Odd I can hook up my DiCE and it connects under the same conditions. I have power to D:8, D15 & D16. That is suppose to keep it alive.vtl wrote: 26 Jul 2021, 11:16Start with the CEM being powered off. Press the reset button on Teensy, wait for "Sending blah-blah", sharply apply the power to the CEM. You have about 20 ms from the CEM's on-the-bench start to send the programming mode messages, otherwise it goes into a sleeping/idle mode.
Tried it in car on my 2005 XC90. Same results not reading PN. But see the overhead dome light go on and off as it goes in and out of programing mode. However the DIM is not blanking and the radio does not shut down.
What I meant was if auto detect is not defined you don't need the part number because auto detect is undefined when testing a CEM-L. You can deduce that it is a CEM-L from the fact that auto detect is undefined.
A hardware and communication test routine Sketch would be handy for trouble shooting.
