odometer is working intermittently
januwan
Year and Model: 97 850 NA 209 K
Has thanked: 7 times
Been thanked: 3 times
Post by januwan »
A few days ago I zeroed my odometer (the car was stopped) and my odometer stopped working. I thought the gear was broken but the next day, after driving to my office and leaving the car in the parking lot (exposed to the sun) it started to work again. The same happened already three times. In the morning it does not work but when I drive home it does.
I was told it could be an ABS module. I upgraded mine a few years back.
Any help greatly appreciated.
januwan
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Odometer on 850 have nothing to do with abs...as long as speedometer works.
If speedo is working intermittently along with odometer...that would be the sign of bad abs module or abs sensors.
Do you have abs/tracs light ON when engine is running?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
januwan
Post by januwan »
No, I don't have any warning light ON and the speedometer is working fine.
januwan
misha
Post by misha »
Then ...it's gears in odometer...which will fail completely...pretty soon.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
januwan
Post by januwan »
Why would it work when the car is hot? Those plastic gears do not expand to engage at the higher temperature and contract at lower one. It looks more like an electrical connection.
I agree that it would indicate gears failure especially when I noticed it after zeroing the trip counter
januwan
misha
Post by misha »
Don't know why but mine did that too...and pretty soon they failed completely at 181k km.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
januwan wrote: 17 Jul 2021, 15:16 Those plastic gears do not expand to engage at the higher temperature and contract at lower one.
A plastics without a coefficient of thermal expansion ... wow! You got a name for that wonder plastic?
Active
Past
Been thanked: 4068 times
RickHaleParker wrote: 18 Jul 2021, 04:12
ShrinkRap....a new genre of Psychologist Musicians
januwan
Post by januwan »
The gears are made out of ABS (most likely) which will expand 10 µm per 1 °C. This would result in 200-300µm expansion which cannot be the reason my odometer does not work properly. That is what I was trying to say. Of course, plastics expand but in this case, it is negligible.
It is better to say nothing if you don't have anything constructive to add.
januwan
RickHaleParker
januwan wrote: 18 Jul 2021, 10:27 but in this case, it is negligible.
If it is in good condition. Right on the edge is another matter. Clearly, it is not in good condition.
What drives the odometer? Pictures are worth a 1000 words.
Active
Past
