2000 V70 AWD
recently noticed 1 in. low coolant
After I refilled it to the seam ( new Volvo reservoir) it was 1 inch above the seam when warmed to full heat / temp
block tester does not change from blue to anything indicating no exhaust gasses in coolant
Is this normal for this 56 engine??
2000 V70 AWD 56 engine coolant now 1 in. higher in reservoir
- Has thanked: 2199 times
When you re-fill the radiator from empty, the system often 'burps' a few times as it can trap air. Carry some spare coolant with you for the first few trips and check each time you stop.
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
My coolant level was climbing quite a bit after shutdown. When I tried to lift the rubber washer out of the cap it broke into pieces. A different cap cured the problem.
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
Why did you start a second thread?
Rocket99
- Year and Model: 2000 V70 XC
- Has thanked: 56 times
The topic went from (apparent) coolant leak to apparent excess pressure in the expansion tank.
I happy to hear folks not implying possible head problem.
Still im in a rental now to get to points 8 hr south.
I still have no clear idea how the coolant was suddenly 1 inch higher in the exp. tank... for months it was stable steady at the full level, ie the seam in the exp. tank, then suddenly one inch higher.
- 800artfreed
- Year and Model: 98 S70T5; 99 S70GLt
- Been thanked: 26 times
There is a chemical test kit that allows you to suck vapour from the reservoir into a clear plastic tube. This tube is filled with a small amount of liquid that turns a different color (blue to yellow) in the presence of hydrocarbons (combustion gases). This can help determine if you have a head gasket leak.
VolvoVoyeur
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
- befarrer
- Year and Model: 1998 V70 AWD
- Been thanked: 24 times
Are you comparing cold engine coolant level to hot engine coolant level? If so, that's normal to rise.
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
05 VW Golf TDI
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
Even cold, the level is not consistent. I have owned 3 850s over the last 10 years, and they all do it. No head gasket problems or whatsoever, the level sometimes is just higher or lower.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
Quick math
Expansion bottle is about 10x10 cm, so each cm of change represents 100 cm^3 of volume
Total system volume is 7 liters or 7000 cm^3
so an inch of change is 250 ml or about 3% expansion of fluid volume.
- Has thanked: 987 times
- Been thanked: 1075 times
By my calculations and research, a 50/50 solution of ethylene glycol and water will expand .000392 for each degree F. Assuming temperature increases from 70 to 230 degree F and 7 liters volume, expansion would be .0627 (6.3 percent). About 440 ml expansion of fluid. This assumes engine, radiator and hoses do not expand (but they will).
Any mistakes here are my own dang fault.
- 12 Replies
- 7157 Views
Last post by RickHaleParker
- 1389 Views
Last post by alschnertz
- 3151 Views
Last post by ctrobk
- 61 Replies
- 9047 Views
Last post by jonesg
- 10 Replies
- 506 Views
Last post by BlackBart
