02 v70xc new fuel pump wont shut down even after battery disconnect! Topic is solved
jking4020
- Year and Model: 1997 850, 2001 v70xc
- Been thanked: 3 times
Yes I put a new Bosch fuel pump in my V70 XC wagon all wheel drive 2.4 l turbo and the fuel pump runs and drains my battery when I turn the car off. I unhooked the negative terminal on the battery and the damn thing still keeps running. I've done a few trial and errors disconnecting the fuel pump fuse on the side of the dash board driver side. And that seems to do the trick. What the hell is with new fuel pumps not wanting to turn off? Has anyone had this issue?
- Been thanked: 4064 times
Break out the popcorn for this oneI unhooked the negative terminal on the battery and the damn thing still keeps running.
- Has thanked: 987 times
- Been thanked: 1075 times
Perpetual motion discovered at last!
jking4020
I mean the fuel pump keeps pumping fuel when I disconnected the battery. No codes. No bad fuses or relays. New fuel pump and it does not want to turn off. Has Bosch been known to be defective?
jking4020
One thing to add. The fuel pump would not stop until I disconnected the sending unit. I'm at least 90% sure I plugged everything in correctly when I was installing the pump. Any ideas from anyone?
OK, Seriously. The fuel pump is running after you disconnect the battery power? Disconnected battery negative only or negative and positive at battery? Or disconnected power at fuel pump? Are you certain if fuel pump wire connections are correct?
Sorry to be a wise guy.
jking4020
Yes! I turned the car off and the fuel pump was still running. I had the seats up still and I could see the pump and still hear it running. I disconnected the negative terminal on the battery thinking it would solve the issue but the thing still ran. So I took the passenger seat up and disconnected the sender unit and that's when it stopped finally. F#$+ing gremlins! I can't afford a new car this is seriously weird!volvolugnut wrote: 22 Jun 2021, 18:47 OK, Seriously. The fuel pump is running after you disconnect the battery power? Disconnected battery negative only or negative and positive at battery? Or disconnected power at fuel pump? Are you certain if fuel pump wire connections are correct?
jking4020
Then I took out the sender unit and switched the two plugins that are identical to see if that may have been a problem. I have no fuel pump sound of operation now and no start issue. No pressure at the fuel rail. No fuses or relays are bad.
- 2158 Views
Last post by BEJinFbk
- 1971 Views
Last post by darylrobert
- 13 Replies
- 3297 Views
Last post by oragex
- 675 Views
Last post by DGM
- 342 Views
