Radiator cooler o-ring 988840
- Has thanked: 987 times
- Been thanked: 1075 times
Is this the trans cooler or what connection?
- Has thanked: 2200 times
I would love to help and there is a chance I might even find one for you, but like you I have no idea what size they are. Do you have the single or double 'O' ring type? I know I have engine oil cooler pipes in the garage and I believe they are the same size. I think those are the 2 ring type but subject to confirmation. Been a long time since I had 98 P80.
Would this be the same as P2? Does anyone know? If same as P2, I think I can get measured.
If I recall a 98 uses a different set up to 99 and on. Hence my request for clarification. I know I can find a part number but that unfortunately does not give the 'O' -ring specs.
Try the master oring size thread in this forum
viewtopic.php?f=1&t=88579
988840
It’s showing as 15.5 mm x 2 mm there
Hmmmm…skandix has a different size.
988840
Ah, measured in the ACsystem, on right , mid page
Measurements are OD and thickness
- 2104 Views
Last post by fitz548
- 1154 Views
Last post by volvodork
- 1415 Views
Last post by volvolugnut
- 661 Views
Last post by mecheng
- 1676 Views
Last post by erikv11
