Vida CEM swapping
raikonen
Year and Model: 2007 c70
Post by raikonen »
mikeak2001 wrote: 31 Mar 2021, 04:34
Pictures from the car config editor:
Main folder:
hello
Is there any chance to get this programm?
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Come on ... trim the quotes.
Active
Past
ricked
Year and Model: xc90
Has thanked: 6 times
Post by ricked »
need some help with V50 CEM 30728906 on bench, i did a few of this model without problems now i have one with part number 30728906 and the script cant find the pin, i did try 4 times now and i get pin numbers like:
27 07 07 -- -- --
48 28 88 -- -- --
last try is 88 35 07 -- -- --
13v power and nothing changed to script or what ever so working with other CEM's
any thoughts?
see log
Code: Select all
CPU Maximum Frequency:   600000000
CPU Frequency:           600000000
Execution Rate:          600 cycles/us
PIN bytes to measure:    3
Number of samples:       100
CAN low-speed init done.
Reading part number from ECU 0x40 on CAN_LS
CAN_LS ---> ID=000ffffe data=cb 40 b9 f0 00 00 00 00
Can't find part number on CAN-LS, trying CAN-HS at 500 Kbps
CAN high-speed init done.
Reading part number from ECU 0x50 on CAN_HS
CAN_HS ---> ID=000ffffe data=cb 50 b9 f0 00 00 00 00
CAN_HS <--- ID=0100082c data=08 00 00 00 00 00 00 59
CAN_HS <--- ID=0110483c data=08 20 a0 00 44 66 e4 00
CAN_HS <--- ID=1a200020 data=82 00 00 00 00 00 01 60
CAN_HS <--- ID=1ae0092c data=c0 00 22 e0 40 00 00 00
CAN_HS <--- ID=1b700030 data=05 00 00 00 00 00 00 00
CAN_HS <--- ID=1ba0493c data=13 00 00 00 00 00 00 00
CAN_HS <--- ID=1be0493c data=01 00 13 bd ea fb 02 04
CAN_HS <--- ID=00400003 data=8f 50 f9 f0 00 30 72 89
CAN_HS <--- ID=0110483c data=08 20 20 00 44 66 e4 00
CAN_HS <--- ID=00400003 data=09 06 20 20 20 30 72 89
Part Number: 30728906
Searching P/N 30728906 in 49 known CEMs
CAN HS baud rate: 500000
PIN shuffle order: 0 1 2 3 4 5
Putting all ECUs into programming mode.
CAN_HS ---> ID=000ffffe data=ff 86 00 00 00 00 00 00
CAN_LS ---> ID=000ffffe data=ff 86 00 00 00 00 00 00
Initialization done.
Calculating bytes 0-2
1000 pins in 703 ms, 1422 pins/s, average response: 151 us, histogram 75 to 226 us
                   us:   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162
[ 00 -- -- -- -- -- ]:     0  1191     0    57     0     0     0     0     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1409332; std 385.40
[ 01 -- -- -- -- -- ]:     1  3925     1  1209     0    63     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1429416; std 389.47
[ 02 -- -- -- -- -- ]:     0  3910     0  1140     0    60     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1428868; std 380.18
[ 03 -- -- -- -- -- ]:     4  3925     0  1198     0    70     0     0     0     1     0     0     0     0     0     0     0     0     0     0 : latency    1429380; std 383.03
[ 04 -- -- -- -- -- ]:     0  3571     0  1028     0    57     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1426861; std 372.23
[ 05 -- -- -- -- -- ]:     2  3992     0  1184     0    61     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1429435; std 386.68
[ 06 -- -- -- -- -- ]:     2  3822     0  1165     0    56     0     0     0     0     0     1     0     0     0     0     0     0     0     0 : latency    1428856; std 386.40
[ 07 -- -- -- -- -- ]:     0  3931     0  1220     0    57     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1429450; std 381.50
[ 08 -- -- -- -- -- ]:     1  3001     0   765     0    40     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1422683; std 364.90
[ 09 -- -- -- -- -- ]:     2  3937     0  1202     0    64     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1429469; std 386.39
[ 10 -- -- -- -- -- ]:     0  1751     0   277     0     9     0     0     0     1     0     0     0     0     0     0     0     0     0     0 : latency    1413722; std 368.62
[ 11 -- -- -- -- -- ]:     0  3931     0  1223     0    64     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1429419; std 381.67
[ 12 -- -- -- -- -- ]:     0  3852     0  1201     0    56     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1428840; std 373.00
[ 13 -- -- -- -- -- ]:     1  3922     0  1196     0    73     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1429463; std 381.39
[ 14 -- -- -- -- -- ]:     4  3518     0  1060     0    50     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1426741; std 368.72
[ 15 -- -- -- -- -- ]:     1  3934     0  1232     0    60     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1429463; std 384.17
[ 16 -- -- -- -- -- ]:     0  3803     0  1173     0    71     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1428836; std 379.47
[ 17 -- -- -- -- -- ]:     0  3951     0  1191     0    76     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1429426; std 380.82
[ 18 -- -- -- -- -- ]:     0  2921     0   796     0    48     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1422667; std 358.72
[ 19 -- -- -- -- -- ]:     0  3907     0  1193     0    70     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1429423; std 384.59
[ 20 -- -- -- -- -- ]:     0  3955     1  1221     0    53     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1429465; std 390.05
[ 21 -- -- -- -- -- ]:     2  3348     2  3913     0  1202     0    50     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449260; std 388.22
[ 22 -- -- -- -- -- ]:     0  3387     0  3832     0  1201     0    54     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448978; std 378.99
[ 23 -- -- -- -- -- ]:     0  3295     2  3969     0  1191     0    53     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1449340; std 384.61
[ 24 -- -- -- -- -- ]:     0  3438     2  3618     1  1029     0    52     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1446941; std 374.99
[ 25 -- -- -- -- -- ]:     2  3357     1  3870     0  1226     0    53     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449291; std 384.52
[ 26 -- -- -- -- -- ]:     1  3311     6  3930     0  1155     0    57     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449003; std 382.86
[ 27 -- -- -- -- -- ]:     0  3310     1  3944     0  1184     0    60     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1449298; std 386.17
[ 28 -- -- -- -- -- ]:     3  3689     2  2955     0   782     0    35     0     0     0     1     0     0     0     0     0     0     0     0 : latency    1442761; std 366.97
[ 29 -- -- -- -- -- ]:     1  3344     0  3884     1  1217     0    54     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1449310; std 384.86
[ 30 -- -- -- -- -- ]:     1  3874     1  1792     0   284     0    12     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1433790; std 374.48
[ 31 -- -- -- -- -- ]:     1  3287     0  3975     1  1178     0    60     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449370; std 386.84
[ 32 -- -- -- -- -- ]:     1  3319     0  3874     0  1179     0    65     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1448981; std 378.27
[ 33 -- -- -- -- -- ]:     0  1453     0  3491     1  3718     1   983     0    13     0     0     0     0     0     0     0     1     0     0 : latency    1466982; std 383.24
[ 34 -- -- -- -- -- ]:     1  3473     1  3550     0  1075     0    39     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1446946; std 376.17
[ 35 -- -- -- -- -- ]:     0  3349     0  3877     0  1207     0    66     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1449316; std 380.13
[ 36 -- -- -- -- -- ]:     0  3248     1  3890     0  1199     0    54     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1448931; std 379.09
[ 37 -- -- -- -- -- ]:     0  3348     1  3891     0  1208     0    60     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449481; std 381.02
[ 38 -- -- -- -- -- ]:     2  3666     2  2951     0   818     1    29     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1442755; std 366.10
[ 39 -- -- -- -- -- ]:     1  3350     0  3905     1  1224     0    50     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1449386; std 385.92
[ 40 -- -- -- -- -- ]:     0  3813     0  1179     0    59     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1428873; std 385.23
[ 41 -- -- -- -- -- ]:     2  3878     1  1221     0    67     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1429492; std 385.15
[ 42 -- -- -- -- -- ]:     3  3381     3  3833     0  1164     0    64     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1448924; std 385.64
[ 43 -- -- -- -- -- ]:     1  3288     0  3957     1  1193     0    71     0     0     0     1     0     0     0     0     0     0     0     0 : latency    1449444; std 385.67
[ 44 -- -- -- -- -- ]:     0  3413     1  3582     0  1048     0    49     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1446887; std 370.98
[ 45 -- -- -- -- -- ]:     2  3341     1  3906     0  1208     0    66     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1449423; std 385.44
[ 46 -- -- -- -- -- ]:     2  3334     2  3860     0  1178     0    53     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448902; std 383.00
[ 47 -- -- -- -- -- ]:     0  3296     0  3921     0  1230     0    55     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1449446; std 380.54
[ 48 -- -- -- -- -- ]:     2  3578     0  2995     0   780     0    40     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1442636; std 360.53
[ 49 -- -- -- -- -- ]:     0  3378     1  3891     0  1228     0    54     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449411; std 383.94
[ 50 -- -- -- -- -- ]:     1  3981     0  1693     0   287     0    10     0     0     0     1     0     0     0     0     0     0     0     0 : latency    1433741; std 371.55
[ 51 -- -- -- -- -- ]:     1  3276     1  3945     0  1225     0    56     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1449461; std 387.16
[ 52 -- -- -- -- -- ]:     1  3347     0  3812     1  1194     0    58     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1448847; std 383.22
[ 53 -- -- -- -- -- ]:     1  3317     2  3923     1  1238     0    51     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449529; std 390.01
[ 54 -- -- -- -- -- ]:     2  3377     0  3591     1  1041     0    47     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1446821; std 372.50
[ 55 -- -- -- -- -- ]:     1  3296     0  3978     0  1205     0    52     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449491; std 385.35
[ 56 -- -- -- -- -- ]:     0  3363     1  3838     2  1180     0    59     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448915; std 382.83
[ 57 -- -- -- -- -- ]:     0  3296     0  3962     1  1205     0    56     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449481; std 384.61
[ 58 -- -- -- -- -- ]:     0  3616     1  2952     0   806     0    31     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1442627; std 358.77
[ 59 -- -- -- -- -- ]:     0  3316     1  3938     0  1229     0    46     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1449432; std 386.22
[ 60 -- -- -- -- -- ]:     0  3917     0  1213     0    62     0     0     0     0     0     1     0     0     0     0     0     0     0     0 : latency    1429445; std 385.60
[ 61 -- -- -- -- -- ]:     3  3337     0  3929     1  1180     0    57     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1449310; std 386.85
[ 62 -- -- -- -- -- ]:     0  3359     0  3861     0  1176     0    70     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1449012; std 378.92
[ 63 -- -- -- -- -- ]:     1  3349     3  3909     0  1192     0    63     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449336; std 385.90
[ 64 -- -- -- -- -- ]:     1  3473     2  3555     1  1054     0    51     0     0     0     1     0     0     0     0     0     0     0     0 : latency    1446943; std 378.38
[ 65 -- -- -- -- -- ]:     1  3356     0  3905     1  1194     0    59     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449344; std 386.35
[ 66 -- -- -- -- -- ]:     0  3299     0  3878     0  1201     0    53     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1449030; std 380.49
[ 67 -- -- -- -- -- ]:     0  3331     2  3922     0  1189     0    58     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449337; std 386.46
[ 68 -- -- -- -- -- ]:     0  3635     1  2971     0   797     0    38     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1442747; std 361.90
[ 69 -- -- -- -- -- ]:     3  3388     3  3846     0  1208     0    65     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1449228; std 384.03
[ 70 -- -- -- -- -- ]:     1  3936     0  1763     0   297     0    10     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1433855; std 368.98
[ 71 -- -- -- -- -- ]:     1  3384     1  3872     0  1220     0    64     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449398; std 385.28
[ 72 -- -- -- -- -- ]:     0  3318     0  3933     0  1146     0    63     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448996; std 380.98
[ 73 -- -- -- -- -- ]:     0  3334     2  3903     0  1207     0    60     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449358; std 385.15
[ 74 -- -- -- -- -- ]:     0  3439     1  3597     0  1026     0    59     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1446973; std 374.77
[ 75 -- -- -- -- -- ]:     1  3331     2  3938     0  1176     0    71     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449371; std 384.16
[ 76 -- -- -- -- -- ]:     0  3274     1  3872     0  1202     0    52     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1448947; std 379.26
[ 77 -- -- -- -- -- ]:     1  3375     1  3898     1  1211     0    52     0     0     0     1     0     0     0     0     0     0     0     0 : latency    1449391; std 388.99
[ 78 -- -- -- -- -- ]:     1  3620     2  2998     2   788     0    30     0     0     0     1     0     0     0     0     0     0     0     0 : latency    1442717; std 366.75
[ 79 -- -- -- -- -- ]:     0  3313     0  3920     1  1201     0    60     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449353; std 383.10
[ 80 -- -- -- -- -- ]:     1  3570     1  1062     0    43     0     0     0     1     0     0     0     0     0     0     0     0     0     0 : latency    1426877; std 375.02
[ 81 -- -- -- -- -- ]:     0  3926     1  1219     0    50     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1429445; std 386.65
[ 82 -- -- -- -- -- ]:     3  3838     0  1181     0    60     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1428881; std 383.89
[ 83 -- -- -- -- -- ]:     1  3976     0  1201     0    65     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1429459; std 383.03
[ 84 -- -- -- -- -- ]:     2  3446     2  3546     0  1048     0    55     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1446833; std 372.51
[ 85 -- -- -- -- -- ]:     0  3303     2  3946     0  1200     0    68     0     0     0     1     0     0     0     0     0     0     0     0 : latency    1449482; std 381.63
[ 86 -- -- -- -- -- ]:     1  3364     0  3822     0  1198     0    52     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1448914; std 380.30
[ 87 -- -- -- -- -- ]:     0  3271     0  3957     1  1206     0    60     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449431; std 383.35
[ 88 -- -- -- -- -- ]:     1  3580     0  2936     0   831     0    28     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1442615; std 356.74
[ 89 -- -- -- -- -- ]:     0  3222     1  3962     0  1236     0    50     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1449419; std 381.87
[ 90 -- -- -- -- -- ]:     0  3933     0  1778     0   265     0     8     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1433908; std 364.22
[ 91 -- -- -- -- -- ]:     2  3313     1  3937     0  1201     0    63     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1449397; std 383.55
[ 92 -- -- -- -- -- ]:     1  3313     3  3904     1  1151     0    64     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1448931; std 385.92
[ 93 -- -- -- -- -- ]:     0  3346     2  3903     1  1207     0    65     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1449385; std 385.29
[ 94 -- -- -- -- -- ]:     2  3521     1  3529     0  1033     0    59     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1446899; std 374.89
[ 95 -- -- -- -- -- ]:     0  3310     2  3879     0  1245     0    61     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449402; std 380.81
[ 96 -- -- -- -- -- ]:     0  3340     1  3847     0  1167     0    63     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448895; std 382.90
[ 97 -- -- -- -- -- ]:     1  3299     0  3914     2  1237     0    51     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449435; std 382.47
[ 98 -- -- -- -- -- ]:     1  3617     1  2960     0   799     0    29     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1442607; std 363.40
[ 99 -- -- -- -- -- ]:     1  3362     0  3852     0  1274     0    42     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1449409; std 379.63
best candidates ordered by latency:
0: 33 lat = 1466982
1: 53 lat = 1449529
2: 55 lat = 1449491
3: 85 lat = 1449482
4: 57 lat = 1449481
95: 14 lat = 1426741
96: 08 lat = 1422683
97: 18 lat = 1422667
98: 10 lat = 1413722
99: 00 lat = 1409332
best candidates ordered by std:
0: 20 std = 390.05
1: 53 std = 390.01
2: 01 std = 389.47
3: 77 std = 388.99
4: 21 std = 388.22
95: 68 std = 361.90
96: 48 std = 360.53
97: 58 std = 358.77
98: 18 std = 358.72
99: 88 std = 356.74
lat_k 0-1 1.20%, lat_k 98-99 0.31%, lat_k 0-99 4.09%
std_k 0-1 0.01%, std_k 98-99 0.56%, std_k 0-99 9.34%
STD has more deviation than latency
STD[99] deviates more than STD[0]
pin[0] choose candidate: 88 based on std
[ 88 00 -- -- -- -- ]:     4  3911     0  3366     0   182     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1441097; std 395.73
[ 88 01 -- -- -- -- ]:     1  3916     0  3415     0   194     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1441377; std 397.14
[ 88 02 -- -- -- -- ]:     0  1917     1  3991     1  3328     0   187     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1460994; std 396.32
[ 88 03 -- -- -- -- ]:     0  1908     0  3996     0  3406     0   186     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1461500; std 396.15
[ 88 04 -- -- -- -- ]:     2  2136     1  3999     0  2973     0   153     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1459029; std 386.77
[ 88 05 -- -- -- -- ]:     0  1836     0  3986     2  3427     0   184     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1461379; std 398.92
[ 88 06 -- -- -- -- ]:     0  1908     3  3987     2  3331     0   182     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1460957; std 398.13
[ 88 07 -- -- -- -- ]:     0  1959     1  3964     1  3384     0   196     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1461420; std 398.54
[ 88 08 -- -- -- -- ]:     1  2702     1  3906     1  2189     0   118     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1454589; std 374.56
[ 88 09 -- -- -- -- ]:     0  1859     1  4143     0  3301     0   189     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1461377; std 400.79
[ 88 10 -- -- -- -- ]:     2  3579     2  3605     0   825     0    35     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1445746; std 381.57
[ 88 11 -- -- -- -- ]:     0  1948     0  4062     0  3346     0   181     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1461428; std 398.17
[ 88 12 -- -- -- -- ]:     0  2022     0  4030     1  3252     0   190     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1460945; std 397.74
[ 88 13 -- -- -- -- ]:     1  1970     1  3971     1  3354     0   198     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1461299; std 401.88
[ 88 14 -- -- -- -- ]:     0  2197     0  4000     0  2900     1   166     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1458759; std 383.06
[ 88 15 -- -- -- -- ]:     0  1922     1  4096     3  3296     0   198     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1461358; std 401.17
[ 88 16 -- -- -- -- ]:     1  1939     0  4070     2  3257     0   188     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1460955; std 398.22
[ 88 17 -- -- -- -- ]:     0  1855     2  4071     1  3342     0   187     0     0     0     1     0     0     0     0     0     0     0     0 : latency    1461291; std 402.36
[ 88 18 -- -- -- -- ]:     0  2721     0  3873     0  2230     0   120     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1454820; std 368.13
[ 88 19 -- -- -- -- ]:     2  1829     2  4054     1  3358     0   204     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1461354; std 403.31
[ 88 20 -- -- -- -- ]:     0  4028     1  3380     0   194     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1441510; std 400.52
[ 88 21 -- -- -- -- ]:     0  1872     0  3968     0  3431     0   186     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1461408; std 398.92
[ 88 22 -- -- -- -- ]:     0  1947     0  3906     0  3380     0   183     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1460990; std 390.43
[ 88 23 -- -- -- -- ]:     1  1870     0  4013     0  3400     0   194     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1461531; std 398.05
[ 88 24 -- -- -- -- ]:     0  2202     1  4002     0  2934     0   168     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1459057; std 384.89
[ 88 25 -- -- -- -- ]:     0  1928     0  3891     1  3476     0   177     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1461469; std 398.23
[ 88 26 -- -- -- -- ]:     0  1941     2  3994     2  3316     1   189     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1461017; std 400.65
[ 88 27 -- -- -- -- ]:     0  1890     1  4031     0  3395     1   186     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1461522; std 401.35
[ 88 28 -- -- -- -- ]:     0  2673     2  3964     0  2151     0   131     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1454602; std 373.42
[ 88 29 -- -- -- -- ]:     0  1898     0  4104     2  3332     0   188     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1461494; std 400.86
[ 88 30 -- -- -- -- ]:     2  3600     0  3562     0   843     0    28     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1445684; std 380.77
[ 88 31 -- -- -- -- ]:     0  1896     0  4042     0  3385     0   172     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1461408; std 399.69
[ 88 32 -- -- -- -- ]:     0  1968     1  4036     0  3255     0   197     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1460913; std 394.64
[ 88 33 -- -- -- -- ]:     0  1850     2  4076     0  3348     0   191     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1461318; std 398.55
[ 88 34 -- -- -- -- ]:     0  2215     0  3990     1  2902     0   167     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1458791; std 383.12
[ 88 35 -- -- -- -- ]:     1  1921     1  4144     1  3298     0   185     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1461433; std 408.29
[ 88 36 -- -- -- -- ]:     0  2047     0  4000     1  3273     0   183     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1460957; std 397.68
[ 88 37 -- -- -- -- ]:     0  1950     1  3966     0  3376     1   194     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1461338; std 400.11
[ 88 38 -- -- -- -- ]:     1  2619     1  3975     0  2203     0   117     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1454846; std 374.35
[ 88 39 -- -- -- -- ]:     1  1990     1  3829     0  3466     0   194     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1461388; std 395.56
[ 88 40 -- -- -- -- ]:     0  1989     0  3979     2  3319     0   189     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1461076; std 397.00
[ 88 41 -- -- -- -- ]:     1  1898     1  3897     0  3455     0   184     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1461352; std 396.71
[ 88 42 -- -- -- -- ]:     0   487     2  1836     2  4076     1  3331     0   170     0     0     0     0     0     0     0     0     0     1 : latency    1481017; std 401.60
[ 88 43 -- -- -- -- ]:     0   439     0  1905     0  3996     0  3388     0   204     0     0     0     0     0     0     0     1     0     0 : latency    1481628; std 392.93
[ 88 44 -- -- -- -- ]:     0   565     0  2241     2  3996     0  2926     0   173     0     0     0     0     0     0     0     0     0     1 : latency    1479082; std 387.37
[ 88 45 -- -- -- -- ]:     1   445     0  1922     3  3948     2  3421     0   190     0     0     0     0     0     0     0     1     0     0 : latency    1481430; std 402.57
[ 88 46 -- -- -- -- ]:     0   488     1  1957     0  3968     1  3323     0   195     0     0     0     0     0     0     0     0     0     1 : latency    1481034; std 397.82
[ 88 47 -- -- -- -- ]:     0   476     0  1898     2  3950     0  3459     0   166     0     0     0     0     0     0     0     0     0     1 : latency    1481466; std 398.06
[ 88 48 -- -- -- -- ]:     0   923     1  2687     1  3889     0  2208     0   119     0     0     0     0     0     1     0     0     0     0 : latency    1474634; std 373.89
[ 88 49 -- -- -- -- ]:     0   420     0  1936     1  4065     1  3348     0   180     0     0     0     0     0     0     0     0     0     1 : latency    1481450; std 404.38
[ 88 50 -- -- -- -- ]:     0  1530     2  3612     1  3585     0   820     0    39     0     0     0     1     0     0     0     0     0     0 : latency    1465727; std 382.02
[ 88 51 -- -- -- -- ]:     0   420     0  1866     0  4134     1  3333     0   175     0     0     0     0     0     0     0     0     0     1 : latency    1481399; std 403.97
[ 88 52 -- -- -- -- ]:     0   500     0  1961     1  4010     0  3290     0   179     0     0     0     0     0     0     0     1     0     0 : latency    1480899; std 394.79
[ 88 53 -- -- -- -- ]:     0   465     0  1922     2  3993     0  3372     0   187     0     0     0     0     0     0     0     0     0     1 : latency    1481306; std 398.78
[ 88 54 -- -- -- -- ]:     0   656     0  2171     3  3969     1  2934     0   160     0     0     0     0     0     0     0     1     0     0 : latency    1478780; std 384.21
[ 88 55 -- -- -- -- ]:     0   420     0  1981     0  4029     3  3343     0   182     0     0     0     0     0     0     0     0     0     1 : latency    1481403; std 399.04
[ 88 56 -- -- -- -- ]:     0   442     1  2018     1  4011     0  3283     0   183     0     0     0     1     0     0     0     0     0     0 : latency    1480990; std 400.08
[ 88 57 -- -- -- -- ]:     1   427     0  1901     2  4046     1  3371     0   177     0     0     0     0     0     0     0     0     0     1 : latency    1481358; std 405.39
[ 88 58 -- -- -- -- ]:     2   851     1  2704     1  3925     0  2225     1   111     0     0     0     0     0     0     0     1     0     0 : latency    1474853; std 378.92
[ 88 59 -- -- -- -- ]:     0   467     0  1893     1  3936     0  3436     0   190     0     0     0     0     0     0     0     1     0     0 : latency    1481388; std 397.76
[ 88 60 -- -- -- -- ]:     1  1853     0  4089     0  3362     0   191     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1461511; std 400.24
[ 88 61 -- -- -- -- ]:     0   455     1  1909     1  3953     0  3414     0   194     0     0     0     0     0     0     0     1     0     0 : latency    1481400; std 398.05
[ 88 62 -- -- -- -- ]:     0   475     1  1989     2  3948     0  3331     0   182     0     0     0     0     0     0     0     0     0     1 : latency    1480947; std 397.85
[ 88 63 -- -- -- -- ]:     0   448     0  1855     0  4071     0  3377     0   191     0     0     0     0     0     0     0     1     0     0 : latency    1481546; std 397.91
[ 88 64 -- -- -- -- ]:     0   612     0  2170     2  4005     1  2933     0   170     0     0     0     0     0     0     0     1     0     0 : latency    1478983; std 388.28
[ 88 65 -- -- -- -- ]:     0   475     0  1980     1  3788     1  3498     0   195     0     0     0     0     0     1     0     0     0     0 : latency    1481420; std 396.78
[ 88 66 -- -- -- -- ]:     1   460     0  1927     3  3976     0  3338     0   188     0     0     0     0     0     0     0     1     0     0 : latency    1480942; std 398.01
[ 88 67 -- -- -- -- ]:     0   446     0  1941     1  3948     1  3413     0   193     0     0     0     0     0     0     0     0     0     1 : latency    1481470; std 398.60
[ 88 68 -- -- -- -- ]:     0   912     1  2668     2  3926     0  2180     0   118     0     0     0     0     0     0     0     1     0     0 : latency    1474531; std 374.34
[ 88 69 -- -- -- -- ]:     0   439     0  1918     4  4052     1  3344     0   190     0     0     0     0     0     0     0     1     0     0 : latency    1481419; std 400.83
[ 88 70 -- -- -- -- ]:     0  1601     2  3553     0  3600     0   829     0    30     0     0     0     0     0     1     0     0     0     0 : latency    1465714; std 379.06
[ 88 71 -- -- -- -- ]:     0   444     0  1882     1  4110     0  3331     0   180     0     0     0     0     0     0     0     1     0     0 : latency    1481411; std 400.84
[ 88 72 -- -- -- -- ]:     0   472     0  1978     1  4050     3  3260     0   177     0     0     0     0     0     0     0     1     0     0 : latency    1480914; std 398.26
[ 88 73 -- -- -- -- ]:     0   467     0  1867     3  4075     2  3355     0   174     0     0     0     0     0     0     0     1     0     0 : latency    1481331; std 403.61
[ 88 74 -- -- -- -- ]:     0   642     0  2181     1  3970     0  2913     0   176     0     0     0     0     0     0     0     0     0     1 : latency    1478765; std 381.33
[ 88 75 -- -- -- -- ]:     0   449     0  1871     0  4060     2  3371     0   180     0     0     0     0     0     0     0     0     0     1 : latency    1481402; std 399.38
[ 88 76 -- -- -- -- ]:     0   468     0  1973     3  4045     0  3257     1   186     0     0     0     0     0     1     0     0     0     0 : latency    1480918; std 397.60
[ 88 77 -- -- -- -- ]:     0   462     0  1936     3  3980     4  3361     0   192     0     0     0     0     0     1     0     0     0     0 : latency    1481273; std 397.74
[ 88 78 -- -- -- -- ]:     0   895     1  2696     1  3906     1  2212     0   122     0     0     0     0     0     0     0     1     0     0 : latency    1474803; std 375.20
[ 88 79 -- -- -- -- ]:     0   500     0  1900     2  3864     1  3484     0   181     0     0     0     0     0     0     0     1     0     0 : latency    1481357; std 398.38
[ 88 80 -- -- -- -- ]:     1  2253     1  3938     0  2961     0   166     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1459046; std 385.83
[ 88 81 -- -- -- -- ]:     0  1881     0  4002     0  3389     0   208     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1461490; std 396.87
[ 88 82 -- -- -- -- ]:     1  1953     0  3982     1  3325     0   184     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1460973; std 398.59
[ 88 83 -- -- -- -- ]:     1  1930     0  3985     1  3396     1   201     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1461567; std 401.68
[ 88 84 -- -- -- -- ]:     0   595     0  2196     0  4013     0  2906     0   181     0     0     0     0     0     0     0     1     0     0 : latency    1478966; std 384.01
[ 88 85 -- -- -- -- ]:     0   475     0  1838     0  4042     1  3376     0   198     0     0     0     0     0     0     0     0     0     1 : latency    1481415; std 399.77
[ 88 86 -- -- -- -- ]:     0   508     2  1969     1  3915     3  3343     0   191     0     0     0     0     0     0     0     0     0     1 : latency    1480942; std 398.07
[ 88 87 -- -- -- -- ]:     0   448     0  1845     3  4050     1  3395     0   192     0     0     0     0     0     0     0     1     0     0 : latency    1481552; std 403.41
[ 88 88 -- -- -- -- ]:     0   959     1  2645     2  3882     0  2219     0   121     0     0     0     0     0     1     0     0     0     0 : latency    1474615; std 370.23
[ 88 89 -- -- -- -- ]:     0   428     0  1917     2  4105     0  3293     0   194     0     0     0     0     0     1     0     0     0     0 : latency    1481328; std 399.45
[ 88 90 -- -- -- -- ]:     1  1546     1  3578     0  3614     0   813     0    35     0     0     0     0     0     0     0     1     0     0 : latency    1465726; std 382.12
[ 88 91 -- -- -- -- ]:     1   435     0  1934     0  4045     1  3348     0   182     0     0     0     0     0     0     0     0     0     1 : latency    1481374; std 398.98
[ 88 92 -- -- -- -- ]:     0   477     0  1965     1  4053     3  3253     0   193     0     0     0     0     0     0     0     1     0     0 : latency    1480990; std 397.74
[ 88 93 -- -- -- -- ]:     0   479     2  1918     2  3962     1  3396     0   182     0     0     0     0     0     0     0     0     0     1 : latency    1481291; std 400.12
[ 88 94 -- -- -- -- ]:     0   608     0  2162     3  4057     0  2886     0   165     0     0     0     0     0     0     0     1     0     0 : latency    1478815; std 384.90
[ 88 95 -- -- -- -- ]:     0   437     0  1848     1  4189     0  3281     0   186     0     0     0     0     0     0     0     0     0     1 : latency    1481395; std 402.44
[ 88 96 -- -- -- -- ]:     0   418     0  1987     1  4097     1  3222     0   197     0     0     0     0     0     1     0     0     0     0 : latency    1481130; std 397.29
[ 88 97 -- -- -- -- ]:     0   445     0  1882     1  4045     1  3355     0   187     0     0     0     0     0     0     0     0     0     1 : latency    1481272; std 401.97
[ 88 98 -- -- -- -- ]:     1   848     1  2712     2  3894     0  2218     0   127     0     0     0     1     0     0     0     0     0     0 : latency    1474766; std 376.92
[ 88 99 -- -- -- -- ]:     0   438     0  1837     1  4057     2  3369     0   205     0     0     0     0     0     0     0     0     0     1 : latency    1481455; std 400.12
0: 43 lat = 1481628
1: 87 lat = 1481552
2: 63 lat = 1481546
3: 67 lat = 1481470
4: 47 lat = 1481466
95: 10 lat = 1445746
96: 30 lat = 1445684
97: 20 lat = 1441510
98: 01 lat = 1441377
99: 00 lat = 1441097
0: 35 std = 408.29
1: 57 std = 405.39
2: 49 std = 404.38
3: 51 std = 403.97
4: 73 std = 403.61
95: 68 std = 374.34
96: 48 std = 373.89
97: 28 std = 373.42
98: 88 std = 370.23
99: 18 std = 368.13
lat_k 0-1 0.01%, lat_k 98-99 0.02%, lat_k 0-99 2.81%
std_k 0-1 0.72%, std_k 98-99 0.57%, std_k 0-99 10.91%
STD[0] deviates more than STD[99]
pin[1] choose candidate: 35 based on std
[ 88 35 00 -- -- -- ]:     0  1510     2  3223     0  3411     0  1386     0    68     0     0     0     1     0     0     0     0     0     0 : latency    1467937; std 355.68
[ 88 35 01 -- -- -- ]:     1   831     1  2723     0  4060     0  2083     0   122     0     0     0     0     0     1     0     0     0     0 : latency    1474658; std 379.26
[ 88 35 02 -- -- -- ]:     1   926     1  2767     2  3923     0  2081     0   120     0     0     0     0     0     1     0     0     0     0 : latency    1474170; std 377.56
[ 88 35 03 -- -- -- ]:     0   859     1  2741     0  4023     0  2102     0   116     0     0     0     0     0     1     0     0     0     0 : latency    1474651; std 378.54
[ 88 35 04 -- -- -- ]:     0  1092     1  2980     0  3710     0  1865     0   101     0     0     0     1     0     0     0     0     0     0 : latency    1472121; std 365.08
[ 88 35 05 -- -- -- ]:     0   879     1  2681     0  4065     0  2108     0   106     0     0     0     0     0     1     0     0     0     0 : latency    1474647; std 376.98
[ 88 35 06 -- -- -- ]:     1   933     0  2760     1  3954     0  2072     0   113     0     0     0     1     0     0     0     0     0     0 : latency    1474180; std 376.89
[ 88 35 07 -- -- -- ]:     0  1344     1  2866     2  3516     2  1723     0    97     0     0     0     0     0     0     0     1     0     0 : latency    1469725; std 352.35
[ 88 35 08 -- -- -- ]:     0   319     0  1533     0  3257     1  3400     0  1358     0    77     0     0     0     0     0     1     0     0 : latency    1487901; std 359.11
[ 88 35 09 -- -- -- ]:     0   131     0   867     0  2740     1  4024     0  2108     0   110     0     1     0     0     0     0     0     0 : latency    1494643; std 381.05
[ 88 35 10 -- -- -- ]:     0   672     0  2295     1  3788     0  2592     0   502     0    23     0     0     0     1     0     0     0     0 : latency    1479133; std 364.39
[ 88 35 11 -- -- -- ]:     0   135     0   865     0  2701     0  4060     1  2098     0   121     0     0     0     0     0     0     0     1 : latency    1494739; std 379.19
[ 88 35 12 -- -- -- ]:     0   169     0   888     1  2770     1  3998     2  2048     1   110     0     0     0     1     0     0     0     0 : latency    1494215; std 383.26
[ 88 35 13 -- -- -- ]:     0   163     0   845     3  2694     2  4049     1  2110     0   120     0     0     0     0     0     1     0     0 : latency    1494722; std 382.65
[ 88 35 14 -- -- -- ]:     0   213     1  1118     0  2883     1  3766     0  1898     0    90     0     0     0     1     0     0     0     0 : latency    1492274; std 367.57
[ 88 35 15 -- -- -- ]:     0   134     1   890     0  2687     0  4027     0  2136     0   108     0     0     0     1     0     0     0     0 : latency    1494703; std 377.96
[ 88 35 16 -- -- -- ]:     0   137     0   920     0  2769     1  3965     0  2082     0   112     0     0     0     0     0     1     0     0 : latency    1494339; std 376.03
[ 88 35 17 -- -- -- ]:     0   155     0   865     2  2652     1  4082     0  2120     0   103     0     0     0     0     0     1     0     0 : latency    1494673; std 381.47
[ 88 35 18 -- -- -- ]:     0   350     0  1483     1  3257     2  3350     0  1442     0    63     0     0     0     0     0     1     0     0 : latency    1488045; std 356.93
[ 88 35 19 -- -- -- ]:     0   131     0   872     2  2699     0  4036     1  2130     0   106     0     0     0     0     0     0     0     1 : latency    1494709; std 378.65
[ 88 35 20 -- -- -- ]:     1   881     0  2688     2  4057     1  2097     0   121     0     0     0     1     0     0     0     0     0     0 : latency    1474714; std 382.93
[ 88 35 21 -- -- -- ]:     0   150     0   882     1  2652     0  4050     2  2142     0   106     0     0     0     0     0     1     0     0 : latency    1494739; std 378.09
[ 88 35 22 -- -- -- ]:     0   136     0   951     0  2677     1  4045     2  2055     0   111     0     0     0     0     0     1     0     0 : latency    1494283; std 378.97
[ 88 35 23 -- -- -- ]:     0   148     0   850     2  2689     1  4053     0  2138     0   100     0     0     0     0     0     1     0     0 : latency    1494723; std 383.72
[ 88 35 24 -- -- -- ]:     0   202     0  1056     1  2980     0  3799     0  1826     0   102     0     0     0     1     0     0     0     0 : latency    1492269; std 369.04
[ 88 35 25 -- -- -- ]:     0   149     0   809     0  2752     1  4061     1  2092     0   116     0     0     0     0     0     1     0     0 : latency    1494746; std 380.68
[ 88 35 26 -- -- -- ]:     0   132     0   930     0  2779     1  3925     1  2102     0   108     0     0     0     0     0     1     0     0 : latency    1494274; std 374.62
[ 88 35 27 -- -- -- ]:     0   152     0   837     0  2700     1  4092     1  2086     0   114     0     0     0     0     0     1     0     0 : latency    1494716; std 380.59
[ 88 35 28 -- -- -- ]:     1   325     0  1502     1  3235     0  3410     0  1398     0    70     0     0     0     0     0     1     0     0 : latency    1488050; std 358.59
[ 88 35 29 -- -- -- ]:     0   130     0   866     1  2700     1  4058     0  2105     0   117     0     0     0     0     0     1     0     0 : latency    1494738; std 379.26
[ 88 35 30 -- -- -- ]:     0   672     0  2317     1  3840     0  2535     0   493     0    26     0     0     0     1     0     0     0     0 : latency    1479045; std 363.91
[ 88 35 31 -- -- -- ]:     1   122     0   905     0  2718     2  3998     0  2132     0   104     0     0     0     0     0     1     0     0 : latency    1494621; std 379.63
[ 88 35 32 -- -- -- ]:     0   152     0   920     1  2794     2  3914     1  2095     0   107     0     0     0     0     0     0     0     0 : latency    1494186; std 376.42
[ 88 35 33 -- -- -- ]:     0   139     0   874     1  2731     1  4005     1  2123     0   105     0     0     0     1     0     0     0     0 : latency    1494593; std 379.96
[ 88 35 34 -- -- -- ]:     0   230     0  1114     0  2903     0  3765     0  1861     0    99     0     0     0     1     0     0     0     0 : latency    1492134; std 360.47
[ 88 35 35 -- -- -- ]:     0   147     0   887     0  2722     2  4010     2  2108     0   114     0     0     0     0     0     1     0     0 : latency    1494618; std 377.38
[ 88 35 36 -- -- -- ]:     0   146     0   945     1  2740     0  3981     0  2067     0   103     0     0     0     0     0     1     0     0 : latency    1494155; std 373.40
[ 88 35 37 -- -- -- ]:     0   132     0   895     3  2703     3  4014     0  2122     0   109     0     0     0     1     0     0     0     0 : latency    1494618; std 379.54
[ 88 35 38 -- -- -- ]:     1   365     0  1502     1  3235     0  3417     0  1377     0    68     0     0     0     0     0     1     0     0 : latency    1487956; std 358.73
[ 88 35 39 -- -- -- ]:     0   139     1   872     0  2762     1  3947     0  2163     0    95     0     0     0     0     0     1     0     0 : latency    1494572; std 381.05
[ 88 35 40 -- -- -- ]:     1   903     0  2776     0  3949     1  2077     0   120     0     0     0     1     0     0     0     0     0     0 : latency    1474278; std 374.86
[ 88 35 41 -- -- -- ]:     0   841     2  2743     0  3999     0  2144     0   110     0     0     0     0     0     1     0     0     0     0 : latency    1474774; std 376.06
[ 88 35 42 -- -- -- ]:     0   163     0   935     1  2716     1  3995     0  2058     0   119     0     0     0     0     0     1     0     0 : latency    1494224; std 377.22
[ 88 35 43 -- -- -- ]:     0   133     0   868     0  2723     2  4009     1  2134     0   113     0     0     0     0     0     1     0     0 : latency    1494751; std 377.99
[ 88 35 44 -- -- -- ]:     0   211     0  1068     1  2904     3  3877     2  1808     0    96     0     0     0     0     0     1     0     0 : latency    1492294; std 372.29
[ 88 35 45 -- -- -- ]:     0   144     1   850     1  2746     1  4019     0  2108     0   118     0     0     0     0     0     0     0     1 : latency    1494707; std 382.95
[ 88 35 46 -- -- -- ]:     0   155     0   895     1  2768     0  3983     0  2068     0   113     0     0     0     0     0     1     0     0 : latency    1494287; std 374.17
[ 88 35 47 -- -- -- ]:     0   134     0   854     0  2736     1  4049     0  2083     0   126     0     0     0     0     0     0     0     1 : latency    1494725; std 379.37
[ 88 35 48 -- -- -- ]:     0   358     1  1479     1  3242     1  3422     0  1378     0    73     0     0     0     1     0     0     0     0 : latency    1488007; std 361.12
[ 88 35 49 -- -- -- ]:     0   124     1   904     0  2713     2  3994     0  2136     0   116     0     0     0     0     0     1     0     0 : latency    1494881; std 374.88
[ 88 35 50 -- -- -- ]:     0   696     1  2251     2  3865     0  2547     0   494     0    22     0     0     0     1     0     0     0     0 : latency    1479037; std 366.05
[ 88 35 51 -- -- -- ]:     0   165     0   845     3  2728     1  3985     0  2140     0   116     0     0     0     0     0     0     0     1 : latency    1494658; std 376.52
[ 88 35 52 -- -- -- ]:     0   165     0   922     1  2719     0  4006     0  2059     0   112     0     0     0     1     0     0     0     0 : latency    1494197; std 375.76
[ 88 35 53 -- -- -- ]:     0   152     0   867     0  2745     3  3988     1  2115     1   115     0     0     0     0     0     1     0     0 : latency    1494597; std 381.27
[ 88 35 54 -- -- -- ]:     0   231     0  1079     0  2954     1  3772     0  1838     0   103     0     0     0     0     0     1     0     0 : latency    1492181; std 366.75
[ 88 35 55 -- -- -- ]:     0   151     1   865     0  2731     0  3995     0  2128     0   111     0     0     0     1     0     0     0     0 : latency    1494599; std 379.35
[ 88 35 56 -- -- -- ]:     0   152     0   939     1  2702     0  4032     1  2037     0   116     0     0     0     1     0     0     0     0 : latency    1494184; std 378.44
[ 88 35 57 -- -- -- ]:     0   139     0   885     1  2710     0  4028     1  2099     0   117     0     0     0     0     0     1     0     0 : latency    1494590; std 379.88
[ 88 35 58 -- -- -- ]:     1   353     0  1481     0  3268     0  3405     0  1373     0    72     0     0     0     0     0     1     0     0 : latency    1487945; std 359.21
[ 88 35 59 -- -- -- ]:     0   141     0   877     1  2773     0  3976     3  2096     0   122     0     0     0     0     0     0     0     1 : latency    1494578; std 376.86
[ 88 35 60 -- -- -- ]:     0   874     0  2643     1  4113     0  2072     0   121     0     1     0     0     0     0     0     0     0     0 : latency    1474647; std 377.34
[ 88 35 61 -- -- -- ]:     0   137     0   895     0  2732     0  3960     0  2139     0   116     0     1     0     0     0     0     0     0 : latency    1494584; std 373.41
[ 88 35 62 -- -- -- ]:     0   162     0   920     0  2719     1  4022     0  2046     0   110     0     0     0     0     0     1     0     0 : latency    1494165; std 374.17
[ 88 35 63 -- -- -- ]:     0   135     0   890     0  2742     1  3953     1  2146     0   112     0     0     0     0     0     1     0     0 : latency    1494608; std 377.98
[ 88 35 64 -- -- -- ]:     0   237     0  1080     2  2907     2  3808     0  1849     0    85     0     0     0     0     0     1     0     0 : latency    1492114; std 369.36
[ 88 35 65 -- -- -- ]:     0   146     1   861     0  2722     1  4031     0  2105     0   116     0     0     0     0     0     0     0     1 : latency    1494654; std 378.35
[ 88 35 66 -- -- -- ]:     0   147     0   937     4  2730     0  4000     0  2050     0   110     0     0     0     0     0     1     0     0 : latency    1494144; std 375.73
[ 88 35 67 -- -- -- ]:     0   139     1   862     0  2733     4  4026     1  2107     0   108     0     0     0     0     0     1     0     0 : latency    1494622; std 380.76
[ 88 35 68 -- -- -- ]:     0   357     1  1465     1  3252     0  3433     0  1353     0    83     0     1     0     0     0     0     0     0 : latency    1487952; std 361.42
[ 88 35 69 -- -- -- ]:     0   131     0   886     0  2730     0  4027     0  2101     0   108     0     0     0     1     0     0     0     0 : latency    1494590; std 374.24
[ 88 35 70 -- -- -- ]:     1   705     0  2261     2  3851     0  2554     1   495     0    26     0     0     0     0     0     1     0     0 : latency    1479144; std 368.16
[ 88 35 71 -- -- -- ]:     0   147     2   864     0  2718     0  3988     2  2150     0   115     0     0     0     1     0     0     0     0 : latency    1494744; std 379.05
[ 88 35 72 -- -- -- ]:     0   152     1   911     2  2749     3  3969     0  2082     0   113     0     0     0     1     0     0     0     0 : latency    1494284; std 379.62
[ 88 35 73 -- -- -- ]:     0   126     0   886     0  2732     0  3982     0  2152     0   106     0     0     0     1     0     0     0     0 : latency    1494714; std 375.26
[ 88 35 74 -- -- -- ]:     0   213     0  1096     2  2931     1  3779     0  1866     0    88     0     0     0     0     0     1     0     0 : latency    1492245; std 367.18
[ 88 35 75 -- -- -- ]:     0   165     0   830     1  2717     2  4014     0  2151     0   106     0     0     0     1     0     0     0     0 : latency    1494747; std 378.20
[ 88 35 76 -- -- -- ]:     0   164     0   939     0  2679     1  4006     0  2082     0   115     0     0     0     0     0     1     0     0 : latency    1494297; std 372.76
[ 88 35 77 -- -- -- ]:     0   129     0   880     3  2742     0  4014     0  2106     0   115     0     0     0     1     0     0     0     0 : latency    1494677; std 378.39
[ 88 35 78 -- -- -- ]:     1   338     0  1484     3  3285     1  3401     0  1364     0    79     0     0     0     1     0     0     0     0 : latency    1488016; std 364.33
[ 88 35 79 -- -- -- ]:     0   140     0   834     1  2815     1  3933     0  2149     0   115     0     0     0     0     0     0     0     1 : latency    1494736; std 379.43
[ 88 35 80 -- -- -- ]:     0  1063     0  2923     1  3844     0  1835     0    84     0     0     0     1     0     0     0     0     0     0 : latency    1472243; std 369.59
[ 88 35 81 -- -- -- ]:     0   857     1  2730     0  4005     0  2141     0   109     0     0     0     0     0     1     0     0     0     0 : latency    1474731; std 378.15
[ 88 35 82 -- -- -- ]:     0   897     0  2725     0  4015     0  2064     0   118     0     0     0     1     0     0     0     0     0     0 : latency    1474316; std 376.47
[ 88 35 83 -- -- -- ]:     0   870     0  2721     1  3965     1  2165     0   113     0     0     0     0     0     1     0     0     0     0 : latency    1474718; std 378.24
[ 88 35 84 -- -- -- ]:     0   216     0  1054     0  2971     1  3813     1  1799     0   115     0     0     0     0     0     1     0     0 : latency    1492248; std 368.67
[ 88 35 85 -- -- -- ]:     0   142     0   856     1  2755     0  3971     0  2145     0   117     0     0     0     0     0     0     0     1 : latency    1494751; std 374.93
[ 88 35 86 -- -- -- ]:     0   158     1   908     0  2688     1  4064     0  2044     0   113     0     0     0     0     0     1     0     0 : latency    1494276; std 379.80
[ 88 35 87 -- -- -- ]:     0   151     1   865     1  2706     0  4020     3  2119     0   125     0     0     0     0     0     1     0     0 : latency    1494767; std 379.61
[ 88 35 88 -- -- -- ]:     0   341     0  1532     1  3243     0  3325     1  1446     0    68     0     0     0     0     0     1     0     0 : latency    1488038; std 355.96
[ 88 35 89 -- -- -- ]:     0   152     0   868     1  2705     1  3993     2  2141     0   121     0     0     0     1     0     0     0     0 : latency    1494722; std 380.71
[ 88 35 90 -- -- -- ]:     0   699     0  2252     1  3862     1  2539     0   496     0    25     0     0     0     1     0     0     0     0 : latency    1479022; std 365.58
[ 88 35 91 -- -- -- ]:     0   152     0   857     0  2742     0  4046     0  2076     0   116     0     0     0     1     0     0     0     0 : latency    1494582; std 377.07
[ 88 35 92 -- -- -- ]:     0   135     1   948     1  2760     1  3941     1  2085     0   110     0     1     0     0     0     0     0     0 : latency    1494224; std 378.88
[ 88 35 93 -- -- -- ]:     0   143     1   877     0  2726     0  4009     0  2109     0   115     0     1     0     0     0     0     0     0 : latency    1494575; std 375.17
[ 88 35 94 -- -- -- ]:     0   229     0  1078     0  2968     2  3749     0  1851     0    95     0     0     0     1     0     0     0     0 : latency    1492112; std 366.33
[ 88 35 95 -- -- -- ]:     0   157     0   842     1  2774     0  3973     0  2126     0   114     0     0     0     1     0     0     0     0 : latency    1494623; std 377.31
[ 88 35 96 -- -- -- ]:     0   155     0   955     0  2769     1  3902     1  2091     0   114     0     0     0     0     0     1     0     0 : latency    1494136; std 374.82
[ 88 35 97 -- -- -- ]:     0   148     1   881     0  2762     0  3907     0  2175     0   114     0     0     0     0     0     1     0     0 : latency    1494653; std 372.35
[ 88 35 98 -- -- -- ]:     0   328     0  1550     1  3178     0  3433     0  1398     0    60     0     0     0     0     0     1     0     0 : latency    1487977; std 353.37
[ 88 35 99 -- -- -- ]:     0   131     0   895     0  2721     1  3991     0  2127     0   111     0     0     0     0     0     1     0     0 : latency    1494589; std 374.58
0: 49 lat = 1494881
1: 87 lat = 1494767
2: 43 lat = 1494751
3: 85 lat = 1494751
4: 75 lat = 1494747
95: 02 lat = 1474170
96: 80 lat = 1472243
97: 04 lat = 1472121
98: 07 lat = 1469725
99: 00 lat = 1467937
0: 23 std = 383.72
1: 12 std = 383.26
2: 45 std = 382.95
3: 20 std = 382.93
4: 13 std = 382.65
95: 18 std = 356.93
96: 88 std = 355.96
97: 00 std = 355.68
98: 98 std = 353.37
99: 07 std = 352.35
lat_k 0-1 0.01%, lat_k 98-99 0.12%, lat_k 0-99 1.84%
std_k 0-1 0.12%, std_k 98-99 0.29%, std_k 0-99 8.90%
pin[2] choose candidate: 07 based on std
Candidate PIN 88 35 07 -- -- -- : brute forcing bytes 3 to 5 (3 bytes), will take up to 703 seconds
Progress: 0%..5%..10%..15%..20%..25%..30%..35%..40%..45%..50%..55%..60%..65%..70%..75%..80%..85%..90%..95%..
PIN is NOT cracked in 2809.39 seconds
done
Resetting all ECUs.
CAN_HS ---> ID=000ffffe data=ff c8 00 00 00 00 00 00
CAN_LS ---> ID=000ffffe data=ff c8 00 00 00 00 00 00
raikonen
Post by raikonen »
RickHaleParker wrote: 25 Jul 2021, 05:14 Come on ... trim the quotes.
sorry
p.s.Image
Thank you guys
RickHaleParker
raikonen wrote: 25 Jul 2021, 07:07 Thank you guys
You don't need a camera. Use the key [PrntScn] ( Print Screen ) then look in the folder Pictures\Screenshots\ .
Active
Past
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
ricked wrote: 25 Jul 2021, 06:33 need some help with V50 CEM 30728906 on bench
What year is it? I've heard 2010+ don't want to crack.
urosm
Year and Model: 2015 Volvo XC70 D5
Has thanked: 10 times
Post by urosm »
vtl wrote: 24 Jul 2021, 21:09 Make sure you have common ground with the OBD-II connector.
I connect common ground with the OBD-II connector.
He won't continue to read the PIN, but he behaves differently.
Here are photos:
I tried cracker on 2004 V70 and 2005 V70. Both D5.
This schematic I used:
Volvo 744 TDIC SOLD, 1989. ; 1997. - 2000.
Volvo 855 GLT + LPG Estate SOLD, 1996. ; 1998. - 2020.
Volvo V70 D5 SOLD, 2004. ; 2013. - 2021.
Volvo XC70 D5 SOLD, 2007. ; 2017. - 2021.
Nissan Pathfinder DRIVING, 2007. ; 2019. -
Volvo XC70 D5 DRIVING, 2015. ; 2021. -
Volvo XC90 D5 DRIVING, 2008. ; 2022. -
vtl
Post by vtl »
2004 will not work.
RickHaleParker
vtl wrote: 25 Jul 2021, 08:41 What year is it? I've heard 2010+ don't want to crack.
I got a 2011 CEM-H to crack. Had to set it to 100 samples. That was the first Frankenstein CEM.
Active
Past
RickHaleParker
urosm wrote: 25 Jul 2021, 09:36
The 2004 V70 is a CEM-B. The side attack does not work on a CEM-B.
The 2005 V70 is a CEM-L. The side attack does works on the CEM-L.
Schematic is good.
If you are cracking in-car. the battery needs to be in good health and fully charged. A CEM may stop responding to the carcker if the voltage is low.
Did you cut the trace between V-USB and V-IN on the back of the Teensy 4.0?
How about some pictures of your CEM cracker. So we can look for possible problems.
Active
Past
