Hi everyone,
well i am getting tired of holding down the button to get my AC to stay on, i took apart a backup one i had and managed to break the push button switch. Took some measurements and found this seems to be the same switch available on digikey.
https://www.digikey.ca/en/products/deta ... FP/2296958
17.5mm height, 6mm wide pins, 5mm spacing between pins.
This seems to match up with what i got from the broken board.
I'll try to desolder on the dummy board first before going to the current good one.
Hoping this will keep it fixed. Anyways if you are looking for a part that will fit then i believe the one above is good,
More photos to come
Bad MCC push button connection | Replacement Part
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
2008 S60 2.5T Auto (Sold)
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
I've not yet had mine apart, but I'd love to see pictures of the board. I've got an indicator light that's not working. Do you have any fancy soldering equipment?
yanga001
Added photos
- 1447 Views
Last post by Xaver
- 1152 Views
- 2462 Views
Last post by Pedey
- 1236 Views
Last post by oizdaman26
- 1150 Views
Last post by Vova585
