After doing the radiator on my 1999 S70 T5, I have this part left over. I searched the part number and found a post where someone else asked the same question, said he'd figured it out but didn't clearly indicate where it goes. I may need a photo.
Apparently this is some sort of air deflector that goes near the top of the radiator near the shroud, but I'm darned if I can figure out where it goes. It looks suspiciously like it should go near the intake snorkel. Here are photos.
Another mystery part. Help! Topic is solved
- Eddystone
- Year and Model: 1967 Ford GT40 Mk IV
- Has thanked: 63 times
- Been thanked: 81 times
All U.S. market models.
All running and on the road.
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Just throw it out, seriously. Supposedly it's designed to prevent water from entering the air intake, but I haven't had mine on since 2008. 200,000+ miles and through thunderstorms, downpours, and snow, no issues at all. I know many others have just tossed it with no ill effects at all.
If anything, it helps a bit more ram air hit the intake. I'm sure it helps a tiny bit, though likely negligible gains.
If you really really want it back, I think the pic below shows the orientation. (captions are not mine and are not relevant)
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- Eddystone
"Just throw it out, seriously.
I have to have it for the local V70 Concours d'Elegance this weekend. It's number 46 on the check list.
Thanks very much!
Thanks very much!
- Been thanked: 4068 times
They check for it right after the they look for the two little trapezoidal rubber pieces under the hood checks
- Eddystone
Saw them yesterday.abscate wrote: 12 Aug 2021, 04:09 They check for it right after the they look for the two little trapezoidal rubber pieces under the hood checks
Just don’t try to pass off those -1998 rubbers as correct for your car…
- 2221 Views
Last post by Ozark Lee
- 34 Replies
- 4124 Views
- 735 Views
Last post by askperry
- 3056 Views
Last post by BaronVonAnt
- 14 Replies
- 1881 Views
Last post by benpineapple
