Re-Using Strut Hardware/Fasteners? Topic is solved
- Eddystone
- Year and Model: 1967 Ford GT40 Mk IV
- Has thanked: 63 times
- Been thanked: 81 times
I've done a few struts (maybe three) and sometimes have wondered why some of the hardware and fasteners need to be changed. Below is a list of the things I'm talking about. Genuine Volvo parts are pretty pricey for this stuff totalling about $100 for both struts. Do you replace all this stuff or reuse it. (I know that there are some nuts and bolts that should always be changed...)
- 1.png (47.27 KiB) Viewed 1061 times
All U.S. market models.
All running and on the road.
- Has thanked: 2208 times
'I'm sure others may have different opinions, but I re-use all the nuts and bolts except the bottom bolt and nut for the control arm and ball-joint. If the bolts are badly rusted to the point where the threads are damaged or there are signs of damage to it I would replace it. Nuts, if they are the type that have the flat on one side that wider than the other end and little serrations on them, I will reuse unless the hex is damage or again it is really rusted.
Volvo nuts and bolts are stupid expensive. When I pull stuff at PnP I always take all the bolts and nuts as they don't charge for them. I have boxes of bolts.
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
I reuse them all, unless damaged. These aren't any kind of TTY bolts.
Any of the lock nuts get replaced if they are "loose", but a bit of thread locker usually deals with any of that.
Haven't had any fail or loosen.
- Has thanked: 1611 times
- Been thanked: 4072 times
I did use hardware store m8 bolt and nut once on a P80 ball joint retainer and it did not end well. It rusted like crap amd had to be ground off. More of a statement on crappy quality than the application
The BUFO hardware from Volvo is expensive stuff, I try to price anchor it to safety so I feel crappy about cheap hardware rather than the reverse.
I keep a list of stuff near by desk to make up my weekly FCP order to $50 economy shipping , too
Strut mount, control arm, caliper carrier bolts…all reused in good or better condition
- Has thanked: 311 times
- Been thanked: 818 times
I re-use all of those suspension fasteners unless they are in obviously bad shape.
- 1404 Views
Last post by brunocerous
- 632 Views
Last post by IlikemyXC70
- 266 Views
Last post by Allgonquin
- 7073 Views
Last post by foggydogg
- 894 Views
Last post by Reys
