Have replaced head. Turned over by hand 5-6 times. Ready to start. Cranks, no start. Timings is on.
I have Fuel, spark, compression in 1,3,5. Used borascope to look at valves in 2/4. Intakes are open. No movement of valves as the engine is hand cranked. Pistons moves. Doesn’t look like there is any contact.
Could I possibly have reversed the cams on install?
What could cause the valves to stick open?
I’m currently tearing it back down but, decided to see what ya’lls thoughts are before I get to crazy and tear it all the down to the block. AGAIN!
I love these cars but, it’s always something.
Thank you
Stephan
06 s60 no valve movement
stephansvolvo
- Year and Model: V70 GLT 1998
- Has thanked: 21 times
- Been thanked: 3 times
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
stephansvolvo
Valves are good. Looks like I didn’t have the timing gears torqued down so the cam wasn’t moving. The rear was but not the intake. Whew!!!
Does anyone know how he torque spec for the variable cone on the cams?
Stephan
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
not so fast, engine cam setup was in the non interference position.ignatz wrote: 02 Aug 2021, 05:39 If the engine turned over, with one cam not moving........you bent a couple of valves.
Center bolt torque is 88ft lbs.
- Been thanked: 4069 times
No, engine was cranked with the intake VVT loose, so cam stays still and interferes.
stephansvolvo
abscate wrote: 02 Aug 2021, 08:14No, engine was cranked with the intake VVT loose, so cam stays still and interferes.
I have pulled the cam cover and cams. I will boroscope the valve positions again to see if they are closed or open. I will place the cam cover back in and set up the VVT according to what I’ve researched. Making sure I get that 88flb. Then turn it over a coupled of times as I have someone watch the backs.
If I pull the intake manifold can I see the valve stems enough to determine they’re status?
I am really trying to avoid pulling everything apart if I don’t HAVE to.
Thank you for your input and help.
Stephan
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
- jonesg
err, the initial set up with the crank set to the timing mark on the crank pulley ensures the engine is in a non interference position.abscate wrote: 02 Aug 2021, 08:14No, engine was cranked with the intake VVT loose, so cam stays still and interferes.
As long as the cam stays still it remains in a safe position.
- 2138 Views
- 1376 Views
- 14 Replies
- 2688 Views
Last post by mecheng
- 1778 Views
Last post by Sommerfeldt
- 9 Replies
- 1885 Views
Last post by rspi
