Hy Buddies,
The 10 mm pin that fixes the brake disc to the hub is broken into the hub. Each time i brake i feel the disc moving till the brakes platelets are taken.
What tool do you recommend me to extract this screw ?
Drill bit 4,2 mm
and then, this one ?
Manov.
850 The pin that attaches the disc to the hub is broken
- Has thanked: 987 times
- Been thanked: 1076 times
Left hand drill bits (cut in opposite of normal direction) are recommended for extraction work.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Rotor can't be moved when you apply brakes because the wheel lugs/bolts...all 5 of them are keeping the rotor in place.
That guide pin is preventing the rotor to be moved when wheel is removed from the car.
Some factory rims like Persus have a blank space on the inside to accept that guide pin.
There is no other way to mount the wheel on the car if you don't aim the guide pin and opening on the rim.
They are usually a 10mm.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
I agree with @misha , the rotor should be captured by the wheel and lug bolts. People who use some aftermarket wheel have to take those little pins off anyway.
If you can get the rotor off, maybe you can get a grip on the nub with some locking pliers ?
- manovlov
- Year and Model: 1995 850 GLT 2.5 170
- Has thanked: 674 times
- Been thanked: 164 times
Ok Guys. I understand. So from where could come this feeling of something moves when I activate brakes (front wheels) ?
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Check your front struts and the rotors for warpage. Could just be warped rotors which will give you a surging feeling, or the front end of the car is taking a dive due to bad struts/springs.
Did you bleed the air out of the brakes while/after doing your work?
- manovlov
All the suspension is new, rods, shocks, springs only OEM. Rotors have 2 years. Maybe the brake pads are "glazed"? I will check them tomorrow. I will replace the steering rack fluid, so it will be the perfect occasion.
Thanks for the help.
Manov.
Manov.
- manovlov
What surprises me is how the hole parts are moving, brakepads, discs. It always seems not normal to me....foggydogg wrote: 02 Aug 2021, 10:29 I agree with @misha , the rotor should be captured by the wheel and lug bolts. People who use some aftermarket wheel have to take those little pins off anyway.
- misha
Inspect front suspension parts....tie rods,bushings and ball joint on control arms....brake calipers and pads.manovlov wrote: 02 Aug 2021, 10:53 Ok Guys. I understand. So from where could come this feeling of something moves when I activate brakes (front wheels) ?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 738 Views
Last post by s10lowrider1994
- 1580 Views
- 16 Replies
- 12592 Views
Last post by Rgierer
- 2435 Views
Last post by [email protected]
- 1936 Views
