06 s60 no valve movement
stephansvolvo
Year and Model: V70 GLT 1998
Has thanked: 21 times
Been thanked: 3 times
Post by stephansvolvo »
Have replaced head. Turned over by hand 5-6 times. Ready to start. Cranks, no start. Timings is on.
I have Fuel, spark, compression in 1,3,5. Used borascope to look at valves in 2/4. Intakes are open. No movement of valves as the engine is hand cranked. Pistons moves. Doesn’t look like there is any contact.
Could I possibly have reversed the cams on install?
What could cause the valves to stick open?
I’m currently tearing it back down but, decided to see what ya’lls thoughts are before I get to crazy and tear it all the down to the block. AGAIN!
I love these cars but, it’s always something.
Thank you
Stephan
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
If you watch the back ends of the cam shafts, do they rotate when you hand crank the crankshaft? Sounds like you may have bent valve stems on 2/4.
chrism
Post by chrism »
….or a couple valve springs came lose??
stephansvolvo
Valves are good. Looks like I didn’t have the timing gears torqued down so the cam wasn’t moving. The rear was but not the intake. Whew!!!
Does anyone know how he torque spec for the variable cone on the cams?
Stephan
98 S70 GLT
73 IH Scout ii
ignatz
Year and Model: 2006 S60 t5m
Has thanked: 18 times
Been thanked: 33 times
Post by ignatz »
If the engine turned over, with one cam not moving........you bent a couple of valves.
2002 V70 2.4
2005 S60 2.5t awd
2006 S60 t5 stick shift
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
ignatz wrote: 02 Aug 2021, 05:39 If the engine turned over, with one cam not moving........you bent a couple of valves.
not so fast, engine cam setup was in the non interference position.
Center bolt torque is 88ft lbs.
ignatz
Post by ignatz »
Check compression or leak down and cross fingers. All it takes is one valve.
2002 V70 2.4
2005 S60 2.5t awd
Has thanked: 1611 times
Been thanked: 4073 times
jonesg wrote: 02 Aug 2021, 05:59
No, engine was cranked with the intake VVT loose, so cam stays still and interferes.
stephansvolvo
abscate wrote: 02 Aug 2021, 08:14
I have pulled the cam cover and cams. I will boroscope the valve positions again to see if they are closed or open. I will place the cam cover back in and set up the VVT according to what I’ve researched. Making sure I get that 88flb. Then turn it over a coupled of times as I have someone watch the backs.
If I pull the intake manifold can I see the valve stems enough to determine they’re status?
I am really trying to avoid pulling everything apart if I don’t HAVE to.
Thank you for your input and help.
Stephan
98 S70 GLT
73 IH Scout ii
jonesg
Post by jonesg »
err, the initial set up with the crank set to the timing mark on the crank pulley ensures the engine is in a non interference position.
As long as the cam stays still it remains in a safe position.
