Broken fuel line clip to fuel filter Topic is solved
jonslave
Year and Model: 1997 855R
Has thanked: 12 times
Re: Broken fuel line clip to fuel filter
Post by jonslave »
This worked a treat so far. I bought another dorman 5/16 press fit and ford 5/16 line and might do the other side of filter (filter to engine) or maybe just keep as a backup....
Has thanked: 1506 times
Been thanked: 3822 times
Bump topic for reference
I ended up adding a zip tie to ensure this fitting stayed on, and thus adding a 6 month inspection protocol and a spare zip tie to the road kit for this car.
The difference in these two fuel filter snouts is important. The Dorman part will lock onto the flange on the top one but not on the bottom one which is OE
TheLazyCarnivore
Year and Model: 2013 XC90
Post by TheLazyCarnivore »
Ok...so my vehicle had the same issue. The clip died, gas spewed out of the pipe (as it wouldn't lock on anymore) and I was getting so annoyed as you cannot buy replacement clips from volvo...but have to buy the entire poxy pipe that is a ballache to put in. So I went online (temu) and they actually sell the clip (in the housing). You squeeze and pull it out (just like you do the fudged one), thread it through and hey presto....works a treat. I spent $3 on something which saved me spending $70. :D
AAXC70
Year and Model: 2011 XC70
Post by AAXC70 »
Can you please post a link to the part?
