iCarSoft i906 reader sometimes doesn’t connect
jkatz
Year and Model: 2007 XC70 2.5T
Has thanked: 2 times
Been thanked: 6 times
Post by jkatz »
I recently bought the iCarSoft i906 reader for my new-to-me XC70 (2007, 171k mi) and initially it was great, hours of entertainment scanning the many codes in all the modules. But sometimes I plug it in and turn the key to II and immediately the brake failure message appears and the shift interlock solenoid starts jackhammering open and closed, even with my foot off the brake. When this happens the reader won’t connect to the vehicle and no amount of turning the car off an on or unplugging the reader will restore it.
Has anyone else seen this? Is it an issue with my car, or the iCarSoft reader? I have read the codes in my other car, a v70 (na, 2003, 169k mi) but there were so few codes - it is such a great car compared to the XC70 - that I didn’t need to read them more than once, and it just worked the first time.
2007 XC70 174k mi
2003 V70 NA ('gifted' to family)
[[ 8 years of Toyota ownership ]]
1984 245 B21FT (sold, 250k mi)
1980 245 B19 (scrapped, 450k mi)
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
Its failing to establish communication if it works with the other car. possible port problem.
Beyond elec spray cleaner on the socket under the dash I wouldn't know, maybe video it on your phone and put it on youtube, lots of information there.
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 6 times
Been thanked: 44 times
Post by darylrobert »
i have the same scanner and have never had any issues with it, just make sure the plug it fitted squarely, i have some problems like this with the VIDA dice, but not the icarsoft.
jonesg
Post by jonesg »
Plenty of people have issues of no power at the socket,
A blown cig lighter fuse can stop the power feed to the socket.
Make sure theres nothing plugged into the lighter, such as GPS or phone charger.
jkatz
Post by jkatz »
Thanks for all the replies. I didn’t realize no power at the socket is an occasional issue. Mine is an intermittent issue, where sometimes it will work several times in a row, and sometimes I have to just give up and try again later. If I can get it to work and even stream data it will often lose connection during the test drive, which is a small hassle.
Interesting about the link to the cig lighter socket. The fuse looks good, but the previous owner installed some kind of FM phone transmitter behind the radio that I will need to pull the waterfall to remove. I assume they tapped into the cigarette lighter power, but I have not checked. I guess I will get rid of it and see if it helps.
2007 XC70 174k mi
Markus
Year and Model: V70 D5 MY2007
Post by Markus »
I had a similar issue with my iCarsoft Vol2 reader after 6 months of usage.
In my case is the SD card inside was gone. New SD card with the software flashed and works perfect now for years.
regards Markus
cleven
Year and Model: 2001 V70 T5
Been thanked: 5 times
Post by cleven »
Has anyone ever done a T/B recalibrate with a icarsoft yet?
jkatz
Post by jkatz »
I’ve never done anything but read DTCs and stream live data. Actually I don’t think my model can do anything more than that.
2007 XC70 174k mi
jonesg
Post by jonesg »
jkatz wrote: 05 Mar 2021, 09:20 Thanks for all the replies. I didn’t realize no power at the socket is an occasional issue. Mine is an intermittent issue, where sometimes it will work several times in a row, and sometimes I have to just give up and try again later. If I can get it to work and even stream data it will often lose connection during the test drive, which is a small hassle.
disconnect battery first or you might get SRS to add to the woes.
jkatz
Post by jkatz »
Can’t the i906 clear the SRS light? If it doesn’t do that I feel a little underwhelmed by it’s capabilities, I should have bought the Vol2 or Vol3 for not much more money.
2007 XC70 174k mi
