Thanks for the video, finally watched it all the way through lol. I tried direct ether to the ports at the rail and since that didn’t work, I assume it’s spark related….but, I have 10.8 at each coil on cranking and nothing. Tried jumping, nothing.
What am I overlooking?
Again thanks so much to everyone for helping, I don’t have many more options.
V70 won’t start. Out of ideas.
- Has thanked: 987 times
- Been thanked: 1075 times
What fuel pressure did you find? Need about 55 PSI.
Spark should be strong and blue. Something electrical may still be wet. Is all of your wire harness well wrapped?
Also, didn’t actually test fuel pressure, but I’m willing to do that. Just assumed direct ether spray into the injection ports ruled out fuel. Am I wrong on that?
New to Volvo, so I might be prejudiced to thinking it’s something I’m not familiar with.
Thanks for answering me! I appreciate everyone’s help!!
You need good fuel pressure (55 PSI) for good spray pattern. Test the fuel pressure with gauge adapter at the pressure release Schrader valve on the right side of the intake manifold. Remove the valve internal and use a hose to adapt to 0 to 100 PSI gauge. Pressure should come up immediately and hold steady.
If some of your wiring loam is missing, there could be a short caused by water somewhere. This would explain the sudden no start after the rain storm.
The coil ground wires are very important. Are they all clean and connected to the head?
Maybe check for any loose vacuum or electric connections? Maybe do a smoke test for the intake system. Search this forum for how to do smoke test.
Check any area you worked around for something you may have knocked loose.
- 35 Replies
- 2166 Views
Last post by MotorTheresa
- 9 Replies
- 1945 Views
Last post by Sanatarium
- 12 Replies
- 2334 Views
Last post by E Showell
- 5648 Views
Last post by Oly850
- 1025 Views
Last post by vtl
