Vida CEM swapping
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
PowerMatz wrote: 15 Jun 2021, 05:39 I use the Waveshare CAN interfaces and cut the resistors for termination. Please see my photos. Should I try some other CAN interface?
1. Breadboard: An experimental model, especially of an electric circuit; a prototype.
Etymology Breadboard ( electronics ): The original electronics breadboards where literally a board to slice bread on with nails as terminals and copper wires as pathways.
2. Yours is soldered breadboard. Two steps up from solderless breadboard. The other is wire wrap breadboard.
3. What are you using for the power source? Insignificant power could be a problem.
4. Use some CAN twisted pairs between the CAN transceivers and the OBD2 connector. A twisted pair reduces electromagnetic radiation from the pair and crosstalk between neighboring pairs and improves rejection of external electromagnetic interference. In other words a twisted pair is quite compared to a untwisted pair. The wire size and twist rate needs to be balanced for optimal performance. Go get some CAN twisted pairs out of a junk car and be done with it. ( The Orange - Orange/White and Gray - Gray/White in my picture. )
5. Shorting the wires between the MCU and CAN transceivers may help. They are laying on top of each other and maybe picking up too much crosstalk. You can run some of the wires on the underside of the board and reduce the size of the hornets' nest.
If Twisted pairs and cleaning up the hornets' nest. is not a cure. Move on to the CAN transceivers.
7. Problems have been reported with the 3.3V Chinese knock off chips. If it where mine I would switch to some good 5V CAN transceivers. You tried everything else, might as well exhaust the last remaining hardware possibility.
Active
Past
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
12v->5v DC-DC is strongly recommended.
RickHaleParker
vtl wrote: 15 Jun 2021, 06:22 12v->5v DC-DC is strongly recommended.
I got away with using the 5V USB from the Teensy 4.0 but if the CAN Transceivers are power hungry that might not do. Also not all USB ports have the same power capacity. That could be an issue.
Active
Past
vtl
Post by vtl »
RickHaleParker wrote: 15 Jun 2021, 06:43
A few folks here reported they started to hit the pin reliably once they had the power switched from USB to DC-DC.
RickHaleParker
vtl wrote: 15 Jun 2021, 07:26 A few folks here reported they started to hit the pin reliably once they had the power switched from USB to DC-DC.
In addition to the power requirements of the CAN transceivers, noise on the USB 5V line could be a problem. If the PC's USB port is loose it could be a source of noise interference and/or reduced power capacity. The 5V source should be a well filtered source.
Active
Past
mikeak2001
Year and Model: S70 1998 T5
Been thanked: 37 times
Post by mikeak2001 »
vtl wrote: 14 Jun 2021, 14:48
PowerMatz wrote: 14 Jun 2021, 14:04 Has anyone another clue for me now? I don't know what to do next because I tried all,
From your Archiv.zip...
First log:
Code: Select all
11:14:01.522 -> 1000 pins in 573 ms, 1745 pins/s, average response: 20 us, histogram 10 to 30 us
20 us is too low, something is not right. Won't work.
Is it possible for anyone testing this on P1 Cems to list the power and ground connections that they are using on this CEM. I have mine powered up and teensy trying to crack. However I never get any success.
I constantly get a latency of around 15us so it calculates different pins each time its run.
Is there anything particular to look out for when the latency is so low?
I have checked my setup with oscilloscopes etc, I have no noise/crosstalk etc. It communicates but never cracks the code.
--EDIT--
Thought I'd add a picture of where I'm at with this project. 3D printed case still to be made.
Labels on the board are for my reference.
Headers were added for all testing purposes, especially for the tft touch screen.
vtl
Post by vtl »
mikeak2001 wrote: 15 Jun 2021, 16:09 Is it possible for anyone testing this on P1 Cems to list the power and ground connections that they are using on this CEM. I have mine powered up and teensy trying to crack. However I never get any success.
P/N 31254903
ricked
Year and Model: xc90
Has thanked: 6 times
Post by ricked »
vtl wrote: 15 Jun 2021, 17:47
P/N 31254903
use this connection and it will work, i did read 4 of them now, also i see cem-h/l on you bench this needs only 4 connections to read it
RickHaleParker
datatransferring.com wrote: "ATTENTION! You cannot swap CEM - L to CEM - H, However, you can use CEM - H instead of CEM - L.
Also, You cannot swap a CEM, each has the Serial number before 0000491..... instead CEM each has the Serial number start from 0000491..... and higher."
Yagger what is different about serial numbers 0000000 - 0000491?
Active
Past
konielian
Year and Model: 2010 C70, 2019 XC60
Post by konielian »
Hello, i followed the instructions and build the board as attached but i tried several times on P1 and P2 and have the same error.
Car key postion 0 on P2 when i tried, and on P1 i tried on postion 2.
I also tried with 100, 60 and 30 samples on P2 but still no results. Please help
