P80 4 bolt control arm kit front 8628498 8628497
- Has thanked: 1611 times
- Been thanked: 4072 times
A bit tough to find sometimes
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Volvo Annapolis shows them @ ca. $156 each.
https://parts.volvocarsannapolis.com/p/ ... 28497.html
FCP only shows TRW.
https://www.fcpeuro.com/products/volvo- ... -8628497oe
Were you looking for a pair, or just sayin' ?
Well, I’m about 5 hours in to replacing the 4 bolt control arms on n XC70
Job notes
The bolts reside inside the subframe amd are shielded by the subframe, transmission, and engine oil pan. You need to do some clearancecjacking to get your tools squarely on the bolts. They are tight and you will need at least a 12 inch bar to crack them.
Jack the car up high so you get some crack room
I found a mix and match of 16mm and 17 mm hex heads
I still haven’t figured out the magic of getting the bolts started. I think you need the knucklecwell clear of the control arm to present it square to the subframe. Once you get one bolt on each bushing started you can pull it square and do the other two easily
Job notes
- Has thanked: 2209 times
Ah, the fun of the 4 bolts system! Why make a job easy when you can make it hard, good old Volvo saying..........!
One side I can usually get to with a flexible knuckle on the breaker bar or ratchet and an extender bar.
Other side it is easiest to jack the motor to get access.
I think I just need to free the knuckle up enough so that I can get the control arm threads flat against the sub frame. They are naturally tensioned at an angle so that you can’t start the threads easily
Ooof,0600 report
Four bolt control arms, 1 Aleve per side next morning
Ooof,0600 report
I popped the tie rod end off, swung the knuckle out of the way and had the bolts hand started in 2 minutes.
The other side went easier as I was rebuilding the axle shaft boots, so the knuckle was already free.
- 2500 Views
Last post by Kazthebassman
- 12 Replies
- 3803 Views
Last post by JimBee
- 18 Replies
- 4300 Views
Last post by SuperHerman
- 2089 Views
- 4040 Views
Last post by Pretribrapper
