OEM Wheel Identification Assistance?
a3inverter
Year and Model: 2006 V70
Been thanked: 9 times
Post by a3inverter »
Howdy folks.
Found a set of 16" wheels/tires that are available locally and trying to understand if they will fit my 2006 V70.
I'm currently running 17" Thors, but the idea of a cushier 16" ride is appealing.
Any ideas what these are (or what the original fitment was)?
2021-07-11 20_58_29-Window.png (271.57 KiB) Viewed 801 times
MDK
Year and Model: 2004 S60R
Been thanked: 42 times
Post by MDK »
MDK here...so, those wheels are for a 2008 V70..I don't know the name or the center bore or the offset. But I'm pretty sure that is the first year of the new body style. I doubt they'll fit an 06. Not only that. If they're for sale then there's probably something wrong with either the tires or wheels or both.
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
They look like Naos which is Volvo part number 30748344.
Look for a Volvo part number on the back side of the wheel.
Naos has a 20 year history from 1998 - 2018. Mostly V70 but was also used on S60 & S80 depending on year.
Active
Past
93SCMax
Year and Model: 2001 V70 T5 mt
Has thanked: 36 times
Been thanked: 45 times
Post by 93SCMax »
Good reference here. Hopefully you will be able to find it on this pdf.
https://images.matthewsvolvosite.com/wh ... ochure.pdf
Been thanked: 4065 times
I think Naos were a later wheel from 2008 on. If I have actually corrected a RHP mistake I will need the rest of the day off for stress reduction.
It’s definitely a Naos wheel though
RickHaleParker
abscate wrote: 14 Jul 2021, 03:11 I think Naos were a later wheel from 2008 on.
Google 1998 Volvo V70. Click on images. Check out the wheels.
Active
Past
It doesn’t show in the P80:wheel chart link above, and volvo OEM shows fitment for later models
No doubt there are lots of P80s running these as they are nice looking wheels.
RickHaleParker
abscate wrote: 15 Jul 2021, 02:46 It doesn’t show in the P80:wheel chart link above, and volvo OEM shows fitment for later models
Hum ... Depends on where you look or who you ask.
Active
Past
There must be a mistake on the internet. We had better get thst fixed.
That is a nice clean 7 spoke wheel. I’ve never seen a Volvo with those but will look harder now.
