Hi all
I am hearing a pop coming from around my exhaust cam area when I turn the crank by hand. It sounds almost like opening a corked bottle.
Thanks
Nicm
Popping from engine when turning crank by hand
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Do you have the spark plugs in still? I had a little pop and hiss when hand cranking my engine once, I assumed it was just the cylinders pressurizing a little and then releasing.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- Has thanked: 987 times
- Been thanked: 1075 times
What is the engine history? Has the timing belt been removed or loosened since it ran? Any other thing that may change valve timing?
Do the timing marks for both cams and the crankshaft line up as required? If not, you can have valve to piston interference.
- 570 Views
- 1447 Views
Last post by oragex
- 1984 Views
Last post by matthew1
- 807 Views
Last post by erikv11
- 11 Replies
- 3581 Views
Last post by hunterhuni
