br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
Replaced vacuum pump and MAF on wife’s car today. Still chasing an engine hesitation issue.
Also burped and bled air from PS pump today after pressure hose and t. Stat replacement on my car last week.
04s60 2.4
04xc70 2.5t
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Generic info:
The inner CV boot on our P1 had finally split in half. Was leaking and splitting for a couple of years. Used the following to keep it going till we can replace it. Still holding up after 6 months axle not clicking.
Zip tie for clamp. For the broken boot we used double sided stick-to-itself harness tape and it is still holding up. Cleaned grease and wrapped around split boot counter rotation of forward moving wheel and it's held up for 6 months now. Used a needle on a grease gun and filled the boot with some high temp grease. Some grease is better than none. Almost a permanent fix with that tape and zip tie.
https://www.amazon.com/Automotive-Harne ... 119&sr=8-3
https://www.amazon.com/Prolube-44880-Gr ... 445&sr=8-8
https://www.amazon.com/Lucas-Oil-10005- ... 536&sr=8-2
SkyVolvo
Year and Model: 04 S60 2.5T, 94 850T
Has thanked: 5 times
Post by SkyVolvo »
Finally finished removing the horrible, 17-year old clear bra from my 2004 S60 2.5T. Took a couple of hours, an entire eraser wheel, a bunch of Goo Gone, and a lot of patience - and I still need to come back for the mirrors and clean things up a little more.
But what a difference it makes!
I basically followed this simple video, if anyone else needs to do the same:
Current Volvo:
2004 S60 2.5T
Volvos Emeritus:
'94 940
'91 740
'94 850T Wagon
DonnVa
Year and Model: 2005 XC70
Has thanked: 21 times
Been thanked: 61 times
Post by DonnVa »
I accumulate parts filling out orders to meet the free shipping and/or discount thresholds while buying things I really need at the moment. One wheel bearing or ball joint and such here and there. My car just passed VA state inspection a couple weeks ago, everything is working good, but I had two front wheel bearings, ball joints, front and back stabilizer links. So that’s what I did with no expectations except to enjoy my wrenching time. I was totally surprised when I drove my car yesterday and I felt a big difference in how smooth my car ran down the road. The power transfer from the engine to the wheels was noticeable with the new wheel bearings. Color me happy in VA on Independence Day. Hope you all have a great day.
2005 XC70 Cross Country 2.5T 185k miles
1962 122s 4dr 100k+ TMU
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
30 + other cars and trucks
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
SkyVolvo wrote: 01 Jul 2021, 09:50 Finally finished removing the horrible, 17-year old clear bra from my 2004 S60 2.5T. Took a couple of hours, an entire eraser wheel, a bunch of Goo Gone, and a lot of patience - and I still need to come back for the mirrors and clean things up a little more.
Well done!
Does anyone know if this method will work on peeling clear coat?
vtl
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
volvolugnut wrote: 05 Jul 2021, 14:01 Does anyone know if this method will work on peeling clear coat?
Nope, 3M wheel did no damage to the clear coat. I didn't want any damage.
P2 has a very thick layer of clear coat, which is hardened right. I think you may need either a sand blaster (would eat it down to metal), or some chemical aid to soften it up.
vtl
Post by vtl »
I was going to transplant the Sonnax valve body from my dying transmission to a rebuilt donor, however didn't likethe gaskets after 3 or 4 years of use. Split the VB apart and sprayed the passages with kerosene. It was clean, no clutch material residue, but anyways.
vtl
Post by vtl »
Well, ~$800 for Sonnax valve body 4 years ago was a big mistake. Look at the LPC bore wear! My ATF was never that dirty to cause any such damage! I'd better pay more for a new overpriced Volvo valve body or google better and find a new AC Delco VB for cheap.
Been thanked: 4068 times
Ooof, that’s awful.
vtl
Post by vtl »
abscate wrote: 09 Jul 2021, 03:08 Ooof, that’s awful.
At least it was clean. Partial drain&fill with Volvo ATF every 20-30k miles, some Lubegard HFM, external oil cooler and Magnefine - all of that does help greatly.
I took apart another VB, about 100k miles, probably w/o ATF flush in its lifetime. It was so dirty that I had problems removing the plungers from the bores. Two internal magnetic filters were very dirty, worse than in my Sonnax VB - and I'm rebuilding the donor transmission, because my is apparently failing mechanically, it grinds itself badly lately.
Two bores in Sonnax were rebored for oversized plungers. They look terrible (no mirror), but it seems they are ok.
LPC is not rebored, it has a lot of wear. Decided not to address it this time.
The VB was working acceptable most of time. The transmission was jerking slightly in traffic when hot (ambient temps 90+), but the same thing happens and always happened to TF80SC and A760E that I own from new, so not concerned too much.
