Vida CEM swapping
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Maybe talk to @sparacis, he was able to crack his C30 in-car. User sirloins on swedespeed is who contributed the initial P1 code.
I have an older P1 CEM that cracks reliably with my bench setup.
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
vtl wrote: 23 Jun 2021, 14:46 That 4159840203 is weird
Consistent 137 @ 31 us ?
Active
Past
konielian
Year and Model: 2010 C70, 2019 XC60
Post by konielian »
I am not sure what to do
RickHaleParker
konielian wrote: 23 Jun 2021, 16:17 I am not sure what to do
Clean up the hornet's nest of wiring. Lay it out nice and neat with shorter wires. This is a timing attack.
Wiring every which way produces magnetic fields every which way. That where you can get excessive cross talk.
You can try switching to 5V CAN transceivers. If it still does not work try powering the 5V CAN transceivers from a 5V supply other the the Teensy 4.0 . Like a 2 Amp USB adapter that plugs into the 12V auxiliary power outlet.
I noticed you are using Perforated hardboard. If you flip the CAN-LS upside down on the header pins. You can place both CAN transceivers right next to the Teensy 4.0 then connect the CTX and CRX lines with a short and straight 2 - 4 mm jumpers.
Active
Past
ricked
Year and Model: xc90
Has thanked: 6 times
Post by ricked »
konielian wrote: 22 Jun 2021, 18:36 Hello, i followed the instructions and build the board as attached but i tried several times on P1 and P2 and have the same error.
Car key postion 0 on P2 when i tried, and on P1 i tried on postion 2.
I also tried with 100, 60 and 30 samples on P2 but still no results. Please help
first thing i did is buy original CAN ic's and replace them on blue boards and indeed add 12v power suply( i do it on bench)
RickHaleParker
ricked wrote: 24 Jun 2021, 04:07 first thing i did is buy original CAN ic's and replace them on blue boards and indeed add 12v power suply( i do it on bench)
You swapped out the ics with what?
Active
Past
ricked
Post by ricked »
RickHaleParker wrote: 24 Jun 2021, 08:23
with the original ones, on the china 1 usd board are 1000% fake ones, orginal its a SN65HVD230DR
https://nl.mouser.com/ProductDetail/Tex ... 65HVD230DR?
most of fakes cant send or cant receive so before you even start pulling pin from cem you have errors....
the ori one is 2.80 usd also i do ECU repairs and i know a fake IC when i see it
RickHaleParker
ricked wrote: 26 Jun 2021, 12:33 with the original ones, on the china 1 usd board are 1000% fake ones, orginal its a SN65HVD230DR
Original is kind of vague. One could say the counterfeit ic is the original for that PCB.
You replaced a counterfeit with a genuine Texas Instruments SN65HVD230DR. Put that way it is clear as a bell what you did.
Active
Past
ricked
Post by ricked »
RickHaleParker wrote: 26 Jun 2021, 14:40
i did say "with the original ones, on the china 1 usd board are 1000% fake ones, orginal its a SN65HVD230DR " so im not sure what you dont understand about that... even incude the link to it
RickHaleParker
ricked wrote: 27 Jun 2021, 05:43 " so im not sure what you dont understand about that... even incude the link to it
My bad your understanding of the English language is so perfect. :roll:
Active
Past
