Coolant flow path diagram Topic is solved
Gmstewart22
Year and Model: 2000 v70 GLT, 850-T5
Has thanked: 11 times
Post by Gmstewart22 »
Does anyone have a coolant flow path diagram for me to reference my 2000 v70 glt is having some issues and need to trace some things down.. or can someone tell me if the water pump fills off the top or bottom hose of the radiator and I can figure it out that way.
Thanks all!
Couldn't find anything in a search.
2000 v70 GLT
1997 v70 AWD lpt
1997 v70 AWD lpt "rally rig"
1995 850 T5
Been thanked: 4071 times
Hot water goes into the top of the radiator and cooled water exits at bottom
The water pump is pulling water from the block though, mostly.
Gmstewart22
Got it,thanks
2000 v70 GLT
1997 v70 AWD lpt
1995 850 T5
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
jawsell
Year and Model: 2000 V70R
Post by jawsell »
Does anyone know what the part number is for the coolant hose on the engine block near the heater hoses? It's a U shaped hose that just goes in and out of the block above the transmission. It's 2000 V70R with B5244T2. Thanks it's been impossible to find
jawsell wrote: 09 Mar 2020, 12:18 Does anyone know what the part number is for the coolant hose on the engine block near the heater hoses? It's a U shaped hose that just goes in and out of the block above the transmission. It's 2000 V70R with B5244T2. Thanks it's been impossible to find
Go here
https://www.volvopartswebstore.com/show ... evel=24667
to find this picture, and the parts and numbers listing
Screen Shot 2020-03-09 at 2.52.17 PM.png (198.5 KiB) Viewed 26690 times
jawsell
Post by jawsell »
Ok thank you, I still don't see it though. I don't know why this hose is so difficult to find!
Take a picture if it and post. I’m beginning to smell a rat.
YV1LW
Year and Model: 98V70r
Has thanked: 15 times
Been thanked: 4 times
Post by YV1LW »
Have a do88 hose kit 24R (think the “R” means red) that is noted as “Turbo Coolant Hose Kit”.
Of the hoses i have found a home for the outlet line (short straight piece of hose on coolant tank side of engine) but I’m not having success finding the inlet side. Is it buried beneath the turbo inlet pipe (the pipe with the MAF box)?
Also, how do I separate the MAF from the inlet pipe? The clamp is removed but cant seem to pull the MAF out. Is it designed to be separated?
Thanks for all replies😀
Reference vehicle: 2005 V70R w/ AW55-51SN
YV1LW
Post by YV1LW »
No home for this hose
The hose with no home
