I am not seeing how the pivoting part fits into the a-post bracket.
When I try to mate the two parts it does not appear as though the door will open.
Additionally, what is the bolt size for the pivoting part and what is the size of the nylock nuts for the bracket exiting the door?
I cannot source the rubber cover as on the ps door.
Thanks,
Tommy
ds door stop
- Has thanked: 312 times
- Been thanked: 818 times
Just to be sure: are you certain that's the correct part number for that side of the car? And it's not upside down?
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
That one is either the wrong side, or upside down.
It says "FR" on top. Does it say "FL" on the other side?
tommylg
- Year and Model: 1998 s70 glt
- Been thanked: 3 times
Well, well, well, it says in a serious monotone, FR. So, that is the issue. I do not have to look at the PS or FR side as everything works properly.
Anybody know where I can source a fine used one w/the rubber sleeve?
Thanks much, Tommy
Thanks much, Tommy
- Has thanked: 1613 times
- Been thanked: 4078 times
The passenger side ones come from France, the driver side from Florida
I can pull a Driver side one from my Miami parts car and send to you. If bread is tight, we can do it on the FDPP,
- Chuck W
I meant, does it say "FL" on the other side of that arm? Some of the available parts are sold as reversible and fitting both sides, and are stamped which way to install them.tommylg wrote: 10 Jun 2021, 16:56 Well, well, well, it says in a serious monotone, FR. So, that is the issue. I do not have to look at the PS or FR side as everything works properly.
Thanks much, Tommy
That being said, those parts aren't perfect fits, as the S/V/X (98-00) are the ones that truly use the same part, just flipped over. The 850 parts is an mirror images. Some suppliers are spec-ing the 98-00 ones for 850's, but they're not exact fits.
The difference is that large oval spring. It isn't centered on the mount and over-hangs one edge more than the other.
It's not an issue on the 98-00 cars, but on the 850s, it can rub a bit on the door wiring harness bundle, even though the bracket itself bolts in and works just fine.
tommylg
Chuck, I mis-read your post and thought the "other side" meant the passenger side.
With that said and a look see, there are no markings on the other side.
So, now where do I stand?
abscate, when I am absolutley sure, I will take the hinge, cash flow good.
Thanks guys,
Tomm
Thanks guys,
Tomm
- Chuck W
If abscate has the proper part, then that would be ideal. The one you have will "work", but with the issue I mentioned above.
Will the spring rubbing on the wire harness cause issues? Maybe, maybe not.
- 5143 Views
Last post by Amk20155
- 409 Views
Last post by cn90
- 257 Views
Last post by volvolugnut
- 1436 Views
Last post by schoen951
- 1144 Views
Last post by Volvo S80
