I replaced the front wheel hub assembly the other night and noticed that a seal on the back side is missing. Thats probably why the bearing failed. It was a FAG bearing. I used FAG also and don't to replace it any time soon. Does anybody know what the part number is for the wheel hub seal? I have searched and can't find any info.
Thanks
P80 FWD front wheel bearing seals 9492980 30647015
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Fag bearings are OEM bearings and they are just "install & go".
That said....remove the old one and put in the new one.There are no aditional seals for it.Everything you need is in the box.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 2857 times
- Been thanked: 1332 times
True. Just did this on my '97 850's LF, FAG brand.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
I looked up the diagram on VIDA and I see the sealing ring.
For V70's they list 9492980 for chassis number up to 665091 and
30647015 for chassis number 665092 and on.
Funny thing is that I have never seen that seal consistently used. I have taken apart a number of cars that likely never had been apart before and have not found that seal.
WHen I have found them in place the fit seems to have nothing to do with sealing the bearing.
- Been thanked: 4068 times
Let’s add to this 10 year old thread !
The seal is not installed on most cars in Sweden / Ghent but is a Volvo approved add on
The 9492980 seal has a correct orientation , see pictures
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
That is brilliant, so it is what they call a dust shield, to keep out water and dirt. How much was it. I elected to try a GmB bearing.abscate wrote: 05 Aug 2021, 00:08 Let’s add to this 10 year old thread !
Btw put some anti seize on those splines, they can size with corrosion
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Added FCP picture to post, it’s $6 part protecting a $100 bearing amd 4 hours labor
Here is the chassis break info on the seal
Bumpity Bump
