Sorry to oppose, but on my 96 the speedo works, but the odometer only works intermittently. The ABS/Tracs lights are on, so the module is probably the culprit.misha wrote: 17 Jul 2021, 13:36 Odometer on 850 have nothing to do with abs...as long as speedometer works.
If speedo is working intermittently along with odometer...that would be the sign of bad abs module or abs sensors.
Do you have abs/tracs light ON when engine is running?
odometer is working intermittently
- Clemens
- Has thanked: 500 times
- Been thanked: 228 times
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- misha
- Has thanked: 155 times
- Been thanked: 432 times
He doesn't have abs/tracs light ON.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
I'm going to go with a bad gear in the odo. It's a known failure.
One bad tooth in the wrong or right location can cause the odo to work sometimes and not others.
- 2020 Views
Last post by Ozark Lee
- 1969 Views
Last post by marcsanders
- 485 Views
Last post by Clemens
- 4178 Views
- 523 Views
Last post by 93Regina
