Low coolant light flashed its warning. Noticed at 65 mph on highway. I had checked coolant on weekend and it was fine.
I continued driving , watching coolant gauge which was locked on 3pm position.
5 minutes later reached destination. Coolant bottle empty.
I had routed 1999 return hose form radiator to bottle under the ECU snorkel and it had dipped down and caught the PS pulley. A nice gouge was machined out and a 1mm thick stream of coolant was projecting out about 30 cm
I topped off with spare coolant , wrapped with electrical tape from the spare Kit, and drove home 12 miles without incident
P80 minor road incident 1999 v70
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
I would be cautious about the reliability of the temperature gauge once your coolant light comes on. If you blew all your coolant, I think it's fairly possible there wouldn't be any indication on the temperature gauge to indicate an overheat (as there would be a lack of coolant flowing over the sensor).
In my mind, if it's safe to do so, the second I see a low coolant light, I'm pulling over and turning the engine off.
Nice roadside fix though!
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
Gory pictures. The original hose had softened and sagged into the pS pulley. In later model 1999, the ECU air snorkel has a additional clip to pick up the radiator hose my early 1999 does not have
Another fix is to drape the hose over the air snorkel
This is extreme 1999 Volvo trivia
- Has thanked: 311 times
- Been thanked: 817 times
Or a zip tie on that ECU vent exhaust hose.
- Has thanked: 2200 times
I modified my snorkel tube to add the clip as the original had fallen apart. Transferred the one from the original.
You were lucky! Go get that lottery ticket now!
Neil
Neil
Everything pretty much worked as intended. I caught the coolant light with a cm of coolant Lefton the reservoir, popped hood , and saw problem right away. The hose had gotten soft vs the new one , but I’ll will figure out a way to secure it from a repeat in 20 years
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
looks like they added an extra hose or snorkel for every new model year. I spot at least 3 that my 96 doesn't have. More hoses and snorkels equals better car. Quite simple ...
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
I hear he even topped it up with Genuine Volvo coolant this time =)abscate wrote: 04 Jul 2021, 05:25 Everything pretty much worked as intended. I caught the coolant light with a cm of coolant Lefton the reservoir, popped hood , and saw problem right away. The hose had gotten soft vs the new one , but I’ll will figure out a way to secure it from a repeat in 20 years
