Differential speed sensor needed
Hello,i am in need of a differential mount speed sensor for my 92 Volvo 960 wagon.It looks as if this part has been discontinued by Volvo,that’s what my local Volvo dealer told me and online stores same story.Any help would be much appreciated,thank you
tmcmilli
- Year and Model: 1994 Volvo 960
- Has thanked: 3 times
- Been thanked: 6 times
Here's what I found after digging around a bit. Volvo ABS Speed Sensor (In Differential) part # 1398321
Here's a link to an ad on Amazon when I searched for the part number above, which says it's available. Another site, a Volvo parts supplier, said it was backordered and temporarily unavailable, which to me is different from saying it's unavailable as in discontinued.
https://www.amazon.com/Genuine-1398321- ... B009GD1VKK
If you do a Google search for Volvo 1398321 you can check out some more results yourself, shop around, maybe find a better price, I don't know. One more thing, a Volvo parts supplier, one of those sites that shows detailed drawings for the section of the car where the part is used, says in the details it is "for any 90-93 240, 89-92 700, 940 all, 960 all..." So if you had to go to a junkyard looking for the part, you're not limited just to a 960.
Hope this helps.
Hope this helps.
Hello,I was wondering if anyone had any knowledge that could guide me toward a solution to my shift flare in my car?no check engine lights on,replaced pnp switch(had a code 3-1-3)but I still have a shift flare(gears 2-3)only when trans is up to operating temp,also accompanied by vibrating on acceleration from a stop.any help would be much appreciated!
