foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
bmdubya1198 wrote: 11 Aug 2021, 10:55 Yuck! It's nasty how much crap gets built up down there. I bet those new parts will feel much better!
Pic didn't do it justice. It wasn't just under the console, it was everywhere. My guess is spilled drink - at least that's what I told myself.
manovlov
Has thanked: 675 times
Been thanked: 164 times
Post by manovlov »
A little steering fluid stuck to my accessory belt. I ordered a new one from my dealer. I disassembled the whole steering pump system to access the alternator but the one I had planned to replace (from a 1998 V70 diesel) is not compatible. So I took the opportunity to clean and degrease everything, I reassembled the alternator and power steering pump, reconnected everything and tomorrow I'll put the new belt. I was too tired to finish.
After that, a good wash at Meguiars and on the way to the test drive, then the refueling.
A question, anyway : This part is to be fix under the steering pump, with the screw of the bracket, right ?
Manov
foggydogg
Post by foggydogg »
Dealing with the steering rack; it froze up solid while I was driving it. Kept it out of the weeds - barely.
Found this.
manovlov
Post by manovlov »
Sub frame to replace, to me, i mean in France, this sends the car to the junk yard... if not in perfect shape.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
Woah, was that the result of it locking up or did you hit something that damaged the rack before? Time for a new subframe!
Has thanked: 1614 times
Been thanked: 4078 times
Ooof, that’s bad
foggydogg
Post by foggydogg »
bmdubya1198 wrote: 11 Aug 2021, 16:19 Woah, was that the result of it locking up or did you hit something that damaged the rack before? Time for a new subframe!
The car is new to me, first time under it; this feature was pre-installed.
Has lots of new stuff, poorly done.
Managed to keep it on the pavement during the Excitement.
foggydogg
Post by foggydogg »
abscate wrote: 11 Aug 2021, 21:58 Ooof, that’s bad
Just got a spreader bar for the floor jack; once I have a man-to-man chat with my back I'll finish dropping it and regroup.
foggydogg
Post by foggydogg »
foggydogg wrote: 11 Aug 2021, 13:27 Dealing with the steering rack; it froze up solid while I was driving it. Kept it out of the weeds - barely.
Found this.
Curios, with that big a whump, that the airbags didn't blow.
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
Well yesterday I finally finished replacement control arms, ball joints and sway bar endlink on the xc90. I will absolutely need an alignment as the wheel is off position and the passenger wheel is visibly toed out. At the end of the jon I was torquing all the bolts according to "googling" and 1 source said to tightened the ballpoint knuckle bolts to 74 ft-lbs. Dont do it!. I snapped a bolt real easy and luckly the old bolts were in perfect shape. I was able to use an ez out to extract the broken piece surprisingly quickly.. I just tightened them by hand after that and called it a day.
