05 XC70 Fuel filter quick connects
Faust
Year and Model: xc70 2008
Has thanked: 31 times
Been thanked: 10 times
Post by Faust »
Over the weekend I hit a stump, or other undergrowth, which ripped my fuel filter off. Included in the loss are the quick connect fittings for the fuel inlet and outlet lines. I assume I can buy new ones, but how would they connect to the old lines?
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
The line is heated then the QC fitting is inserted. Not very wise to do with the fuel/vapors present in the line.
I would cut a piece of the line, heat/insert the fitting, use a piece of rubber fuel line over the plastic line ends (squeeze them together inside the rubber line) and a pair of Oetiker clamps.
vtl
Post by vtl »
Alternatively, remove the fuel ramp, blow some compressed air through the fuel line to get rid of vapors and heat/insert the new fitting.
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
maybe heat a steel punch , not red hot, push it into the hose, let it soften the hose, remove, then insert the fitting and clamp.
