Vida CEM swapping
RickHaleParker
Been thanked: 958 times
Re: Vida CEM swapping
Post by RickHaleParker »
PowerMatz wrote: 09 Jun 2021, 10:43 Hi, here is a new part number:
You are misinterpreting the output. The software found 30786579 in the database. 30786579 is a known CEM.
If a CEM part number is not found in the database the software will output " "Unknown CEM part number XXXXXXXX. Don't know what to do".
RickHaleParker
PowerMatz wrote: 09 Jun 2021, 14:21 OK, will try tomorrow and send full log. Thanks!
If it still fails try changing the following in the code. You will find it near the top of the code.
#define SAMPLES 30 /* number of samples per sequence, more is better (up to 100) */
#define SAMPLES 100 /* number of samples per sequence, more is better (up to 100) */
SAMPLES 100 will take longer but it might get the PIN.
More SAMPLES is slower but more reliable. Fewer SAMPLES is faster but less reliable.
ricked
Year and Model: xc90
Has thanked: 6 times
Post by ricked »
im not sure this was asked before but are P3 CEMS supported in the future, i did try 2 of them but i get unknown CEM and script stops
Slav000
Year and Model: 2006 XC90
Post by Slav000 »
I think the task was not to crack CEM on the P3 platform. The D5T5 VDASH program makes the crack CEM of the P3 platform in a reasonable time.
RickHaleParker
ricked wrote: 10 Jun 2021, 04:11 im not sure this was asked before but are P3 CEMS supported in the future, i did try 2 of them but i get unknown CEM and script stops
P1, P2 CEM-L and P2 CEM-H are supported. P2 CEM-B and P3 are not supported.
The side attack used on the P1, P2 CEM-L and P2 CEM-H does not work on the P2 CEM-B.
P3 is a dynamic "PIN". If somebody can get the algorithm for solving the P3 "PIN" challenge and a algorithm for ferreting out the private key ... P3 could be added. Completely different security than the supported CEMS.
RickHaleParker
RickHaleParker wrote: 10 Jun 2021, 02:03 If a CEM part number is not found in the database the software will output " "Unknown CEM part number XXXXXXXX. Don't know what to do".
Perhaps that should be extended to: "Unknown CEM part number XXXXXXXX. Don't know what to do. Report part number and CEM type to the developers or call Junior Samples at BR-549. "
ricked
Post by ricked »
ok thanks @RickHaleParker, for infos, in my case all pin extractions are 35 minutes, as for cem-l/h and the p1 cem
running i7 with 64gb of ram win 10 64x
RickHaleParker
VTL it looks like there are only four P3-CEM part numbers. Which could be add to the database.
Then if a unsupported P2-CEM-B or P3-CEM is detected. Could output "XXX not supported"
Leave code for unknown CEMs there might be some out there I have not found.
P3 CEM part numbers:
30765624
30686819
31327994
31412971
PowerMatz
Year and Model: 2009 XC 90 3.2l AWD
Post by PowerMatz »
RickHaleParker wrote: 10 Jun 2021, 02:16
In my code it is already set to 100.
Here are the two log files I grabbed today
Archiv.zip
Two logfiles of failed crack
(19.63 KiB) Downloaded 135 times
First attempt was directly after stopping the engine and put the key in position 0
Second attempt was after quite a while. Key was in position 0 all the time. The engine was not started.
Matthias
ricked
Post by ricked »
RickHaleParker wrote: 10 Jun 2021, 21:27 VTL it looks like there are only four P3-CEM part numbers. Which could be add to the database.
30765624
30686819
31327994
31412971
30686819 does not exist
