Turbo removel neccessary for Manifold and Flange Replacement?
Turbolena
Year and Model: 850 Turbo Wagon 1994
Has thanked: 2 times
Post by Turbolena »
Hi There,
I searched all the multiple postings on this topic. And while other's posited the question there was not a conclusive answer when dealing with just exhaust manifold and flange replacement.
Does the Turbo needed to be removed for Manifold and Flange Replacement?
I have gotten enough loosened up without much movement of the exhaust manifold that I am speculating that it does need to be removed. maybe I just need to pound the manifold off? I did try some prying and blows and it moved a little with all the studs out, but it still seemed stuck via the turbo to flange connection- which I did loosen the clamp for.
Thanks ahead of time for some insights.
1994 850 Turbo Wagon
2006 V70R
Has thanked: 1502 times
Been thanked: 3817 times
On my 1999 T5 HPT it was necessary
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
I just replaced my exhaust manifold a couple of weeks ago. I didn't need to remove the turbo.
Loosen the three bolts on the down pipe, then the four holding the turbo to the flange. Then pull the down pipe toward the passenger side and separate the turbo from the flange. I had to use a piece of wood as a wedge to hold the turbo away from the manifold and then finagle the manifold out.
1999 V70 GLT
