This is the Banjo from my 2002 2.5ltr XC70 (part number i think is 8653884) it has a very small diameter hole that i can pass wire though. There is no ball bearing/slug or anything that can come loose and destroy your engine. It has 01-02 stamped on the head. I believe Volvo fitted defective bolts to 2004-05 vehicles
Here is a picture of a failed Banjo bolt, third bolt in the pic where the pin has dislodged and ruined the engine. This is the part number 31325709 for the 2014 improved version.
If you have the version without a check valve there is a risk of blowing oil seals/gaskets under turbo boost.
Check your Banjo PCV bolt
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 44 times
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
To find the resource to investigate this do I just look in the main PCV replacement instructions? Or is there a guide for this particular part (don't have a need to do full PCV service atm)
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- firstv70volvo
- Year and Model: V70 T5 2001
- Has thanked: 52 times
- Been thanked: 123 times
I've replaced the banjo bolt with the latest design and it's supposed to have 2014 stamped on the head of the bolt. Today I attempted to see if I could view the head of the bolt with it installed in the manifold (my car). I used a small inspection mirror and a bright shop light but I couldn't make out the 2014 marking on the head of the bolt and I don't recall if the bolt had the 2014 marking. The space is very tight between the bolt head and alternator. This would be the only way I know of to verify if you have the latest bolt design when it's already installed.br0dy519 wrote: 07 Jun 2021, 11:19 To find the resource to investigate this do I just look in the main PCV replacement instructions? Or is there a guide for this particular part (don't have a need to do full PCV service atm)
https://www.fcpeuro.com/products/volvo- ... oup%20%231
- darylrobert
yes it should have 2014, you might need to remove the steering pump to even view it with a mirror.
- gnalan
- Year and Model: 2001 S60
- Has thanked: 557 times
- Been thanked: 135 times
I don't remember seeing a banjo bolt when I redid my PCV system with all new parts. Is this only on particular models? I have a 2001 S60 non-turbo. If it's on all of them could you post a pic of where the bango bolt is located so I can check mine?
- Been thanked: 4068 times
It lives under the intake manifold on the right, passenger side. You might not have it on an NA in 2001.
It looks like yours vents to a small hose without it.
- gnalan
The only bolts on mine were to hold the PCV box onto the block, and all of the hoses attached with new Oetiker clamps that I bought; I'm not a huge fan of worn clamps. My power steering line was leaking at the reservoir, and where it attaches to the pump, so I cut the bad ends off and installed Oetiker clamps. I haven't had a single drop leak since. (Sorry for going off topic.)abscate wrote: 08 Jun 2021, 11:24 It lives under the intake manifold on the right, passenger side. You might not have it on an NA in 2001.
Any post with either an Oxford comma, an Oetiker clamp, or a semicolon is on-topic in all Fora or sub-Fora; Extra points are awarded for all three.
- DonnVa
- Year and Model: 2005 XC70
- Has thanked: 21 times
- Been thanked: 61 times
I wanted to follow up here as well regarding the banjo bolt. Mine was the old style when I did my PCV job last summer. I cleaned it out with carb cleaner and didn’t think twice until I saw what it could potentially do if the pin and ball came out. I was already getting prepared to replace my alternator pulley so I ordered the new style. Mine came with a 2020 stamp on it, so don’t get caught up thinking it has to have a 2014. It was easy to access with my alternator dismounted and moved to the side. Here are a couple pics.
Off topic edit. Screw those oetiker “bust your knuckles break something else” clamps. Lol On things that I will be going in again for routine maintenance I replace them with regular ones as long as the pig tails won’t rub on something else. I will put them back on things that I probably won’t touch for a while or are necessary like CV boots.
2005 XC70 Cross Country 2.5T 185k miles
1962 122s 4dr 100k+ TMU
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
30 + other cars and trucks
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
Rvolvos
- Year and Model: 2006 xc70
- Has thanked: 73 times
- Been thanked: 23 times
Did check the banjo bolt on our V70 today, pcv was serviced by the dealer with previous owner.
Used a mirror, a bright light and my phone to make a picture of the mirror, so that I could zoom in.
Luckily it is the later style marked with 2014.
2006 XC70 2.5T 238k
2012 S60T6 95k rip
2011 C30 T5 M66 105k Totalled RIP
2006 V70 2.5T 184k RIP
2011 C30 T5 AW55-50SN 99k sold
2012 S60T6 95k rip
