such short order. Evidently my 95 T-5 is the conical "lame" flange and my 00 glt is angle flange. Sound like the angle flange is the most efficient tho.
2000 v70 GLT
1997 v70 AWD lpt
1995 850 T5
1997 v70 AWD lpt
1995 850 T5
h20ham
- Year and Model: 1998 xc
anyone know the flex pipe lengths, from turbo to cat?
2.5" diameter I suspect. or is 2.75 better? or to be safe...
for a 96 855t
for a 96 855t
68 125 b18 4 speed
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
95 965 T shift controller in progress
05 xc90 rough idle
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
05 xc90 rough idle
- rollinheavy65
- Year and Model: 1997 850 glt
- Has thanked: 2 times
Question regarding this topic, I have a 97 850 GLT, with a motor out of a 98 v70r. So I have the t5r with hpt. Ppl have told me to get the angle flange instead on the straight flange when doing the down pipe. Now are they talking about the down pipe itself being an angle flange, and if so would the work with a straight flange. Or did they mispeak and all down pipes are the same and only turbo outlet is straight, angle, and conical. The reason I'm curious is bc I just purchased a 3 inch exhaust cat back. So I was going to replace the down pipe while I was in there, even possibly the header. Any advice and clarification would be so helpful thank you.
The flange is a separate piece. There are three pieces: turbo, exhaust flange piece connects to turbo, downpipe connects to exhaust flange piece (exhaust manifold does too - so tehnically 4 pieces if you count manifold). See my post above about what has to match and is interchangeable.
- rollinheavy65
Okay that helps there. And I wish I would've seen that above post, sorry about that. But is there any noticable performance benefits switching the exhaust flange piece between straight or angled?
- 14 Views
- 18019 Views
- 5166 Views
Last post by darrylrobert
- 789 Views
Last post by Turbolena
- 2024 Views
Last post by jimmy57
