Rear seat belt electronics?
- cleven
- Year and Model: 2001 V70 T5
- Been thanked: 5 times
My 2001 v70 needs rear seat belts. Can I use some universal belts or does the Volvo have some electronics hooked up to the unit? Its like ZERO volvo's in the junk yards locally .
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
On my 04 v70 I think the rear seat sensor is to detect anyone sitting there.cleven wrote: 20 May 2021, 00:13 My 2001 v70 needs rear seat belts. Can I use some universal belts or does the Volvo have some electronics hooked up to the unit? Its like ZERO volvo's in the junk yards locally .
If it detects a rear passenger it looks for the seatbelt to be buckled.
If it didn't set an SRS light I wouldn't bother, if you need it for inspection I'd just sling an old belt in there and fake it.
I failed on my old volvo 740 because the front belt was removed, so I pulled one from the rear seats and installed that.
they didn't even look at the rear seats.
- Has thanked: 987 times
- Been thanked: 1076 times
On my 2001 V70 T5, the rear seat belts have a electrical connection to the SRS. If the SRS wires are not connected on start, the SRS will set a fault. This particular fault can not be cleared by most code readers.
- jonesg
the sensor would be in the seat cushion.volvolugnut wrote: 20 May 2021, 11:52 On my 2001 V70 T5, the rear seat belts have a electrical connection to the SRS. If the SRS wires are not connected on start, the SRS will set a fault. This particular fault can not be cleared by most code readers.
Tripped it on mine when I did the fuel pump reseal.
- 2269 Views
- 677 Views
Last post by AylmerQc
- 1238 Views
Last post by Cerutti
- 692 Views
Last post by 93Regina
- 18 Replies
- 8578 Views
Last post by BeachWagon
