Alarm system service required Topic is solved
Mrichards
Year and Model: 2006 S40
Post by Mrichards »
This message came up on the dash right after I got my alternator replaced yesterday. Got a new battery in May. Looked on some other forums saying it might be a problem with the battery, but since I had it replaced, I don't think that would be the issue.
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
The battery in the Alarm/Siren module not the Starter battery.
Active
Past
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Recommend taking care of it right away! I took my time and the battery acid ate the board so it worked partially after the battery install and went out. Heavy duty zip ties to secure it just in case it rattles over bumps if you don't want to remove the bracket. Should be about the same placement on many Volvos.
Mrichards
Post by Mrichards »
I replaces the siren module, but I'm still getting the message on my dash saying it needs serviced.
RickHaleParker
Mrichards wrote: 23 Jul 2021, 17:27 I replaces the siren module, but I'm still getting the message on my dash saying it needs serviced.
Did you clear the codes with VIDA-DiCE ?
If you replace it with used, there a fair chance the replacement has the same problem.
Active
Past
MoVolvos
Post by MoVolvos »
New, used, you rebuilt and parts number match? A quick search and FCP does not have a module for an 06 S40?
MoVolvos
Post by MoVolvos »
The front of this V50 looks like the pre-facelift C30's. What alarm is this?
Mrichards
Post by Mrichards »
My alarm is the same one in this video
I got a used part from ebay. Didn't clear any codes
MoVolvos
Post by MoVolvos »
The battery and or board may be bad? Battery may no longer charge even if the board is not acid eaten? May have to get another used or new unit unless you know how to test the module. Call a local Volvo shop to see if they have a known good spare sitting around for you to test with.
motormikeyman
Year and Model: 2004 XC70 AWD
Been thanked: 8 times
Post by motormikeyman »
Or you could just ignore it and turn off the warning when you start the car... I've been ignoring mine for 2-1/2 years, LOL.
'94 940 wagon, 220K miles- sold to a guy who then drove it to Oklahoma
'99 XC70 AWD, 210K miles- trans went
'04 XC70 AWD, 196K miles- still going strong
'06 S40 sedan, 150K miles- went with the ex
