2004 Xc70 cross county
My volvo seems to do this only when its very hot outside .105 last time today it was 110. .my volvo makes a thump under the car sounds like the tranny ..then shuts off ..then comes back on again..but instead of having everything working normal .i have no lites no power .windows etc.and it runs like its running on only a few cylinders weak.. Someone told me it was limp mode .anyway it got me home .it flickers back and forth.but everytime it does it makes a big thump. Does anbody know what the problem is.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
make sure the cooling fan is working in the computer box next to the steering fluid reservoir.
Air is supplied from the cabin so it helps to have the A/C turned on to cool the computer.
motormikeyman
- Year and Model: 2004 XC70 AWD
- Been thanked: 8 times
You are probably experiencing a heat related CEM failure. You may hear relays on it clicking when this failure occurs, it is under the dash above your left foot. Clunk in trans feels like you are running over a brick, transmission goes into limp home mode, stalls- no start condition, no tach or speedo, ABS failure warning, no sunroof or power windows, no AC. Xemodex has a good diagnostic procedures for this issue on their website.
'94 940 wagon, 220K miles- sold to a guy who then drove it to Oklahoma
'99 XC70 AWD, 210K miles- trans went
'04 XC70 AWD, 196K miles- still going strong
'06 S40 sedan, 150K miles- went with the ex
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Second the CEM failure, but first measure your battery and check all connections. You can look at the CEM with a flash light from under the dash for dry traces of leaks, or remove for further inspection if you can lift the wiper arms
- Has thanked: 1611 times
- Been thanked: 4074 times
Ten 2004 was known for a heat soak problem in the CEM. Thread maybe 2 years back?
