98 V70 Hissing PTC
Has thanked: 292 times
Been thanked: 765 times
98 V70 Hissing PTC
There has been a pretty loud hiss in the engine bay, today I tracked it down and it is coming from inside the PTC. If I kink the line from the intake manifold nipple to the PTC, the hiss stops. No leaks in that line itself. The hiss also diminishes (goes away?) if I rev the engine. I know the PTC is wide open if you are looking in from the top (through the larger opening). And pulling that big line off doesn't change the hiss.
Is this normal or do I need to fix something? I thought it was a vacuum leak by the sound of it, and I feel like there is a small one somewhere but I can't find one. My R doesn't make this sound.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
tdlund
Year and Model:
Post by tdlund »
I was just working in that area of my 98 V70 today and didn't hear any hissing from the ptc nipple. I wouldn't think that the pcv system could give enough pressure to make that kind of sound. Just my thoughts.
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
So that's what it is! Mine hissed for a over a year but I did not attributed to the PTC. I discovered that it was not pressed fully into the Intake Tube when I was working on the Heater Core. Now that you mentioned it I've never heard the hiss after the Heater Core work. Always thought it was a huge Vaccum leak but the car ran ok.
Well I removed the PTC and inspected it, it was installed correctly and totally clean.
So I grabbed a spare PTC and fresh air hose, again totally clean and properly assembled, and installed that. It has the same hiss, it is due to vacuum from that line from the intake manifold.
Maybe the hiss has to do with the diameter of the hose I used or something? I will leave it as is for now, at least I know what is going on now. At some point I will compare it with the vacuum pull that hose has on my R.
'06 S60 R, 197k
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
I take it you don't have the normal Volvo oil trap to PTC hose in place there?
'98 S70 T5
2016 Chevy Cruze Premier
Correct, I have DIY vacuum line in there.
'06 S60 R, 197k
BatStig
Year and Model: 1997 850 GLT
Has thanked: 7 times
Post by BatStig »
erikv11 wrote: 10 Mar 2014, 10:08 Correct, I have DIY vacuum line in there.
Sorry to bring this thread back from the grave, but this is the only post I have found on the internet about this. My 850 is doing the exact same thing immediately after installing my own larger DIY vacuum line.
What was the outcome? Is it simply the larger vacuum hose causing this? I have smoke-tested the system and can't find any leaks.
I've still got the car, it has 65,000 more miles on it now, it still has the hiss and it still runs great. I just never messed with it any further.
'06 S60 R, 197k
Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
After upgrading to a bigger hose I got that hissing sound as well. 4 years later it still hisses, runs great and passes the glove test.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Has thanked: 1497 times
Been thanked: 3810 times
Good luck vs UKR today , Clemens. A victory will be celebrated with Kangaroo steaks on the Barbie
