Vida CEM swapping
NuovoRecord
- Year and Model: 2004 V70
This is such a cool and useful project. Is there any chance that it will work on 2004s soon?
- RickHaleParker
- Been thanked: 980 times
If somebody can come up with a side attack that works on a P2 CEM-B ( MY -2004 ). So far nobody has found anything exploitable.NuovoRecord wrote: 01 Aug 2021, 21:20 This is such a cool and useful project. Is there any chance that it will work on 2004s soon?
The side attack we have how works on P1, P2 CEM-L & CEM-H ( MY 2005+ ).
Active
Past
Past
ricked
- Year and Model: xc90
- Has thanked: 6 times
- Been thanked: 2 times
pincode is 223549122494 and is correct as i did login with itvtl wrote: 01 Aug 2021, 08:58 "DBG NORM: -1" is printed by the FlexCAN_T4 library: https://github.com/tonton81/FlexCAN_T4/ ... .tpp#L1092 I don't know what it means.
Could you paste the log for the first byte, and also the pin you read with xprog/ioterminal?
second log in my post is the one this pin belongs to so the one the cracker can not read, but the part number is in the script
Part Number: 30765015
V50 year 2006 cem with 2x 0L01Y MCU’s
first outcome was:
48 33 -- -- -- --
second:
58 28 68 -- -- --
- RickHaleParker
RHP PT V2.1 Its cracking.
Did way with the Buck Converter. Tennesy 4.0 100mA, Bosch CF160 80mA. 100 mA + 2 x 80mA = 260mA. Not going to over load any USB port. No terminating resistors. Just the Tennsy 4.0 and two Bosch CF160 CAN transceivers.
Active
Past
Past
ricked
just run it? no need to edit something in script?
edit
pin found!! with new script and its faster in my case also
if the latency approach does not work must we comment it out or leave it in as old script works with my spare?
log for your info:
Code: Select all
CPU Maximum Frequency: 600000000
CPU Frequency: 600000000
Execution Rate: 600 cycles/us
PIN bytes to measure: 3
Number of samples: 100
CAN low-speed init done.
Reading part number from ECU 0x40 on CAN_LS
CAN_LS ---> ID=000ffffe data=cb 40 b9 f0 00 00 00 00
CAN_LS <--- ID=04301090 data=00 00 00 00 00 00 00 00
CAN_LS <--- ID=09c050b8 data=48 00 02 00 00 00 00 4c
CAN_LS <--- ID=19f010f8 data=80 00 00 00 00 00 05 60
CAN_LS <--- ID=00600005 data=8f 40 f9 f0 00 30 76 50
CAN_LS <--- ID=065373ba data=c4 00 20 c0 1b 00 00 9c
CAN_LS <--- ID=0a90f698 data=08 d3 00 00 00 00 00 00
CAN_LS <--- ID=13f041ba data=00 40 1f ff 80 00 00 00
CAN_LS <--- ID=1ad10068 data=28 44 00 00 fc 43 33 24
CAN_LS <--- ID=02120498 data=10 00 00 00 00 00 00 00
CAN_LS <--- ID=03c3f7fc data=00 00 00 00 00 20 18 00
CAN_LS <--- ID=00600005 data=09 15 20 20 20 31 26 46
Searching P/N 30765015 in 49 known CEMs
CAN HS baud rate: 500000
PIN shuffle order: 0 1 2 3 4 5
CAN high-speed init done.
Putting all ECUs into programming mode.
CAN_HS ---> ID=000ffffe data=ff 86 00 00 00 00 00 00
CAN_LS ---> ID=000ffffe data=ff 86 00 00 00 00 00 00
Reading part number from ECU 0x50 on CAN_HS
CAN_HS ---> ID=000ffffe data=50 88 00 00 00 00 00 00
CAN_HS <--- ID=00000003 data=50 8e 00 00 30 76 50 15
Initialization done.
Calculating bytes 0-2
1000 pins in 702 ms, 1424 pins/s, average response: 151 us, histogram 75 to 226 us
us: 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162
[ 00 -- -- -- -- -- ]: 0 1152 0 51 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 : latency 1409176; std 380.60
[ 01 -- -- -- -- -- ]: 1 3948 0 1172 0 59 0 0 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1429267; std 384.68
[ 02 -- -- -- -- -- ]: 0 3921 0 1100 0 59 0 0 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1428705; std 383.71
[ 03 -- -- -- -- -- ]: 0 3978 0 1165 0 58 0 0 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1429236; std 382.72
[ 04 -- -- -- -- -- ]: 0 3572 0 1014 0 42 0 0 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1426698; std 371.28
[ 05 -- -- -- -- -- ]: 0 3978 0 1180 0 46 0 0 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1429280; std 382.96
[ 06 -- -- -- -- -- ]: 0 3840 0 1135 0 56 0 0 0 0 0 1 0 0 0 0 0 0 0 0 : latency 1428712; std 380.59
[ 07 -- -- -- -- -- ]: 0 3948 0 1188 0 48 0 0 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1429296; std 383.47
[ 08 -- -- -- -- -- ]: 0 2964 0 773 0 28 0 0 0 0 0 1 0 0 0 0 0 0 0 0 : latency 1422534; std 360.88
[ 09 -- -- -- -- -- ]: 0 3935 0 1180 0 58 0 0 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1429318; std 383.00
[ 10 -- -- -- -- -- ]: 0 1722 0 268 0 10 0 0 0 0 0 1 0 0 0 0 0 0 0 0 : latency 1413580; std 369.88
[ 11 -- -- -- -- -- ]: 0 3977 0 1187 0 54 0 0 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1429270; std 381.46
[ 12 -- -- -- -- -- ]: 0 3893 0 1150 0 61 0 0 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1428696; std 376.47
[ 13 -- -- -- -- -- ]: 0 3941 0 1169 0 64 0 0 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1429314; std 382.90
[ 14 -- -- -- -- -- ]: 0 3516 0 1029 0 54 0 0 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1426598; std 367.42
[ 15 -- -- -- -- -- ]: 0 3959 0 1209 0 44 0 0 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1429308; std 383.80
[ 16 -- -- -- -- -- ]: 0 3766 0 1164 0 71 0 0 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1428686; std 376.70
[ 17 -- -- -- -- -- ]: 0 3903 0 1202 0 62 0 0 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1429278; std 380.51
[ 18 -- -- -- -- -- ]: 0 2882 0 807 0 21 0 0 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1422518; std 358.89
[ 19 -- -- -- -- -- ]: 0 3887 0 1177 0 66 0 0 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1429264; std 382.68
[ 20 -- -- -- -- -- ]: 0 3967 0 1178 0 61 0 0 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1429314; std 381.91
[ 21 -- -- -- -- -- ]: 0 3391 0 3887 0 1177 0 55 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1449120; std 382.13
[ 22 -- -- -- -- -- ]: 0 1445 0 3521 0 3642 0 973 0 12 0 1 0 0 0 0 0 0 0 1 : latency 1466648; std 375.79
[ 23 -- -- -- -- -- ]: 0 3296 1 4006 0 1141 0 54 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1449201; std 386.46
[ 24 -- -- -- -- -- ]: 0 3461 0 3604 0 1013 0 51 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1446802; std 373.15
[ 25 -- -- -- -- -- ]: 0 3330 0 3917 0 1203 0 37 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449150; std 381.70
[ 26 -- -- -- -- -- ]: 0 3300 0 3953 0 1124 0 56 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1448856; std 379.37
[ 27 -- -- -- -- -- ]: 0 3341 0 3941 0 1169 0 48 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449146; std 382.98
[ 28 -- -- -- -- -- ]: 0 3708 0 2968 0 758 0 29 0 0 0 1 0 0 0 0 0 0 0 0 : latency 1442621; std 363.91
[ 29 -- -- -- -- -- ]: 0 3328 0 3937 0 1184 0 38 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449156; std 382.76
[ 30 -- -- -- -- -- ]: 0 3855 0 1770 0 279 0 11 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1433642; std 366.25
[ 31 -- -- -- -- -- ]: 0 3354 0 3906 0 1200 0 42 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449210; std 382.11
[ 32 -- -- -- -- -- ]: 0 3327 0 3863 0 1195 0 40 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1448832; std 376.25
[ 33 -- -- -- -- -- ]: 0 3364 0 3894 0 1193 0 41 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1449164; std 382.32
[ 34 -- -- -- -- -- ]: 0 3506 0 3568 0 1024 0 42 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1446802; std 371.77
[ 35 -- -- -- -- -- ]: 0 3352 0 3902 0 1179 0 57 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449172; std 381.52
[ 36 -- -- -- -- -- ]: 0 3305 0 3864 0 1184 0 47 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1448790; std 377.82
[ 37 -- -- -- -- -- ]: 0 3362 0 3896 0 1176 0 58 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1449184; std 381.80
[ 38 -- -- -- -- -- ]: 0 3673 1 2966 0 789 0 25 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1442607; std 360.53
[ 39 -- -- -- -- -- ]: 0 3397 0 3901 0 1192 0 47 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1449242; std 383.25
[ 40 -- -- -- -- -- ]: 0 3852 0 1146 0 49 0 0 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1428726; std 382.72
[ 41 -- -- -- -- -- ]: 0 3884 0 1215 0 50 0 0 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1429340; std 379.78
[ 42 -- -- -- -- -- ]: 0 3394 0 3811 0 1174 0 48 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1448766; std 378.93
[ 43 -- -- -- -- -- ]: 0 3323 2 3959 0 1175 0 54 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1449294; std 385.34
[ 44 -- -- -- -- -- ]: 0 3426 0 3608 0 1014 0 42 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1446740; std 370.50
[ 45 -- -- -- -- -- ]: 0 3396 0 3867 0 1215 0 47 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1449272; std 381.87
[ 46 -- -- -- -- -- ]: 0 3364 0 3845 0 1162 0 47 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1448758; std 379.36
[ 47 -- -- -- -- -- ]: 0 3342 0 3917 0 1211 0 41 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449302; std 382.31
[ 48 -- -- -- -- -- ]: 0 3585 0 3005 0 754 0 39 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1442482; std 356.48
[ 49 -- -- -- -- -- ]: 0 3371 0 3894 0 1199 0 58 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449268; std 381.62
[ 50 -- -- -- -- -- ]: 0 3996 0 1673 0 265 0 15 0 0 0 1 0 0 0 0 0 0 0 0 : latency 1433588; std 370.59
[ 51 -- -- -- -- -- ]: 0 3318 0 3958 0 1185 0 52 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1449320; std 382.93
[ 52 -- -- -- -- -- ]: 0 3335 0 3837 0 1163 0 53 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1448704; std 375.48
[ 53 -- -- -- -- -- ]: 1 3370 0 3884 0 1228 0 47 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1449383; std 383.91
[ 54 -- -- -- -- -- ]: 0 3400 0 3558 0 1037 0 45 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1446670; std 367.57
[ 55 -- -- -- -- -- ]: 0 3305 0 3949 0 1201 0 49 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449332; std 382.11
[ 56 -- -- -- -- -- ]: 0 3371 0 3869 0 1149 0 50 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1448766; std 380.30
[ 57 -- -- -- -- -- ]: 0 3352 0 3926 0 1202 0 48 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449340; std 382.79
[ 58 -- -- -- -- -- ]: 0 3635 0 2918 0 802 0 31 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1442482; std 356.26
[ 59 -- -- -- -- -- ]: 0 3334 1 3934 0 1198 0 47 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449283; std 384.63
[ 60 -- -- -- -- -- ]: 1 3955 0 1172 0 58 0 0 0 0 0 1 0 0 0 0 0 0 0 0 : latency 1429299; std 385.04
[ 61 -- -- -- -- -- ]: 0 3392 1 3919 0 1151 0 54 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1449169; std 386.34
[ 62 -- -- -- -- -- ]: 0 3416 0 3819 0 1176 0 58 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1448866; std 379.43
[ 63 -- -- -- -- -- ]: 0 3379 0 3890 0 1179 0 59 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449194; std 381.98
[ 64 -- -- -- -- -- ]: 0 3492 1 3568 0 1012 0 55 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1446803; std 375.45
[ 65 -- -- -- -- -- ]: 0 3406 0 3935 0 1141 0 55 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449212; std 387.66
[ 66 -- -- -- -- -- ]: 0 3334 0 3870 0 1191 0 38 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1448886; std 379.48
[ 67 -- -- -- -- -- ]: 0 3353 0 3925 0 1166 0 50 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1449192; std 383.37
[ 68 -- -- -- -- -- ]: 0 3660 0 2972 0 779 0 27 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1442608; std 358.94
[ 69 -- -- -- -- -- ]: 0 3401 1 3861 0 1199 0 43 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1449083; std 381.41
[ 70 -- -- -- -- -- ]: 0 3901 0 1774 0 278 0 8 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1433704; std 364.47
[ 71 -- -- -- -- -- ]: 0 3384 0 3925 0 1190 0 42 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1449254; std 383.95
[ 72 -- -- -- -- -- ]: 0 3292 0 3957 0 1127 0 53 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1448852; std 381.45
[ 73 -- -- -- -- -- ]: 0 3367 0 3898 0 1173 0 64 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449216; std 381.71
[ 74 -- -- -- -- -- ]: 0 3467 0 3580 0 1014 0 52 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1446832; std 371.01
[ 75 -- -- -- -- -- ]: 0 3367 0 3926 0 1178 0 51 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1449370; std 378.87
[ 76 -- -- -- -- -- ]: 0 3273 0 3894 0 1177 0 45 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1448818; std 380.42
[ 77 -- -- -- -- -- ]: 0 3387 0 3904 0 1170 0 61 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1449256; std 383.17
[ 78 -- -- -- -- -- ]: 1 3631 0 2974 0 780 0 33 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1442581; std 359.68
[ 79 -- -- -- -- -- ]: 0 3286 0 3966 0 1176 0 45 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449204; std 382.46
[ 80 -- -- -- -- -- ]: 0 3570 0 1025 0 43 0 0 0 1 0 0 0 0 0 0 0 0 0 0 : latency 1426730; std 370.15
[ 81 -- -- -- -- -- ]: 0 3940 0 1193 0 51 0 0 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1429308; std 380.05
[ 82 -- -- -- -- -- ]: 0 3838 0 1178 0 48 0 0 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1428744; std 377.59
[ 83 -- -- -- -- -- ]: 1 3950 0 1196 0 53 0 0 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1429315; std 381.32
[ 84 -- -- -- -- -- ]: 0 3476 0 3557 0 1018 0 50 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1446698; std 369.91
[ 85 -- -- -- -- -- ]: 0 3338 0 3960 0 1176 0 53 0 0 0 1 0 0 0 0 0 0 0 0 : latency 1449344; std 383.99
[ 86 -- -- -- -- -- ]: 0 3376 0 3820 0 1175 0 52 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1448778; std 378.47
[ 87 -- -- -- -- -- ]: 0 3300 0 3945 0 1193 0 50 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1449290; std 382.01
[ 88 -- -- -- -- -- ]: 0 3608 0 2967 0 779 0 29 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1442480; std 359.24
[ 89 -- -- -- -- -- ]: 0 3251 0 3949 0 1219 0 45 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1449282; std 380.25
[ 90 -- -- -- -- -- ]: 0 3960 0 1743 0 262 0 3 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1433624; std 368.00
[ 91 -- -- -- -- -- ]: 0 3358 0 3899 0 1206 0 50 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1449254; std 379.39
[ 92 -- -- -- -- -- ]: 0 3328 0 3903 0 1154 0 41 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1448786; std 378.37
[ 93 -- -- -- -- -- ]: 0 3352 0 3873 0 1225 0 49 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449232; std 380.01
[ 94 -- -- -- -- -- ]: 0 3530 1 3518 0 1050 0 34 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1446759; std 373.03
[ 95 -- -- -- -- -- ]: 0 3324 0 3912 0 1199 0 59 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449260; std 380.73
[ 96 -- -- -- -- -- ]: 0 3360 0 3837 0 1154 0 55 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1448750; std 381.21
[ 97 -- -- -- -- -- ]: 0 3323 0 3949 0 1185 0 53 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449300; std 382.71
[ 98 -- -- -- -- -- ]: 0 3605 0 2970 0 767 0 36 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1442464; std 356.67
[ 99 -- -- -- -- -- ]: 0 3369 0 3905 0 1214 0 40 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1449268; std 380.27
best candidates ordered by latency:
0: 22 lat = 1466648
1: 53 lat = 1449383
2: 75 lat = 1449370
3: 85 lat = 1449344
4: 57 lat = 1449340
95: 14 lat = 1426598
96: 08 lat = 1422534
97: 18 lat = 1422518
98: 10 lat = 1413580
99: 00 lat = 1409176
best candidates ordered by std:
0: 65 std = 387.66
1: 23 std = 386.46
2: 61 std = 386.34
3: 43 std = 385.34
4: 60 std = 385.04
95: 68 std = 358.94
96: 18 std = 358.89
97: 98 std = 356.67
98: 48 std = 356.48
99: 58 std = 356.26
lat_k 0-1 1.19%, lat_k 98-99 0.31%, lat_k 0-99 4.08%
std_k 0-1 0.31%, std_k 98-99 0.06%, std_k 0-99 8.81%
pin[0] choose candidate: 22 (latency only)
[ 22 00 -- -- -- -- ]: 0 1769 0 3757 0 3397 0 568 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1463218; std 377.75
[ 22 01 -- -- -- -- ]: 0 586 0 2183 0 4074 0 3051 0 0 0 0 0 0 0 0 0 0 0 1 : latency 1478620; std 392.59
[ 22 02 -- -- -- -- ]: 0 601 1 2194 0 4102 0 2977 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1478263; std 393.45
[ 22 03 -- -- -- -- ]: 0 575 0 2147 0 4183 0 3001 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1478720; std 396.19
[ 22 04 -- -- -- -- ]: 0 728 0 2479 0 3991 0 2645 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1476316; std 378.37
[ 22 05 -- -- -- -- ]: 0 569 0 2144 0 4111 0 3048 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1478598; std 393.42
[ 22 06 -- -- -- -- ]: 0 688 0 2175 0 4013 0 3028 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1478242; std 385.88
[ 22 07 -- -- -- -- ]: 0 576 1 2157 0 4138 0 3028 0 0 0 0 0 0 0 0 0 0 0 1 : latency 1478699; std 394.78
[ 22 08 -- -- -- -- ]: 0 1146 0 2817 0 3768 0 2008 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1472080; std 361.99
[ 22 09 -- -- -- -- ]: 0 572 0 2134 0 4107 0 3092 0 0 0 0 0 0 0 0 0 0 0 1 : latency 1478926; std 392.95
[ 22 10 -- -- -- -- ]: 0 469 0 1744 0 3679 0 3467 0 562 0 0 0 1 0 0 0 0 0 0 : latency 1483202; std 376.34
[ 22 11 -- -- -- -- ]: 0 78 0 590 0 2142 0 4068 0 3113 0 0 0 0 0 0 0 0 0 1 : latency 1498928; std 391.82
[ 22 12 -- -- -- -- ]: 0 80 0 627 0 2181 0 4103 0 2998 0 0 0 0 0 0 0 0 0 0 : latency 1498446; std 390.10
[ 22 13 -- -- -- -- ]: 0 91 0 605 0 2119 0 4092 0 3088 0 0 0 0 0 0 0 0 0 1 : latency 1498818; std 391.50
[ 22 14 -- -- -- -- ]: 0 135 0 844 0 2351 0 3949 0 2705 0 0 0 0 0 0 0 0 0 0 : latency 1496278; std 376.63
[ 22 15 -- -- -- -- ]: 0 78 0 594 0 2171 0 4034 0 3116 0 0 0 0 0 0 0 0 0 1 : latency 1498876; std 390.74
[ 22 16 -- -- -- -- ]: 0 111 0 614 0 2160 0 4083 0 3022 0 0 0 0 0 0 0 1 0 0 : latency 1498406; std 389.08
[ 22 17 -- -- -- -- ]: 0 97 0 613 0 2126 0 4004 0 3148 0 0 0 0 0 0 0 0 0 0 : latency 1498800; std 391.10
[ 22 18 -- -- -- -- ]: 0 229 0 1082 0 2871 0 3866 0 1925 0 0 0 0 0 0 0 1 0 0 : latency 1492072; std 367.27
[ 22 19 -- -- -- -- ]: 0 109 0 592 0 2134 0 4097 0 3054 0 0 0 0 0 0 0 1 0 0 : latency 1498590; std 390.52
[ 22 20 -- -- -- -- ]: 0 576 0 2094 0 4230 0 3000 0 0 0 0 0 0 0 0 0 0 0 1 : latency 1478774; std 395.48
[ 22 21 -- -- -- -- ]: 0 111 0 585 0 2107 0 4162 0 3022 0 0 0 0 0 0 0 0 0 0 : latency 1498604; std 394.49
[ 22 22 -- -- -- -- ]: 0 103 0 611 0 2221 0 4061 0 2992 0 0 0 0 0 0 0 0 0 0 : latency 1498272; std 388.24
[ 22 23 -- -- -- -- ]: 0 76 0 605 0 2127 0 4134 0 3046 0 0 0 0 0 0 0 1 0 0 : latency 1498746; std 394.62
[ 22 24 -- -- -- -- ]: 0 117 0 750 0 2488 0 3985 0 2644 0 0 0 0 0 0 0 0 0 1 : latency 1496366; std 380.72
[ 22 25 -- -- -- -- ]: 0 81 0 566 0 2257 0 3985 0 3096 0 0 0 0 0 0 0 0 0 1 : latency 1498694; std 389.32
[ 22 26 -- -- -- -- ]: 0 96 0 611 0 2246 0 4028 0 3007 0 0 0 0 0 0 0 0 0 1 : latency 1498292; std 387.67
[ 22 27 -- -- -- -- ]: 0 82 0 583 0 2155 0 4144 0 3027 0 0 0 0 0 0 0 0 0 1 : latency 1498734; std 393.04
[ 22 28 -- -- -- -- ]: 0 246 0 1077 0 2863 0 3782 0 2000 0 0 0 0 0 0 0 1 0 0 : latency 1492114; std 363.68
[ 22 29 -- -- -- -- ]: 0 87 0 531 0 2186 0 4086 0 3096 0 0 0 0 0 0 0 0 0 0 : latency 1498948; std 395.33
[ 22 30 -- -- -- -- ]: 0 464 0 1813 0 3627 0 3433 0 587 0 0 0 0 0 1 0 0 0 0 : latency 1483130; std 375.50
[ 22 31 -- -- -- -- ]: 0 72 0 597 0 2132 0 4113 0 3081 0 0 0 0 0 0 0 0 0 1 : latency 1498924; std 392.95
[ 22 32 -- -- -- -- ]: 0 94 0 657 0 2108 0 4129 0 3000 0 0 0 0 0 0 0 0 0 0 : latency 1498516; std 389.71
[ 22 33 -- -- -- -- ]: 0 107 0 574 0 2121 0 4069 0 3115 0 0 0 0 0 0 0 0 0 0 : latency 1498824; std 393.23
[ 22 34 -- -- -- -- ]: 0 160 0 773 0 2419 0 3932 0 2697 0 0 0 0 0 1 0 0 0 0 : latency 1496234; std 374.78
[ 22 35 -- -- -- -- ]: 0 11 0 116 0 809 0 2396 0 3924 1 2706 0 34 0 0 0 0 0 0 : latency 1516597; std 378.48
[ 22 36 -- -- -- -- ]: 0 95 0 606 0 2237 0 4007 0 3042 0 0 0 0 0 0 0 1 0 0 : latency 1498390; std 389.77
[ 22 37 -- -- -- -- ]: 0 83 0 621 0 2140 0 3998 0 3150 0 0 0 0 0 0 0 0 0 1 : latency 1498860; std 389.25
[ 22 38 -- -- -- -- ]: 0 221 0 1101 0 2848 0 3855 0 1946 0 0 0 0 0 0 0 0 0 1 : latency 1492118; std 366.39
[ 22 39 -- -- -- -- ]: 0 85 0 608 0 2155 0 4091 0 3049 0 0 0 0 0 0 0 0 0 1 : latency 1498636; std 390.73
[ 22 40 -- -- -- -- ]: 0 653 0 2194 0 4061 0 3002 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1478340; std 388.16
[ 22 41 -- -- -- -- ]: 0 610 0 2158 0 4054 0 3071 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1478616; std 389.47
[ 22 42 -- -- -- -- ]: 0 109 0 603 0 2207 0 4055 0 3007 0 0 0 0 0 0 0 1 0 0 : latency 1498266; std 388.00
[ 22 43 -- -- -- -- ]: 0 83 0 603 0 2130 0 4123 0 3049 0 0 0 0 0 0 0 0 0 0 : latency 1498720; std 392.00
[ 22 44 -- -- -- -- ]: 0 112 0 760 0 2437 0 4084 0 2591 0 0 0 0 0 0 0 1 0 0 : latency 1496350; std 383.19
[ 22 45 -- -- -- -- ]: 0 99 0 562 0 2150 0 4176 0 3002 0 0 0 0 0 0 0 0 0 1 : latency 1498660; std 393.65
[ 22 46 -- -- -- -- ]: 0 102 0 636 0 2173 0 4078 0 3002 0 0 0 0 0 1 0 0 0 0 : latency 1498312; std 388.40
[ 22 47 -- -- -- -- ]: 0 84 0 547 0 2225 0 4100 0 3034 0 0 0 0 0 0 0 0 0 0 : latency 1498732; std 394.68
[ 22 48 -- -- -- -- ]: 0 239 0 1081 0 2845 0 3826 0 1978 0 0 0 0 0 0 0 1 0 0 : latency 1492136; std 367.30
[ 22 49 -- -- -- -- ]: 0 79 0 559 0 2227 0 3978 0 3148 0 0 0 0 0 0 0 0 0 0 : latency 1498948; std 390.39
[ 22 50 -- -- -- -- ]: 0 474 0 1740 0 3642 0 3479 0 572 0 0 0 0 0 0 0 0 0 1 : latency 1483172; std 374.72
[ 22 51 -- -- -- -- ]: 0 83 0 586 0 2148 0 4061 0 3112 0 0 0 0 0 0 0 0 0 0 : latency 1498894; std 391.47
[ 22 52 -- -- -- -- ]: 0 100 0 588 0 2252 1 4006 0 3038 0 0 0 0 0 0 0 0 0 0 : latency 1498385; std 392.01
[ 22 53 -- -- -- -- ]: 0 94 0 588 0 2219 0 3899 0 3187 0 0 0 0 0 0 0 0 0 0 : latency 1498804; std 387.19
[ 22 54 -- -- -- -- ]: 0 139 0 780 0 2421 0 3965 0 2675 0 0 0 0 0 0 0 0 0 1 : latency 1496280; std 376.16
[ 22 55 -- -- -- -- ]: 0 75 0 544 0 2243 0 4015 0 3113 0 0 0 0 0 0 0 0 0 0 : latency 1498922; std 391.50
[ 22 56 -- -- -- -- ]: 0 97 0 580 0 2206 0 4101 0 3000 0 0 0 0 0 0 0 0 0 1 : latency 1498438; std 392.65
[ 22 57 -- -- -- -- ]: 0 103 0 602 0 2082 0 4090 1 3110 0 0 0 0 0 0 0 1 0 0 : latency 1498819; std 393.31
[ 22 58 -- -- -- -- ]: 0 218 0 1092 0 2873 0 3869 0 1923 0 0 0 0 0 0 0 0 0 1 : latency 1492106; std 367.66
[ 22 59 -- -- -- -- ]: 0 101 0 573 0 2120 0 4168 0 3017 0 0 0 0 0 0 0 0 0 1 : latency 1498614; std 392.88
[ 22 60 -- -- -- -- ]: 0 560 0 2222 0 4110 0 3031 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1478790; std 393.11
[ 22 61 -- -- -- -- ]: 0 104 0 584 0 2168 0 4052 0 3077 0 0 0 0 0 0 0 0 0 0 : latency 1498624; std 391.88
[ 22 62 -- -- -- -- ]: 0 94 0 656 0 2164 0 4097 0 2983 0 0 0 0 0 0 0 0 0 1 : latency 1498288; std 388.63
[ 22 63 -- -- -- -- ]: 0 89 0 555 0 2197 0 4099 0 3050 0 0 0 0 0 0 0 0 0 1 : latency 1498758; std 392.37
[ 22 64 -- -- -- -- ]: 0 139 0 755 0 2374 0 4110 0 2601 0 0 0 0 0 0 0 0 0 0 : latency 1496320; std 380.68
[ 22 65 -- -- -- -- ]: 0 94 0 596 0 2145 0 4103 0 3050 0 0 0 0 0 0 0 0 0 1 : latency 1498652; std 391.15
[ 22 66 -- -- -- -- ]: 0 122 0 612 0 2167 1 4105 0 2980 0 0 0 0 0 0 0 1 0 0 : latency 1498219; std 392.96
[ 22 67 -- -- -- -- ]: 0 95 0 564 0 2168 0 4133 0 3031 0 0 0 0 0 0 0 1 0 0 : latency 1498712; std 392.78
[ 22 68 -- -- -- -- ]: 0 246 0 1060 0 2889 0 3765 0 1996 0 0 0 0 0 1 0 0 0 0 : latency 1492026; std 363.40
[ 22 69 -- -- -- -- ]: 0 89 0 564 0 2115 0 4149 0 3072 0 0 0 0 0 0 0 0 0 1 : latency 1498920; std 396.18
[ 22 70 -- -- -- -- ]: 0 483 0 1762 0 3621 0 3488 0 564 0 0 0 0 0 0 0 1 0 0 : latency 1483150; std 374.60
[ 22 71 -- -- -- -- ]: 0 82 0 554 0 2200 0 4022 0 3132 0 0 0 0 0 0 0 0 0 1 : latency 1498962; std 391.46
[ 22 72 -- -- -- -- ]: 0 85 0 631 0 2226 0 4004 0 3042 0 0 0 0 0 0 0 0 0 0 : latency 1498390; std 387.27
[ 22 73 -- -- -- -- ]: 0 91 0 612 0 2137 0 4013 0 3139 0 0 0 0 0 0 0 0 0 1 : latency 1498832; std 389.49
[ 22 74 -- -- -- -- ]: 0 164 0 772 0 2412 0 3929 0 2702 0 0 0 0 0 0 0 1 0 0 : latency 1496220; std 376.71
[ 22 75 -- -- -- -- ]: 0 92 0 562 0 2144 0 4106 0 3088 0 0 0 0 0 0 0 0 0 1 : latency 1498908; std 395.05
[ 22 76 -- -- -- -- ]: 0 87 0 651 0 2142 0 4126 0 2985 0 0 0 0 0 0 0 0 0 1 : latency 1498370; std 392.00
[ 22 77 -- -- -- -- ]: 0 95 0 602 0 2116 0 4058 0 3118 0 0 0 0 0 0 0 0 0 1 : latency 1498824; std 390.60
[ 22 78 -- -- -- -- ]: 0 239 1 1068 0 2909 0 3814 0 1947 0 0 0 0 0 0 0 0 0 1 : latency 1492073; std 368.44
[ 22 79 -- -- -- -- ]: 0 88 0 592 0 2165 0 4105 0 3038 0 0 0 0 0 0 0 0 0 0 : latency 1498640; std 393.46
[ 22 80 -- -- -- -- ]: 0 749 0 2400 0 4118 0 2574 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1476248; std 381.04
[ 22 81 -- -- -- -- ]: 0 592 0 2136 0 4137 0 3043 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1478764; std 392.77
[ 22 82 -- -- -- -- ]: 0 637 0 2192 0 4058 0 2995 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1478218; std 387.38
[ 22 83 -- -- -- -- ]: 0 561 0 2202 0 4108 0 3041 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1478786; std 392.76
[ 22 84 -- -- -- -- ]: 0 120 0 817 0 2387 0 4053 0 2608 0 0 0 0 0 1 0 0 0 0 : latency 1496214; std 380.47
[ 22 85 -- -- -- -- ]: 0 107 0 589 0 2123 0 4089 0 3073 0 0 0 0 0 1 0 0 0 0 : latency 1498632; std 390.53
[ 22 86 -- -- -- -- ]: 0 110 0 651 0 2185 0 4034 0 3009 0 0 0 0 0 0 0 1 0 0 : latency 1498178; std 388.47
[ 22 87 -- -- -- -- ]: 0 76 0 592 0 2125 0 4153 0 3043 0 0 0 0 0 0 0 0 0 0 : latency 1498812; std 393.48
[ 22 88 -- -- -- -- ]: 0 246 0 1108 0 2822 0 3810 0 1984 0 0 0 0 0 0 0 1 0 0 : latency 1492060; std 361.24
[ 22 89 -- -- -- -- ]: 0 84 0 584 0 2180 0 4008 0 3133 0 0 0 0 0 0 0 0 0 0 : latency 1498866; std 390.11
[ 22 90 -- -- -- -- ]: 0 454 0 1797 0 3644 0 3456 0 571 0 0 0 0 0 0 0 1 0 0 : latency 1483192; std 375.04
[ 22 91 -- -- -- -- ]: 0 97 0 580 0 2140 0 4073 0 3103 0 0 0 0 0 0 0 0 0 1 : latency 1498852; std 393.60
[ 22 92 -- -- -- -- ]: 0 76 0 629 0 2217 0 4025 0 3043 0 0 0 0 0 0 0 0 0 1 : latency 1498486; std 388.38
[ 22 93 -- -- -- -- ]: 0 89 0 579 0 2203 0 3969 0 3146 0 0 0 0 0 0 0 0 0 0 : latency 1498944; std 388.98
[ 22 94 -- -- -- -- ]: 0 122 0 831 0 2344 0 3988 0 2691 0 0 0 0 0 0 0 0 0 0 : latency 1496330; std 378.18
[ 22 95 -- -- -- -- ]: 0 88 0 585 0 2160 0 4025 0 3129 0 0 0 0 0 0 0 0 0 1 : latency 1498852; std 390.34
[ 22 96 -- -- -- -- ]: 0 101 0 636 0 2130 0 4085 0 3033 0 0 0 0 0 0 0 0 0 1 : latency 1498422; std 388.90
[ 22 97 -- -- -- -- ]: 0 116 0 597 0 2140 0 3973 0 3162 0 0 0 0 0 0 0 1 0 0 : latency 1498746; std 390.13
[ 22 98 -- -- -- -- ]: 0 209 0 1080 0 2932 0 3816 0 1932 0 0 0 0 0 1 0 0 0 0 : latency 1492050; std 367.12
[ 22 99 -- -- -- -- ]: 0 91 0 617 0 2113 0 4081 0 3080 0 0 0 1 0 0 0 0 0 0 : latency 1498652; std 392.35
0: 35 lat = 1516597
1: 71 lat = 1498962
2: 49 lat = 1498948
3: 29 lat = 1498948
4: 93 lat = 1498944
95: 82 lat = 1478218
96: 04 lat = 1476316
97: 80 lat = 1476248
98: 08 lat = 1472080
99: 00 lat = 1463218
0: 03 std = 396.19
1: 69 std = 396.18
2: 20 std = 395.48
3: 29 std = 395.33
4: 75 std = 395.05
95: 38 std = 366.39
96: 28 std = 363.68
97: 68 std = 363.40
98: 08 std = 361.99
99: 88 std = 361.24
lat_k 0-1 1.18%, lat_k 98-99 0.61%, lat_k 0-99 3.65%
std_k 0-1 0.00%, std_k 98-99 0.21%, std_k 0-99 9.67%
pin[1] choose candidate: 35 (latency only)
[ 22 35 00 -- -- -- ]: 0 11 0 84 0 637 0 1905 0 3332 0 3070 0 958 0 0 0 0 0 0 : latency 1522890; std 342.73
[ 22 35 01 -- -- -- ]: 0 2 0 43 0 306 0 1277 0 3128 0 3589 0 1652 0 0 0 0 0 0 : latency 1529592; std 358.17
[ 22 35 02 -- -- -- ]: 0 2 0 33 0 327 0 1292 0 3217 1 3547 0 1578 0 0 0 0 0 0 : latency 1529159; std 361.18
[ 22 35 03 -- -- -- ]: 0 5 0 35 0 292 0 1307 0 3073 1 3666 0 1618 0 0 0 0 0 0 : latency 1529631; std 362.07
[ 22 35 04 -- -- -- ]: 0 5 0 68 0 388 0 1510 0 3309 0 3306 0 1411 0 0 0 0 0 0 : latency 1527094; std 350.55
[ 22 35 05 -- -- -- ]: 0 7 0 46 0 292 0 1222 0 3149 0 3710 0 1571 0 0 0 0 0 1 : latency 1529616; std 363.75
[ 22 35 06 -- -- -- ]: 0 3 0 49 0 339 0 1323 0 3100 0 3544 0 1639 0 0 0 0 0 1 : latency 1529180; std 354.48
[ 22 35 07 -- -- -- ]: 0 14 0 124 0 570 0 1716 0 3182 0 3064 0 1325 0 0 0 0 0 1 : latency 1524696; std 336.07
[ 22 35 08 -- -- -- ]: 0 0 0 14 0 115 0 590 0 1856 0 3446 0 2990 0 986 0 0 0 1 : latency 1542900; std 343.76
[ 22 35 09 -- -- -- ]: 0 0 0 4 0 37 0 285 0 1358 0 2990 0 3693 0 1630 0 0 0 0 : latency 1549648; std 358.55
[ 22 35 10 -- -- -- ]: 0 1 0 26 0 249 0 1082 0 2630 0 3635 0 2068 0 306 0 0 0 0 : latency 1533914; std 347.50
[ 22 35 11 -- -- -- ]: 0 0 0 2 0 31 0 308 0 1301 0 3139 0 3615 0 1601 0 0 0 0 : latency 1549452; std 359.57
[ 22 35 12 -- -- -- ]: 0 0 0 5 0 36 0 342 0 1323 0 3115 0 3614 0 1562 0 0 0 0 : latency 1549060; std 357.72
[ 22 35 13 -- -- -- ]: 0 0 0 4 0 45 0 311 0 1318 0 3027 0 3683 0 1608 0 1 0 0 : latency 1549474; std 360.73
[ 22 35 14 -- -- -- ]: 0 0 0 9 0 70 0 406 0 1502 0 3198 0 3505 0 1307 0 0 0 0 : latency 1546970; std 353.75
[ 22 35 15 -- -- -- ]: 0 0 0 2 0 38 0 276 0 1282 0 3162 0 3710 0 1527 0 0 0 0 : latency 1549470; std 364.53
[ 22 35 16 -- -- -- ]: 0 0 0 5 0 36 0 291 0 1368 0 3069 0 3773 0 1455 0 0 0 0 : latency 1549062; std 363.74
[ 22 35 17 -- -- -- ]: 0 0 0 5 0 40 0 298 0 1279 0 3123 0 3682 0 1570 0 0 0 0 : latency 1549466; std 361.67
[ 22 35 18 -- -- -- ]: 0 0 0 18 0 124 0 594 0 1873 0 3340 0 3107 0 941 0 1 0 0 : latency 1542816; std 343.54
[ 22 35 19 -- -- -- ]: 0 0 0 3 0 53 0 300 0 1315 0 3082 0 3599 0 1645 0 0 0 0 : latency 1549458; std 356.86
[ 22 35 20 -- -- -- ]: 0 3 0 49 0 312 0 1285 0 3124 0 3573 0 1651 0 0 0 0 0 0 : latency 1529472; std 357.07
[ 22 35 21 -- -- -- ]: 0 0 0 2 0 37 0 293 0 1328 0 3081 0 3660 0 1596 0 0 0 0 : latency 1549492; std 359.69
[ 22 35 22 -- -- -- ]: 0 0 0 1 0 43 0 364 0 1309 0 3025 0 3735 0 1520 0 0 0 0 : latency 1549064; std 359.44
[ 22 35 23 -- -- -- ]: 0 0 0 4 0 43 0 333 0 1323 0 2964 0 3706 0 1624 0 0 0 0 : latency 1549494; std 357.24
[ 22 35 24 -- -- -- ]: 0 0 0 2 0 64 0 440 0 1484 0 3212 0 3456 0 1339 0 0 0 0 : latency 1546992; std 351.95
[ 22 35 25 -- -- -- ]: 0 0 0 4 0 48 0 282 0 1303 0 3149 0 3593 0 1617 0 1 0 0 : latency 1549458; std 361.38
[ 22 35 26 -- -- -- ]: 0 0 0 6 0 48 0 311 0 1358 0 3092 0 3618 0 1564 0 0 0 0 : latency 1549050; std 357.42
[ 22 35 27 -- -- -- ]: 0 0 0 6 0 43 0 299 0 1311 0 3047 0 3699 0 1592 0 0 0 0 : latency 1549494; std 359.92
[ 22 35 28 -- -- -- ]: 0 0 0 9 0 110 0 616 0 1890 0 3360 0 3056 0 956 0 0 0 0 : latency 1542812; std 342.92
[ 22 35 29 -- -- -- ]: 0 1 0 6 0 53 0 333 0 1300 0 3028 0 3588 0 1688 0 0 0 0 : latency 1549474; std 356.54
[ 22 35 30 -- -- -- ]: 0 8 0 21 0 212 0 1038 0 2759 0 3619 0 2026 0 314 0 0 0 0 : latency 1533972; std 350.36
[ 22 35 31 -- -- -- ]: 0 0 0 3 0 35 0 285 0 1220 0 3188 0 3748 0 1518 0 0 0 0 : latency 1549608; std 366.98
[ 22 35 32 -- -- -- ]: 0 0 0 3 0 30 0 314 0 1442 0 3054 0 3491 0 1663 0 0 0 0 : latency 1549142; std 351.99
[ 22 35 33 -- -- -- ]: 0 0 0 6 0 37 0 310 0 1285 0 3070 0 3663 0 1626 0 0 0 0 : latency 1549604; std 359.22
[ 22 35 34 -- -- -- ]: 0 1 0 5 0 54 0 395 0 1550 1 3187 0 3440 0 1364 0 0 0 1 : latency 1547131; std 356.24
[ 22 35 35 -- -- -- ]: 0 0 0 1 0 34 0 276 0 1315 0 3128 0 3675 0 1568 0 0 0 0 : latency 1549530; std 362.16
[ 22 35 36 -- -- -- ]: 0 0 0 2 0 38 0 297 0 1367 0 3119 0 3600 0 1574 0 0 0 0 : latency 1549182; std 358.20
[ 22 35 37 -- -- -- ]: 0 0 0 1 0 46 0 277 0 1281 0 3098 0 3740 0 1554 0 0 0 0 : latency 1549598; std 363.66
[ 22 35 38 -- -- -- ]: 0 2 0 8 0 117 0 623 0 1903 0 3258 0 3100 0 986 0 0 0 1 : latency 1542910; std 342.57
[ 22 35 39 -- -- -- ]: 0 0 0 2 0 55 0 344 0 1260 0 3026 0 3620 0 1690 0 0 0 0 : latency 1549610; std 355.43
[ 22 35 40 -- -- -- ]: 0 0 0 41 0 308 0 1367 0 3138 0 3585 0 1558 0 0 0 0 0 0 : latency 1529048; std 355.58
[ 22 35 41 -- -- -- ]: 0 2 0 64 0 315 0 1285 0 3067 0 3591 0 1672 0 0 0 0 0 0 : latency 1529488; std 357.99
[ 22 35 42 -- -- -- ]: 0 0 0 4 0 33 0 316 0 1316 0 3158 0 3674 0 1496 0 0 0 0 : latency 1549060; std 362.04
[ 22 35 43 -- -- -- ]: 0 0 0 10 0 39 0 342 0 1309 0 2972 0 3674 0 1651 0 0 0 0 : latency 1549506; std 356.02
[ 22 35 44 -- -- -- ]: 0 0 0 9 0 60 0 417 0 1549 0 3222 0 3315 0 1425 0 0 0 0 : latency 1546986; std 347.44
[ 22 35 45 -- -- -- ]: 0 0 0 2 0 38 0 298 0 1277 0 3098 0 3755 0 1529 0 0 0 0 : latency 1549490; std 364.00
[ 22 35 46 -- -- -- ]: 0 0 0 6 0 40 0 357 0 1382 1 3035 0 3544 0 1632 0 0 0 1 : latency 1548985; std 354.48
[ 22 35 47 -- -- -- ]: 0 0 0 3 0 33 0 303 0 1355 0 3056 0 3584 0 1663 0 0 0 0 : latency 1549530; std 355.92
[ 22 35 48 -- -- -- ]: 0 0 0 7 0 91 0 566 0 1972 0 3413 0 3000 0 948 0 0 0 0 : latency 1542834; std 345.40
[ 22 35 49 -- -- -- ]: 0 0 0 0 0 6 0 47 0 374 0 1604 0 3191 1 3395 0 1365 0 14 : latency 1567151; std 355.07
[ 22 35 50 -- -- -- ]: 0 2 0 31 0 207 0 1029 0 2779 0 3629 0 2000 0 320 0 0 0 0 : latency 1533950; std 350.95
[ 22 35 51 -- -- -- ]: 0 0 0 3 0 46 0 328 0 1306 0 2980 0 3685 0 1649 0 0 0 1 : latency 1549592; std 356.99
[ 22 35 52 -- -- -- ]: 0 0 0 5 0 41 0 297 0 1372 0 3118 0 3557 0 1607 0 0 0 0 : latency 1549178; std 356.39
[ 22 35 53 -- -- -- ]: 0 0 0 3 0 30 0 282 0 1280 0 3119 0 3758 0 1525 0 0 0 0 : latency 1549578; std 365.26
[ 22 35 54 -- -- -- ]: 0 1 0 6 0 79 0 425 0 1512 0 3097 0 3487 0 1390 0 0 0 1 : latency 1547128; std 351.49
[ 22 35 55 -- -- -- ]: 0 0 0 1 0 43 0 347 0 1298 0 2963 0 3699 0 1646 0 0 0 0 : latency 1549586; std 356.85
[ 22 35 56 -- -- -- ]: 0 0 0 6 0 45 0 326 0 1368 0 3059 0 3541 0 1652 0 0 0 0 : latency 1549186; std 353.37
[ 22 35 57 -- -- -- ]: 0 0 0 0 0 42 0 295 0 1345 0 3055 0 3591 0 1669 0 0 0 0 : latency 1549592; std 353.90
[ 22 35 58 -- -- -- ]: 0 0 0 11 0 98 0 624 0 1958 0 3293 0 2933 0 1080 0 0 0 0 : latency 1542952; std 336.48
[ 22 35 59 -- -- -- ]: 0 1 0 4 0 38 0 301 0 1286 0 3104 0 3642 0 1620 0 1 0 0 : latency 1549576; std 364.11
[ 22 35 60 -- -- -- ]: 0 1 0 49 0 282 0 1281 0 3143 0 3633 0 1608 0 0 0 0 0 0 : latency 1529566; std 360.61
[ 22 35 61 -- -- -- ]: 0 1 0 0 0 41 0 264 0 1299 0 3112 0 3736 0 1544 0 0 0 0 : latency 1549594; std 364.26
[ 22 35 62 -- -- -- ]: 0 0 0 4 0 48 0 313 0 1266 0 3196 0 3658 0 1512 0 0 0 0 : latency 1549112; std 362.43
[ 22 35 63 -- -- -- ]: 0 0 0 0 0 39 0 292 0 1267 0 3091 0 3761 0 1547 0 0 0 0 : latency 1549630; std 361.97
[ 22 35 64 -- -- -- ]: 0 0 0 4 0 55 0 381 0 1529 0 3324 0 3308 0 1398 0 0 0 0 : latency 1547276; std 349.38
[ 22 35 65 -- -- -- ]: 0 0 0 0 0 40 0 294 0 1304 0 3067 0 3728 0 1564 0 0 0 0 : latency 1549542; std 359.72
[ 22 35 66 -- -- -- ]: 0 0 0 5 0 42 0 281 0 1353 0 3147 0 3609 0 1560 0 0 0 1 : latency 1549186; std 359.58
[ 22 35 67 -- -- -- ]: 0 0 0 2 0 36 0 282 1 1276 0 3136 0 3704 0 1560 0 0 0 0 : latency 1549587; std 365.72
[ 22 35 68 -- -- -- ]: 0 0 0 4 0 110 0 580 0 1984 0 3361 0 2899 0 1059 0 0 0 0 : latency 1542908; std 339.04
[ 22 35 69 -- -- -- ]: 0 0 0 1 0 38 0 261 0 1319 0 3133 0 3646 0 1599 0 0 0 0 : latency 1549626; std 361.43
[ 22 35 70 -- -- -- ]: 0 1 0 28 0 218 0 1111 0 2633 0 3686 0 2003 0 317 0 0 0 0 : latency 1533876; std 349.21
[ 22 35 71 -- -- -- ]: 0 0 0 4 0 31 0 317 0 1305 0 3070 0 3677 0 1593 0 0 0 1 : latency 1549480; std 359.70
[ 22 35 72 -- -- -- ]: 0 1 0 4 0 44 0 370 0 1342 0 3054 0 3535 0 1647 0 0 0 1 : latency 1549038; std 354.49
[ 22 35 73 -- -- -- ]: 0 0 0 6 0 46 0 298 0 1301 1 3096 0 3616 0 1633 0 0 0 1 : latency 1549495; std 360.38
[ 22 35 74 -- -- -- ]: 0 0 0 1 0 62 0 429 0 1546 0 3155 0 3441 0 1363 0 0 0 0 : latency 1546998; std 349.84
[ 22 35 75 -- -- -- ]: 0 0 0 3 0 44 0 264 0 1334 0 3071 0 3739 0 1542 0 0 0 0 : latency 1549490; std 362.94
[ 22 35 76 -- -- -- ]: 0 0 0 2 0 40 0 307 0 1325 0 3201 0 3560 0 1562 0 0 0 0 : latency 1549088; std 359.00
[ 22 35 77 -- -- -- ]: 0 0 0 3 0 45 0 314 0 1331 1 3031 0 3635 0 1637 0 0 0 0 : latency 1549461; std 358.92
[ 22 35 78 -- -- -- ]: 0 2 0 12 0 129 0 594 0 1912 0 3327 0 3017 0 1004 0 1 0 0 : latency 1542808; std 342.42
[ 22 35 79 -- -- -- ]: 0 1 0 0 0 32 0 305 0 1283 0 3121 0 3677 0 1578 0 0 0 1 : latency 1549528; std 361.57
[ 22 35 80 -- -- -- ]: 0 4 0 57 0 412 0 1572 0 3157 0 3434 0 1360 0 0 0 0 0 1 : latency 1526988; std 352.41
[ 22 35 81 -- -- -- ]: 0 4 0 51 0 309 0 1329 0 2975 0 3711 0 1618 0 0 0 0 0 0 : latency 1529520; std 358.02
[ 22 35 82 -- -- -- ]: 0 1 0 51 0 342 0 1318 0 3091 1 3629 0 1563 0 1 0 0 0 1 : latency 1529055; std 361.87
[ 22 35 83 -- -- -- ]: 0 4 0 29 0 315 0 1243 0 3170 0 3689 0 1547 0 0 0 0 0 0 : latency 1529474; std 363.45
[ 22 35 84 -- -- -- ]: 0 0 0 5 0 72 0 439 0 1515 0 3186 0 3351 0 1429 0 0 0 0 : latency 1547012; std 346.84
[ 22 35 85 -- -- -- ]: 0 1 0 1 0 54 0 311 0 1266 0 3098 0 3668 0 1598 0 0 0 0 : latency 1549462; std 362.18
[ 22 35 86 -- -- -- ]: 0 0 0 5 0 36 0 332 0 1360 0 3112 0 3576 0 1576 0 0 0 0 : latency 1549006; std 356.28
[ 22 35 87 -- -- -- ]: 0 1 0 5 0 54 0 306 0 1297 0 3029 0 3704 0 1601 0 0 0 0 : latency 1549472; std 361.53
[ 22 35 88 -- -- -- ]: 0 0 0 6 0 102 0 590 0 1930 1 3444 0 2941 0 983 0 0 0 0 : latency 1542785; std 345.84
[ 22 35 89 -- -- -- ]: 0 0 0 0 0 60 0 317 0 1286 0 3048 0 3659 0 1627 0 0 0 0 : latency 1549482; std 355.50
[ 22 35 90 -- -- -- ]: 0 2 0 41 0 217 0 1058 0 2678 0 3638 0 2041 0 322 0 0 0 1 : latency 1533982; std 348.55
[ 22 35 91 -- -- -- ]: 0 0 0 4 0 31 0 296 0 1312 0 3108 0 3598 0 1648 0 0 0 0 : latency 1549614; std 358.26
[ 22 35 92 -- -- -- ]: 0 0 0 1 0 54 0 304 0 1298 0 3173 0 3607 0 1560 0 0 0 1 : latency 1549160; std 359.75
[ 22 35 93 -- -- -- ]: 0 0 0 2 0 41 0 309 0 1290 0 3086 0 3623 0 1646 0 0 0 0 : latency 1549604; std 358.16
[ 22 35 94 -- -- -- ]: 0 0 0 7 0 58 0 381 0 1523 0 3223 0 3463 0 1342 0 0 0 1 : latency 1547170; std 353.78
[ 22 35 95 -- -- -- ]: 0 0 0 3 0 24 0 306 0 1327 0 3060 0 3666 0 1611 0 0 0 0 : latency 1549586; std 359.39
[ 22 35 96 -- -- -- ]: 0 0 0 1 0 32 0 337 0 1289 0 3153 0 3663 0 1522 0 0 0 1 : latency 1549138; std 361.21
[ 22 35 97 -- -- -- ]: 0 0 0 3 0 39 0 323 0 1298 0 2990 0 3755 0 1589 0 0 0 0 : latency 1549576; std 360.33
[ 22 35 98 -- -- -- ]: 0 1 0 13 0 97 0 611 0 1930 0 3379 0 2917 0 1049 0 0 0 0 : latency 1542884; std 341.74
[ 22 35 99 -- -- -- ]: 0 0 0 2 0 42 0 282 0 1276 0 3083 0 3778 0 1534 0 0 0 0 : latency 1549596; std 364.76
0: 49 lat = 1567151
1: 09 lat = 1549648
2: 63 lat = 1549630
3: 69 lat = 1549626
4: 91 lat = 1549614
95: 40 lat = 1529048
96: 04 lat = 1527094
97: 80 lat = 1526988
98: 07 lat = 1524696
99: 00 lat = 1522890
0: 31 std = 366.98
1: 67 std = 365.72
2: 53 std = 365.26
3: 99 std = 364.76
4: 15 std = 364.53
95: 78 std = 342.42
96: 98 std = 341.74
97: 68 std = 339.04
98: 58 std = 336.48
99: 07 std = 336.07
lat_k 0-1 1.13%, lat_k 98-99 0.12%, lat_k 0-99 2.91%
std_k 0-1 0.34%, std_k 98-99 0.12%, std_k 0-99 9.20%
pin[2] choose candidate: 49 (latency only)
Candidate PIN 22 35 49 -- -- -- : brute forcing bytes 3 to 5 (3 bytes), will take up to 702 seconds
Progress: 0%..5%..10%..15%..20%..25%..30%..35%..40%..45%..50%..55%..60%..65%..70%..75%..80%..85%..90%..done
found PIN: 22 35 49 12 24 94
PIN is cracked in 2779.14 seconds
Validating PIN
PIN verified.
done
Resetting all ECUs.
CAN_HS ---> ID=000ffffe data=ff c8 00 00 00 00 00 00
CAN_LS ---> ID=000ffffe data=ff c8 00 00 00 00 00 00
- RickHaleParker
They do make USB hubs that draw power from a external source.vtl wrote: 02 Aug 2021, 10:14 Easily: a 5-port hub connected to already subpar laptop port that drops voltage even before the load reaches 0.5A![]()
Active
Past
Past
- RickHaleParker
The one I have runs off 5V and has a USB port for power input. Use a high current 12 - 5V USB adapter.
Google "Powered USB Hub" and take a look.
At least on the CEM-H the 12V receptacle turns on when the CEM goes into programing mode.
Active
Past
Past
- 10019 Views
Last post by RickHaleParker
- 10461 Views
- 27 Replies
- 32003 Views
Last post by cn90
- 10 Replies
- 12346 Views
Last post by jonesg
- 7244 Views
