06 s60 no valve movement
Been thanked: 4068 times
If I pull the intake manifold can I see the valve stems enough to determine they’re status?
Yes, you can see the guides and back of the valves through the ports. Hope you are ok!
stephansvolvo
Year and Model: V70 GLT 1998
Has thanked: 21 times
Been thanked: 3 times
Post by stephansvolvo »
abscate wrote: 03 Aug 2021, 04:46 If I pull the intake manifold can I see the valve stems enough to determine they’re status?
Seems way easier than pulling the head again!
This went from unsolved to solved back to unsolved.
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
You can put each cyl at TDC and apply 15 psi air to the plug hole.
Low pressure is to prevent the engine rotating, I do this on my briggs engine in a tractor, you can hear it.
