2007 S80 3.2 FWD Auto -Not responding to throttle
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
So twice now, dearest spouse has mentioned she has trod on the accelerator, had the engine RPMs increase, but no corresponding increase in forward momentum.
Car had its 150K mile service recently and mileage is probably right about at 150K miles.
Any ideas what might be going on? No codes, no CEL. Wife says it tends to happen in high heat with AC on.
I have been unable to reproduce this fault.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 120 times
Been thanked: 189 times
Post by pgill »
Your problem sounds more like a transmission problem than a Engine or Accelerator pedal problem.
Try shifting into Manual mode and changing the gear when the problem occurs.
If the Transmission thinks that you are requesting neutral instead of drive it would do exactly what you have described.
What does the cluster show when the problem occurs D or N?
If you lean on the gear selector can you get it to go from D to N?
Good luck
Paul
E Showell
Post by E Showell »
That was my sense of things as well. But thanks, for responding.
'95 855 auto (sold)
Has thanked: 1609 times
Been thanked: 4065 times
Check ATF fluid level to make sure you arent just down and the TC is running a bit dry. Unlike the engine, this wont damage it, it will just lose transfer of torque.
